Propeller Serial communication question.
Good evening,
I need to interface the propeller with a "I^2 C" communications protocall wich is Sync.'s
Is this possible with the Propeller ?
I understand that this protocall is timing critical being Sync. instead of Aysync.
But due to the speed of the Propeller I thought it may be fesible.
Our delima is that we need to do this through a pair of trancievers, one being the Master generating the clock signal and another being the slave.
If anyone can give me some information on this subject it would be very helpful.
John Logan
JMLStamp2p@aol.com
John Logan
JMLStamp2p@aol.com
"A complex design is the sign of an inferior designer." - Jamie Hyneman, Myth Buster
DGSwaner
But all implement master mode!
It is not clear from your note (or rather I fear it is...) whether you want to use the propeller as I2C slave? This has still to be done, I think. But will be possible with ease for 400kBit and with dificulties also with highest speed (1MBPS).
Being synchronious is no problem. There is also a technique called "bit stretching" which can relax things considerably..
Post Edited (deSilva) : 1/3/2008 4:17:40 PM GMT
If I remember correctly though, it all went quite when someone from Parallax suggested that Philips would want their royalties for any SLAVE implementation...
Cheers,
Simon
www.norfolkhelicopterclub.co.uk
You'll always have as many take-offs as landings, the trick is to be sure you can take-off again ;-)
BTW: I type as I'm thinking, so please don't take any offense at my writing style
This is no longer the case...
And had never been for software solutions, but for silicon only!
And it depends on how you "call" it cf. ATMEL with their TWI
http://forums.parallax.com/showthread.php?p=617209
www.nxp.com/products/interface_control/i2c/licensing
Cheers,
Simon
