Emiter base backlash from motor or relay
·I just got the prop to turn on a Radio Shack PNP to drive a 12v light. Works great. I want to hook up a small dc motor 12vdc again from radio·shack. Will the PNP protect the prop from the voltage spike when the motor or relay is turned off?
· I am not sure about Emitter, base backlash thru a transistor.
Transistor is TIP3055 70 W, same size as 5 and 3.3 v regulators.
New Years is over. We can all go back to sad.
Mosquito: An animal which buzzes in your ear and never stops. He may byte you, he may nibble you, but you will know you were bit.
Technologically challenged individual, Please have pity.
Post Edited (mosquito56) : 1/7/2008 7:55:36 PM GMT
www.parallax.com/Store/Microcontrollers/BASICStampModules/tabid/134/List/1/ProductID/142/Default.aspx?txtSearch=industrial+control&SortField=ProductName%2cProductName
The motor I want to run is a very small brushed motor. Reading the industrial control says to protect the mosfet from spikes so I will have to find a diode somewhere. Thanks again for the link.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
that do not go to the stepper directly, and can be @3 volts.
Edit:
Using the advantages of servos as "motor" needs minor modifications only:
www.seattlerobotics.org/guide/servohack.html
Post Edited (deSilva) : 1/8/2008 1:55:51 AM GMT
explains nicely how diodes are used to protect inductor load drivers. The last page offers a schematic.
I found the 1n4001 diodes someone recommended on another thread at mouser. Those suckers are 5cents each. I ordered 100 and the cart changed the price to 3cents each. My problem is that my order is only $25. Need some recommendations on things to buy to build up the warchest for latter.
I was running out of projects to do with the education kit. Luckily my new toys came in from Ucontroller yesterday.
LEON: Thanx for the numbers order 10 to get me started.
Leon
You generaly ask the most extraordinary things....
There are many people who take the effort to answer you, according their best knowledge, just to HELP you.
I have some continuous rotation servos from parallax, that saves me from hacking the servos...
http://www.parallax.com/Store/Robots/RoboticComponents/tabid/198/CategoryID/70/List/0/Level/a/ProductID/102/Default.aspx?SortField=ProductName%2cProductName
Do you think one could hack an encoder into these? -Something like drill a hole into the top and put a reflector on one of the cogs and read it with a ir-led/phototransistor combination ...
I know, for the Boebot parallax offers wheel encoders, but it would be nicer (and more precise) to have something directly on or in the servo.
@Mosquito: Sorry, I hope this is not thread hijacking as it has at least roughly to do with your original post.
Cheers,
Clemens
Post Edited (mosquito56) : 1/8/2008 6:38:09 PM GMT
