Mounting Parallax 433 MHz Modules
I just purchased a pair of the 433 MHz RF modules (they work great BTW - thanks Parallax). What I'm searching for now is a good way to mount them in the finished project. Ideally I'd like to have just the antenna sticking out of the project box, but I don't see any obvious way to accomplish this. The only place they appear to disconnect is at the base of the antenna where it connects to the board. Can the board be connected to the antenna with a cable of some sort?
Is it possible to use these with a different antenna that I could mount through-hole on the project box? Does anyone have any other ideas here?
Also - assuming I end up needing to mount the entire thing inside the box, can I safely add hardware on the screw that joins the antenna to the board? Will this affect the range of the RF link if I do so?
Thanks.
Greg
Thanks.
Greg
- Stephen
my only complaint about these RF modules is that there is little to hold the unit down. and I can't get them to work with a propeller.
"A complex design is the sign of an inferior designer." - Jamie Hyneman, Myth Buster
DGSwaner
Thanks for the information!· I think I understand what you are saying here but if you don't mind posting the picture that would be great.
Is there anything holding the antenna to the project box besides the friction of the snug fit in the hole?· I don't think it would be an issue but I just wanted to clarify.
Thanks.
Greg
DGSwaner
