Problem with assembly code
EmptyLocalBuffer
mov t0, #8
ZeroLocal mov Buffer+0, Zero
add ZeroLocal, incrDest
djnz t0, #ZeroLocal
EmptyLocalBuffer_ret ret
Zero long $00000000
incrDest long %10_00000000
Buffer long 0,0,0,0,0,0,0,0
t0 res 1
Is there something wrong with this code?
It doesn't seem to work and I can't figure out why not.
-Chad
E.g. you can put it into some debugger. Ale's pPropellerSim is the most recent one... You have to modify for it, as it does not yet accept constant expressions and preset sequences in a line.
So your problem is on a higher level...
And does horrible harm at the second call
Edit: Though my analysis was absolutely correct, it was a little bit - succinct
Post Edited (deSilva) : 1/5/2008 2:42:01 AM GMT
I suspected something else was the problem, but I set an led right before returning and it doesn't turn on unless the "add ZeroLocal, incrDest" line is removed.
In the same application this code works fine:
EmptyLocalBuffer mov t0, #8 mov t1, #Buffer+0 movd ZeroLocal, t1 ZeroLocal mov Buffer, Zero add t1, #1 movd ZeroLocal, t1 djnz t0, #ZeroLocal EmptyLocalBuffer_ret retStill don't know why the other didn't.
Does the propeller do any pipelining?
movs GetLocal, StoreAt nop GetLocal mov data, Buffer+0seems to work, but ...
movs GetLocal, StoreAt GetLocal mov data, Buffer+0doesn't work right.
EmptyLocalBuffer MOVD ZeroLocal, #Buffer '''' this was missing!!!! mov t0, #8 ZeroLocal mov 0-0, Zero add ZeroLocal, incrDest djnz t0, #ZeroLocal EmptyLocalBuffer_ret rethippy: I thought I tried putting one in there as I couldn't find a detailed description of the Fetch-Decode-Execute cycle to check on the pipelining.
that's probably the issue though
I have a working version now though, thanks.
Chad
At least you validated that I wasn't going crazy and the code should work (assuming proper initialization of course)
-Chad
A simple data array doubles in·memory use·because the calling·code assumes·the array is zero'ed.
Coming at it from another direction, if you cut the need to only·7 longs in buffer you could just unroll the loop and forget the djnz.
At 8 longs, it's a wash.
EmptyLocalBuffer
1)······················ MOVD· ZeroLocal, #Buffer··· '''' this was missing!!!!
2)······················ mov···· t0, #8
3) ZeroLocal·············· mov···· 0-0, Zero
4)······················· add···· ZeroLocal, incrDest
5)······················· djnz··· t0, #ZeroLocal
6) EmptyLocalBuffer_ret··· ret
7) Zero······ long $00000000
8) incrDest· long %10_00000000
Buffer···· long 0,0,0,0,0,0,0,0
9) t0·········· res 1
__________________________ alternatively
1) EmptyLocalBuffer sub Buffer,Buffer
2)························· sub Buffer+1,Buffer+1
3)························· sub Buffer+2,Buffer+2
4)························· sub Buffer+3,Buffer+3
5)························· sub Buffer+4,Buffer+4
6)························· sub Buffer+5,Buffer+5
7)························· sub Buffer+6,Buffer+6
8)························· sub Buffer+7,Buffer+7
9) EmptyLocalBuffer_ret··· ret
Post Edited (Fred Hawkins) : 1/5/2008 8:09:40 AM GMT
I like the SUBs
NAND, XOR, and SHL/SHR #31 will work as well... In fact that was the first lesson in 8080 programming ("How to clear a register"
I would have thought most people would be using #0 for zero most of the time. I think there's the odd case where you can't use an immediate operand, and might need a zero in a memory location, but i wouldn't have thought most routines would need it.
Help to build the Propeller wiki - propeller.wikispaces.com
Play Defender - Propeller version of the classic game
Prop Room Robotics - my web store for Roomba spare parts in the UK
INA, PHSx, or CNT (or even PAR) cannot be used as "dest" operand. So they must be at "scr". WAITPxx is a similar case when you wait for low lines, etc. etc.
I feign ignorance of your fakeconstants, and submit this 11% improvement:
EmptyLocalBuffer
3) ZeroLocal··········sub Buffer, Buffer
4)······················· add···· ZeroLocal, incrs
7) incrs· long %10_00000001
8) t0·········· res 1
