Prop Plug kit
I would like to build 10 prop plugs to save a little money. I could not find any Prop plug kit on Parallax.com
The FT232RQ would be a problem for hand solder. What is the NPN transistor?
Thank you.
Michael
Thank you.
Michael
The circuit posting in parallax.com/DiagramsSchematicsandImages/tabid/254/Default.aspx this page can be made with all through-hole components, but....... only works with a serial port, not USB
Brian
uController.com - home of SpinStudio
PropNIC - Add ethernet ability to your Propeller!
SD card Adapter
You will not find a Prop Plug kit because it's expensive to make when you already have the experience and facilities for making an SMT version. The board is smaller. There are fewer holes. The parts are often slightly cheaper. Kits also require the bagging of the proper number of the correct parts ... all manual work. They require much more support, particularly for soldering technique.
If you want to partially build your own, you could buy the FT232R portion from FTDI and build your own reset circuitry. FTDI has a nice USB cable serial adapter with "wire ends". It's essentially an FT232R built into the USB "A" plug and an attached cable that brings out all the necessary connections. There's a 5V signal version and a 3.3V signal version. Both bring out the 5V from USB so you could power your circuit from USB if you wanted.
It costs about $23. It's not much savings over the PropPlug, but you do have access to the USB power.
Quite nice, but has some disadvantages...
Thank you to all. I am getting more familiar with this subject. This forum is a great place.
I have more time than money and I want my friends to get involve by giving them something to start.
Michael
Do those computers you want to use it on have serial ports? If money is an issue, the transistors and resistors that make up the serial cost only pennies a peice... that's probably the cheapest route.
Brian
SD card Adapter
And the disadvantages are .... ?
