Ping))) #28015 Troubles
Hey everyone,
I am attempting to get started with this Ping ultrasonic distance meter #28015. The datasheet specifies a 5us burst to SIG, then a 750us holdoff, then an output from SIG for 18.5us - 115us. For some reason I don't seem to be getting any signal from the SIG pin. The "ACT" light does come on and I can hear a slight pitch coming from the device. Is there anything else special that is needed?
Attached is the signal when hooked to a scope. You can see the 5us output to SIG but nothing from SIG. Any ideas?
Thanks!
Ben
Thanks!
Ben
I took another look this morning before work and managed to get a signal coming back from the device. My question is, at what points should the pin go from High to Low to Tri-State on the timeline? The reason I ask is because the signal coming back from the Ping))) appears to be accurate only to about 20cm after that it gets very unstable. I'm thinking I've just got the timing on the pin states a little off. Any help would be great.
Thanks again,
Ben
Ambient noise (depending on frequency) could cause erratic readings, but not cause the sensor to malfunction. Once triggered you will get a return pulse, whose width is determined by how the sound takes to return up to the maximum width. The Propeller Object does the following…
Clear the I/O pin (make it low, in case it was previously set).
Make the pin an output.
Set the I/O pin (make it high).
Make the I/O pin an input (in SPIN, the effective time to do this is > 2 us).
Wait for the I/O pin to go high (this is the start of the pulse).
Store the current counter value.
Wait for the I/O pin to go low (end of pulse).
Subtracting the old counter value from the new one gives you the number of clock ticks and you can then calculate the time and distance.
Note that after your trigger pulse you should immediately make your I/O pin an input. I’ve had several people contact me saying they were never seeing a return pulse. Most had never made the I/O pin an input and in two cases, they were using a signal generator to generate pulses with a scope connected to ‘see’ the return pulse. The problem is that the signal generator is asserting the line and the scope will never see the PING))) return pulse in that case. I hope this helps. Take care.
Thanks for the help getting this thing going - I managed to get a good signal coming from the sensor. I've got another issue now·but I don't think this is the right forum for that one =].
Thanks again!
Ben
Post Edited By Moderator (Chris Savage (Parallax)) : 1/9/2008 3:26:31 PM GMT
