PENGUIN ROBOT 18-Band Radio!!!! - the Code
Title: Penguin 18-Band Radio
Code Name: penguin_radio.bpx
Purpose: A Penguin 18-Band Radio
Believe it or not, this code turns Penguin Robot
into a Radio!!!!!! With 18 bands!!!
This program is in the top 10 list of amazing
and fantastic Penguin Robot programs!
humanoido
PENGUIN RADIO SPECS
Front End - Virtual
Bandwidth - 20 Degrees per band
Speaker - Peizo Element Tweeter
Gain - Auto
Output - Acoustic Mono
# of Channels - 18 bands
Frequency Range - 0 to 360 Degrees (angular measured)
Tuner - Robotic Body
Tuning - Circular Geometry Penguin Rotation
Antenna - Directional by Compass
Audio - VR Sound Synthesizer Chip VSSC
Audio Gen Type - WG Waveform Generation
Audio Waveforms - Up to 4
AVC - Automatic Volume Control, One
Volume - Variable per VVA Virtual Volume Amp
Bandpass Filter - Built In
Mult Waveform Gen - Yes
Mixer - Built into VR Sound Chip
Weight - None
Size - None
Cost - None
Tuner Bands - Penguinese, Penguisonic
Supported Audio - Freqout, Baud, Toggle
Audio Out Port - Port 12
Channel Display - Illuminated Digital Built In
Display Drivers - Standard 1-Digit, VR 2-Digit
Amplifier - VVA Virtual Volume Amp
Control Knob - One, VR, Penguins' Body
Tuning - Virtual Tuning Switch VTS
Storage - EEPROM, Cache
Direction Finder - Yes
Virtual Elements - VVA, VSSC, VSD, VTS
Streaming Content - Yes
Radio Content - Static, Bubble, Chat, Code, Time, Orbit,
Tower, English, Ras, Car, Wild, Alien,
Dance, Ion, Construction, Space, SciFi,
Silent
humanoido
humanoido said...
You gotta hear this to believe it! Penguin will let you tune his
creative international internal digital Penguin Band Scanner Radio.
It's a lot like Short Wave Radio, only the waves are Peguisonic.
Be a PWL'r (Penguisonic Wave Listener). Can you find Penguin
Newscasts in Penguinese? The blue display will show the radio band
numbers. It's fun to tune the random digital air waves! Every band
is different. What will you find tonight? - a goldmine or static?!
Hey! Where's the tuning knob? This is a VR radio! The tuner is all
Virtual Reality. Tuning is by turning Penguins body!
All of the Penguin stations are very unique! To vary Penguisonic
frequencies, use the virtual control knob, by moving Penguin around
in various cardinal directions. This will directly tune the bands.
The reception is proportionally directional. There's roughly a new
radio band scanned every 20 degrees. That's 18 bands of the most
unusual Penguin Radio!
' DIRECTORY ' --------- ' CALIBRATION ' PROMO ' INTRO ' VIRTUAL RESOURCES ' OVERVIEW ' RADIO BAND DISPLAY ' PLACING THE RADIO ON STANDBY ' TUNING ' EMBEDDED RANGE OF DEGREES AND ' AUTO CALIBRATION OF RADIO FREQUENCIES ' TUNING SPEED ' TUNING RESOLUTION ' STREAMING CONTENT ' BAND SAMPLING ' ANTENNA ' RADIO BANDS ' AUDIO OUTPUT ' CONTENT ' CHANNELS WITH RANDOM NATURE ' REPEATER CHANNELS ' PENGUIN RADIO PARAMETERS CHART ' KEY ' RADIO SPECS ' DIRECTION FINDER ' STRONG MAGNETIC FIELDS ' EXTRA PROJECTS ' CHANNEL PROGRAMMING DETAILS ' 01 ZERO BAND, STATIC ' 02 ALIEN PENGUIN WORLD ' 03 PENGUIN CHAT LINE ' 04 PENGUIN MORSE CODE TRANSMITTER TOWER ' 05 OPEN PROGRAMMING ' 06 PENGUIN SPACE STATION IN ORBIT ' 07 REPEATER TOWER ' 08 PENGUIN LEARNING ENGLISH CHANNEL ' 09 ADULT PENGUIN - BLOW RASBERRY CHANNEL ' 10 AUTOMOTIVE - CAR ENGINE REPAIR ' 11 INTL GEOGRAPHIC (NATURES BUBBLING STREAM) ' 12 MUSIC CHANNEL (ALIEN) ' 13 DANCE CHANNEL (HAPPY TAP DANCE) ' 14 ELECTRIC IONOSPHERE ' 15 CONSTRUCTION (PENGUINS WORKING) ' 16 PENGUIN SPACE WAR ' 17 SCI FI CHANNEL (JACOBS LADDER) ' 18 SILENT CREATURES CHANNEL
PENGUIN RADIO SPECS
Front End - Virtual
Gain - Auto
Weight - None
Size - None
Cost - None
Silent
Giggly Googley!
humanoido
A Short Sound Tutorial by Humanoido
Background into Sound Creation
A little background into sound creation - an important element is the waveform. Set up a Sound Oscilloscope to study and examine various sound waveforms and the effects of multiple channels with sound mixing. Multiple sound channels are created. A sound mixer is added. The resulting sounds are set by various baud rates to closely control the waveforms.
Sound Waveform Comparisons & Formation
Actual sounds can be recorded, played back, and the resulting waveform captured. This captured image is then compared to the code waveform formants and adjusted.
Methods of Sound Generation
For other methods of sound generation, not using the VSC Virtual Sound Chip, or otherwise, the baud was simulated. These techniques include FREQOUT, TOGGLE, SEROUT, code commands, nests, pauses, and other methods of making sounds and regulating the essential timing.
Keys to Complex Sound
The key to creating more complex sounds rests within these multiple channels and mixers.
The Nested Subroutine
Another key feature to mixing sounds is the nested subroutine because it has the capacity to regulate the timing to close tolerances and increase the number of sound channels. Be aware that anything placed within the nest is effectual to the waveform. It may be handy to create a timing guide to various code statements that will be located within the nest(s).
Sound and the Basic Stamp
Each basic stamp is a little different. So the sounds will be particular to the version of Basic Stamp microcontroller used. Not only the speed of the processor is a controlling sound element, but the statements execution time as well. These programs are particular to the Basic Stamp 2px and the Penguin Robot. There are Parallax manual guides for doing the conversions from one Basic Stamp to another.
The Sound Oscilloscope
There's a forum thread describing the sound oscilloscope and building a computer interface for it that should help. The sound oscilloscope is a virtual instrument free of charge that installs into a PC computer and has a speed range within the limits of the sound spectrum.
A Challenge
One posed challenge is to create sound that closely resembles the human voice. Penguinese includes such a subroutine. However, more work is needed to refine the results, making the effects more intelligible. In the future, a human speech language processor, created from these sound basics and a Basic Stamp microcontroller, is entirely possible.
More Information
For more information, consult the code comments and examine the sound code structure in the following programs:
that's used to develop sound code. [noparse]:)[/noparse]
http://forums.parallax.com/showthread.php?p=696412
humanoido
http://forums.parallax.com/showthread.php?p=701526
humanoido
operating, which applies to all software utilizing the compass.
Within a 3-foot radius, the compass may report false
readings when near the following items:
computer, radio, speakers, and telephone, plus any
devices generating electromagnetic fields such as
electric cords, motors, disk drives, lights, etc.
When programming Penguin, it's a good idea to stretch
out the USB cable to the maximum length and locate
Penguin away from the computer using the radius rule.
A good tip is to use a simple analog compass to "explore"
the surrounding region and note any deviations in the
needle direction readings.
humanoido
