Hall Effect Sensors
Ok, so I got 5 ACS754SCB-130-PFF Hall effect sensors from Allegro(samples). They are able to measure up to 130 Amps with fairly high accuracy. The output is 0-5V. My question is, where would I be able to get any kind of supply that will output at least 50 amps? I thought I could possibly use a car battery momentarily, with some high value resistors in parallel with each other and in series with the battery. What should I discharge all that power into? Another depleted battery perhaps? I also have a big welder that I might be able to use... Also, how should I go about getting an accurate measurement of the current, besides the hall effect sensors? i.e. caliberation.
Thanks guys.
Thanks guys.
This can draw 100A .
Exact calibration is difficult. You can try to meassure the voltage at the battery. Knowing its internal resistance will give you an idea about the current. Internal restance can be estimated by drawing 10A which can be measured with standard equipment. This will need 1 Ohms@100W.. well..
However as much chemistry is involved the internal resistance might not be such a constant value when drawing 100A
Stick welder: Not good, as the welder is self regulating (soft volatge / amperage curve) when you do have an arc.
TIG welder: Like stick welder.
MIG/MAG welder: bad at low currents, because you do have lots of short circuits in the arc and current varies a lot. Starting at about 200A (with a 0.8mm wire) you do have a spray arc that has a much smoother current consumption.
Car battery. Not so good when starting your car, because it will (hopefully start) and then the current drawn will be much less. While starting, the current also varies a lot (piston at TDC or not).
So take your battery and connect 20 50W bulbs and you have a constant self-regulated current and enough time to measure.
Nick
Never use force, just go for a bigger hammer!
The DIY Digital-Readout for mills, lathes etc.:
YADRO
