The Gridrunner driver and a question about the VSCL...
Finally, I got my driver to work...
It's based on the NTSC high color driver and an 8x8 tile driver...
Nothing really new...
However I put in tons of comments, explanations and references to the Hydra book so it might have some value for beginners like me.
I really tried to explain every step there was to generate the video signal.
One question though...
If I would just move 512 to the VSCL and not specify any clocks per pixel, what would waitvid output ?
For example,
mov VSCL, #512
waitvid My_Palette, My_Pixel_Data
Does it output 2 pixels since the clock per pixel (cpp) field is 8-bit and zero could be interpreted as 256 or does it automatically divide 512 with 16 for cpp and uses 32 for cpp?
Living on the planet Earth might be expensive but it includes a free trip around the sun every year...
Experience level:
[noparse][[/noparse] ] Let's connect the motor to pin 1, it's a 6V motor so it should be fine.
[noparse][[/noparse] ] OK, I got my resistors hooked up with the LEDs.
[noparse][[/noparse]X] I got the Motor hooked up with the H-bridge and the 555 is supplying the PWM.
[noparse][[/noparse] ] Now, if I can only program the BOE-BOT to interface with he Flux Capacitor.
[noparse][[/noparse] ] I dream in SX28 assembler...
/Bamse
For example,
mov VSCL, #512
Experience level:
/Bamse
Andre'
Not very exiting, but maybe I should go back and try some of the "unused" bits, you never know...
Sorry I forgot to post the results...
Experience level:
/Bamse
Andre'
I got caught up in another project so progress is slow but steady...
Experience level:
/Bamse
