BS2pe OWIO commands for servo control
I've got a BS2pe motherboard with a PWR-I/O Daughterboard attatched to it.· Everything seems to work just fine when controlled by the stamp but I want to gain control over those last two·headers on the daughterboard labelled A0 and A1 which require OWIO commands to function.· First, are there hexfiles besides the GPIO version3·firmware that need to be loaded first?· Second, exactly what OWIO commands should replace my normal PULSIN (PIN#), 1(HIGH), (VARIABLE) which I use to get the signal from my R/C receiver?· Third, what OWIO commands should replace my normal PULSOUT commands to the servos?· And how do these fit in with the FOR counter = VARIABLE (start) TO VARIABLE (end) STEP VARIABLE (speed) commands which define servo movement?· Any hints would be appreciated.· I've been banging my head against the Basic Stamp Manual without much to show for it.· Thanks.
Thanks for your help on this.
Stuart
