Nice project, but is it possible ...
Your opinions please ..
Next week meeting an old friend to investigate what and especially how he can monitor his machine park.
At this stage all machines are stand alone app's so there is no network.
The idea is to capture production specific data, like running hours, downtime, speed, etc..
To try to keep it as simple as possible (because we speak about approx. 100 machines) the stamps (one for each machine) should only send about 9 bytes to the master (4 analogues as two bytes each, 4 digitals as single byte), and of course a few for the protocol.
My question now, because there are different ways to get to Rome... What is the best one.
One more detail, the area we speak about is industrial, quiet hot and humid in summer (40 degrees and more), and around 100m by 50m.
Total lenght in cabling from node to node would be around 1000m.
Each machines details will be send 'raw', and interpreted (scaled and calculated) on the PC side and stored into a (SQL) database.
RS485 with the SN7516 (for example) and spread it over 3 to 4 networks (32 nodes maximum I think).
Wireless with each node a RF transceiver?
Personally, I prefer the second one because of the cabling, but how can I overcome the distance, can some nodes act as repeaters?
Your input will be much appreciated.
Simple polling would work. The master would transmit a request containing a slave number. If there's no response within some timeout period, the master could try again immediately or simply wait for the next cycle. The slave would normally wait for a request. If addressed, it would read its sensors and send back the data, otherwise it would just listen for a poll.
You would want some kind of checksum on the poll and the returned data. Again, it might be easiest to just throw erroneous data away and wait for the next cycle. If a slave doesn't provide a valid response within a certain number of cycles, it would be flagged as inoperative and would need to be repaired.
I would keep the Baud low, 2400 to 9600 Baud to reduce sensitivity to noise. Even at 2400 Baud, you could query all 100 slaves within 15 seconds.
- Stephen
An RF version means you need a transceiver on each machine for polling.
You Could "Time Slot" each one, but with 100 machines you'd probably have some issues with data resolution (assign 1second per unit and that's 100seconds -- good math eh!).
X10 perhaps? Although it's still cheaper to buy the rs485 IC's AND run cable than to output 100 machines with an X10 device....it'd take longer to wire them all...
<FONT>Steve
What's the best thing to do in a lightning storm? "take a one iron out the bag and hold it straight up above your head, even God cant hit a one iron!"
Lee Travino after the second time being hit by lightning!
