interface Propeller<-->LVTTL
Hi all,
I guess I needhelp...I put mself in trouble
I have just bought a Prop to realize my first project and I have realized it is far harder than I have thought.
While I have no problem in programming, this is the first timeI attempt to realize some hw. I have a driver for display I would liketo use with my Prop. I should I build the electric interface?????
Where can I get info? I posted the info I have...I hope somebody could help me.....
I believe you guys have better to do but a small hint would be very appreciated.
Thanks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Post Edited (nicolad76) : 1/5/2008 11:38:43 PM GMT
At first glance this is perfect companion to the Propeller; just connect the 14 relevant datalines to the Propeller I/Os.
Most likely some can even be connectetd to a static level later.
It looks quite similar to a KS0108, for which drivers exist, I think..
It is actually a driver for E-Ink display but unfortunately I cannot post links to the original document since it is not on-line and, well, otehr reason [noparse]:)[/noparse].....
My doubt is about the phisycal interface between the Prop and the driver...I guess I cannot just connect pin to pin directly......
What kind of interface do you think I should build?????
Addendum: On any lines that can be outputs from the other chip, it's always best to add a least a 330-ohm series resistor to protect against bus conflicts from an errant Propeller program.
Post Edited (Phil Pilgrim (PhiPi)) : 1/6/2008 3:04:12 AM GMT
@Nicolad76: I do not understand this... Though you are not the only one...
I told you in my upper posting to just connect those damn lines!
O.k. You need not believe me and wait for more people to say the same....
But just posting this question again ".. I guess, I cannot..." This is, well, not very polite...
Why do you guess this? Is it "Although deSilva said "Do it", I guess, I cannot..."?
Sorry for being rude, but I want to be rude now
Phil is very cautious, but unneccessarily so, I should say,,,
@Phil: The protection diodes will care for 0.6V
I didn't mean to be unpolite, probably I should have studied english at school (I'm italian, country where people usually speaks only italian....·) a little bit more since I did not realiaze I could be offensive...
...afterall I am just starting now with this toy...it is normal to "guess"...
Well guys...I'll let you know how fast I will destroy the whole thing....and thanks for the...well....hint
Ciao
P.S. deSilva, do you ever sleep? What time is it there?
deSilva is probably 3 people one over here, one in Oz or Japan and one in the Americas
