mikrokopter
Has anyone on this forum built a Mikrokopter
http://www.mikrokopter.com/ucwiki/
sorry it's in German but google does an ok job translating. I'm working on a design for my own mikrokopter but with a propeller chip instead of the atmega. I figured i would try to port the software to spin. I'm thinking I would build a 2" x2" propeller main board and a second board with sensors like gyro's, accelerometers, compass, altimeter, and GPS (maybe GPS would have it's own Board). I figured I would design a board and see if there was any other interest out there in the propeller community.
Brian
uController.com - home of SpinStudio
PropNIC - Add ethernet ability to your Propeller!
SD card Adapter
(I have a project where I'm going to make one of those fly autonomously using a Propeller. Unfortunately, it has been on the backburner for a while...)
Don't visit my new website...
check this out.. they have these copters + some really super high speed DC motors as well..
http://www.gws.com.tw/english/english.htm
cheers Ron Mel OZ
Looks like a nice piece of kit. I have thought about using a Prop with my cheap electric helicopter, but I doubt it could carry the weight unless I went the whole hog and fabricated up a board. I would be interested to see what you come up with.
I see that mikrokopter decided to design their own speed controller, as they say it needs a 100Hz update rate. Anyone know how to control a brushless motor from a PChip? (It's similar to a stepper motor, but with feedback, isn't it?)
BTW: Loads of quadrcopter info' at: wiki.xufo.net/wiki/Main_Page
Cheers,
Simon
www.norfolkhelicopterclub.co.uk
You'll always have as many take-offs as landings, the trick is to be sure you can take-off again ;-)
BTW: I type as I'm thinking, so please don't take any offense at my writing style
Post Edited (simonl) : 1/4/2008 11:15:23 AM GMT
I'll be using the '5 Axis of Freedom' Gyro/Accel from Sparkfun, which can run off 3.3V, weighs 2grams and is read with ADC. From what I've calculated, a single COG should be able to run ADC on 16 different sensors 100times/second and still have plenty of processing time to spare.(Assuming 8 bit accuracy. didn't look into anything else as the technology - resistors and caps - isn't that accurate)
What do you mean ?
Ron Mel oz..
There are lots of really nice brushless motor controllers available for good prices, and sending control inputs to those controllers is a lot simpler than having the Prop chip control the motor directly. Standard motor controllers are controlled by the same square wave input pulses that control standard servos. Pulse width controls throttle setting - that's it. This way we simplify the software running on the prop - or at least that aspect of it - and it simplifies the board we have to make, and each person can select the size of motors and motor controllers he wants to use, depending on the beast he wants to build. We would really only be concerning ourselves with the autopilot & control system that accepts pulse train inputs from a standard RC receiver made for driving servos. Another plus is that we'd be taking advantage of all the development work that others have already done to maximize the efficiency of the available motor controllers, which is a pretty complicated subject. Motor controllers are certainly not all created equal, and if you've never flown an electric RC helicopter before, believe me - maximum efficiency in getting battery power to the motors is a REALLY BIG DEAL. it can make or break your battery duration, which translates directly into your maximum range (meaning traveling distance), which in turn translates directly into the maximum real-world mission-usefulness of any flying machine. Especially an electric one. (Just in case you wanted to do something with it other than hover it over your coffee table.)
This idea does of course add certain complications to the Prop software that would not be an issue when you're designing an autopilot for only one specific flying machine. For example: small aircraft, of whatever type, are able to suddenly roll themselves upside-down and crash extremely fast compared to a much larger aircraft of the same type. Generally speaking, the bigger it is, the easier it is to fly, because bigger means it's more sluggish on the controls, and that's especially true of helicopters. The difference in handling characteristics can be shocking. Therefore, when your machine is in a 10 degree bank and the autopilot needs to send a control correction to the motors, the nature of that control correction would be different in a tiny copter than in a really big copter. The software needs to offer the user with some very quick and easy way to adjust certain control system settings to suit the size, and the particular handling quirks of the aircraft it's installed in. But this is only a software complication, and not an electrical one.
I'm not suggesting I'm as qualified as the rest of you guys to design this thing because I'm still very new to the prop chip. I'm actually an industrial tool designer and not that much of an electronics engineer. But I do have a pilot's license and I do know something about flying machines, so I thought I'd throw in my two cents about why I think this project would benefit by separating itself from being tied to any one specific size (or performance class) of quad copter. Although I DO think we would have to tie ourselves to the quad copter concept, and not expect any one autopilot system to be adaptable to other aircraft types, like conventional tail-rotor helicopters or fixed wing airplanes.
Or course, separate projects to automate the flight of those other machines would be nice too, but right now I think the quad copter sounds like a better starting point, because it's probably the easiest machine for a computer to stabilize and land without crashing using just accelerometers, GPS, compass, barometer, (if it's sensitive enough to be useful) and a downward facing Ping sensor for inputs. Humans find fixed wing airplanes easier to fly & land, but as with driving a car, vision is more badly needed to land them except under tightly controlled runway conditions.
I'm not a aero-dynamicist but I have a lot of opinions about how this sort of thing could be done.
I would lobby for a co-axial(counter-rotating) design...
I realize that this is somewhat political... but I would remind everyone that Zhukovski did his work in Czarist Russia, many years before the revolution, and the idea survived. So if we promote the concept as being essentially a-political and patent rending, we should be fine.
Besides, if RadioShack sells only co-axial designs, it can't be such a bad idea...
At Christmas time, we could get the guts of a 4 copter platform at RadioShack for $26x4. With two channels available?
Rich
I've been creating a system with first goal of autonomous operation on a small standard tail-rotor helicopter.
Started with a counter rotating design, but the dual DC motor control mechanism had various issues not easy to
overcome with over-the counter parts like motor-mind or the dual-motor controller.
If you're interested in the design and development log look at this RSS feed:
http://123.writeboard.com/abb0cbb24f2e6cff5/feed/d69403e2673e611d4cbd3fad6fd1788e
Steven
As a separate thought I was under the impression that a quadcopter would be more stable than a standard helicopter am I correct in thinking this? Stability was the main factor in my interest in quadcopters.
Owen
I think Brain L is correct: a quadrocopter is mechanically much simpler to build, and I believe it's a simpler control mechanism / maths model too - bear in mind that most copters these days have a 120deg CCPM control set-up).
Anyways: Steven is correct - if we are careful with our object design, there should be no reason not to create a core controller for any physical set-up; the differences will be in the motor / servo commands, and potentially some feedback requirement (?)
Cheers,
Simon
How it would handle if flown manually is anyones guess because the only ones I've ever heard of had artificial stability added by uControllers. For this thing I was thinking that even manual flight would actually be just a matter of the pilot directing the autopilot on where to go, and not really direct manual control. Even if it's a real squirrel to handle manually, if it's the easiest one to write software for, the uControllers quick reaction time could still make it the most successful flier, and the best first machine for this kind of project.
With the quad and four fixed pitch propellers, control corrections are delayed by the fact that you have to wait for the motors to change their RPM before anything happens. Conventional heli's simply change cyclic pitch control while rotor speed stays the same and the reaction to control inputs is instant. For that reason I think quad's would be less able to quickly react to gusty wind conditions and would never match the aerobatic capabilities of regular heli's, but in calm winds I think they'd do fine. Stability in no wind gusts is a much different thing than having the ability to combat a strong gust.
I'm sure simonl already knows most of this stuff, but for anyone who doesn't already own a model helicopter: they have a lot of complications you may not want to deal with.
Post Edited (Brian L) : 1/8/2008 8:13:43 PM GMT
Adapting to different kinds of machines is another reason to separate the motor controllers from the board. Then the outputs can either drive servos on a conventional heli, or motor controllers on the Quad. I think stevenmess2004 is right. If it's given proper forethought, even most of the code could probably be reused on different copter types.
Cheers,
Simon
