LCD module - know of any
Hi there
I need an lcd module at least 2.5" but for less than $60 AUD.
That can display graphics.
Does anyone know of one or am I dreaming.
Thank you![smile.gif](http://forums.parallax.com/images/smilies/smile.gif)
Check out my robot using the propeller RECONAUTOR
Thank you
You don’t specify what type of display…For example, does it need to be color? Is it something you need to draw on to display or should it just display a composite video signal, such as the unit linked below?
http://www.parallax.com/Store/Microcontrollers/BASICStampModules/tabid/134/txtSearch/LCD/List/1/ProductID/337/Default.aspx?SortField=ProductName%2cProductName
I need it to display lots of information in a clear manner.
Yet it needs to be fairly cheep, as I am already spending a fair amount on other parts of the project.
Thank you
A composite screen implies you already have a video source…a serial screen implies you do not. Without knowing what you need/have there’s little advice that can be offered.
Am not sure how I am going to display the data yet, was going to base that around the displays capabilities.
Composite would be nice however if it is going to be to expensive than serial will have to do.
Thank you
I have some 1.8" color LCDs (557x234) that are inexpensive, but I don't have a driver for the propeller.
If you want to have a go at writing the driver I can send you one with an adapter to plug it into a breadboard.
How many do you need ?
Bean.
www.iElectronicDesigns.com
A picture and datasheet would be nice if you can get them.
How inexpensive is inexpensive?
Thank you
I'll send you one for free if you give a good effect at getting it to work.
I'll send you a PM about prices.
Bean.
