Dual interface of crystals
Is it possible to share a crystal between the propeller and another chip? I have an ADS1211P 24 bit ADC I'd like to use with the prop and it only seems logical that they would be syncronized with the same crystal. I'm not too experienced with how crystals operate so I'm not sure if there would be a probelm. Basically, the propeller XIN and XOUT would stay the same, but the ADC XIN would just be connected to the XIN of the propeller as well. I would think that they would share the same clock freq.
Any problem yet?
Any problem yet?
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Paul Baker
Brian
uController.com - home of SpinStudio
PropNIC - Add ethernet ability to your Propeller!
SD card Adapter
Consider using the 'Synth' object to generate your ADC clock.
I'm using it to generate a 5 MHz sq. wave for the 2nd Prop of a two Prop project. Works great. Only 'costs' one I/O pin.
Harley Shanko
