Problem with MUXC instruction (I think)
I have hit a wall on the code segment below. From another Cog, I have populated a large area of HUB Ram and the Cog in question reads a portion of that HUB Ram and places it in a table "OutputImageTable" using MOVD in a loop. This table is 48 Longs.
I have verified using Gear, that all the data in the "OutputImageTable" is correct. I have also used PropTerm to verify this data.
The code segment loops and takes 1 word at a time from the table and based upon a Bit pointer, should set/clear one of the output pins based on the MUXC instruction. This is the area that seems to fail.
The MUX_BitPointer· pointer serves 2 functions. First it is used in an "AND" with the table word and if the single bit in MUX_BitPointer and a corresponding bit in the table word are both set, I believe that the "C" flag should be set as this would be an ODD number of bits [noparse][[/noparse]1]. I then use that "C" flag in the MUXC instuction to set/clear the proper output pin but what sounds good on paper does not work so my logic must be flawed.
If I can get the output bits set/cleared (they never get set) then the ClockSet and ClockClear calls will clock that data into 16 external shift registers.
The intent of the loop is to evaluate a given bit position on each of 16 table longs, set the output pin then repeat this 32 times until all the bits have been sent to the output pins.
I would appreciated if one of the group could spot my dumb mistake.
PlaceDataToOutput mov tmpOutImage, #0 mov MUX_BitPointer, #1 mov BitCounter, #0 NextSetOfBits mov RankCntr, #0 'Clear Rank counter mov tbl_Output_Ptr,#OutputImageTable 'Should move the first address of OutputImageTable to tbl pointer add BitCounter, #1 mov MUX_BitPointer, #1 ReadTableRank_W1 'This routine reads the 1st word of each rank, shift all 32 bits to the outa register call #ClockClear movs ModifySrcAddr,tbl_Output_Ptr 'Change Source address for instruction @ label ModifySrcAddr add tbl_Output_Ptr,#3 'Get 1st of 3 words for each rank (3 words/rank) ModifySrcAddr mov tmp1, 0_0 'Pull data from table and place in tmp1. Source address is fed by MOVS above and tmp1,MUX_BitPointer wc 'C flag should be set if odd number of bits in result muxc outa, MUX_BitPointer 'Whatever bit is set in MUX_BitPointer will be set/cleared based on C flag add RankCntr, #1 cmp RankCntr, #MAX_CHROMATIC_RANKS wc, wz, nr if_b jmp #ReadTableRank_W1 'IF < than max number of ranks get next word from table shl MUX_BitPointer, #1 'Check next bit position in every rank call #ClockSet '16 output bits have been set clock them to external Shift Register cmp BitCounter, #32 wc,wz, nr 'have all bits been set if_nz jmp #NextSetOfBits jmp #MainLoop 'REMOVE
Thanks for look at this.
When being unable to see the wood because of all the trees, I generally remove what is not relevant (the comments!!! If wrong they might terribly block you!
Second I start obtimizing, i.e. "transforming" the program. This is what came out:
Again, thanks for looking at this.
Thanks for looking at this and I'll post the results.
