TTL to RS232?
·Hi, I'm trying to connect an ultrasonic sensor (SRF02) into the Javelin using a serial port
·However, I'm kind of stuck on how to perform a TTL to RS232 conversion.
·Can anybody help me how to do this?
·Or·are there any websites or other resources that can help?
·Thanks
·Thanks
- Stephen
This thread is being moved from the Stamps in Class Forum to the Javelin Forum. The SRF02 has both I2C and Serial interfaces…bear in mind that any I/O pin on the Javelin can be a serial I/O line and would be TTL. There’s no need to try an connect to the programming port. Take care.
http://forums.parallax.com/showthread.php?p=696420
Edit: You must NOT use a level shifter like max232.
The srf02·connects directly to the javelin I/O pins.
regards peter
Post Edited (Peter Verkaik) : 1/8/2008 4:23:03 PM GMT
