Piezo Film Vibra Tab Mass VS Flexiforce sensor
Hi there,
In the past I used the Flexiforce sensor and found that the results I was getting wern't very accurate, the reading were different everytime I applied the same force.
Is the Piezo Film Vibra Tab Mass sensor any better?
Any help on the piezo film vibra tab mass would be much appreciated.
cheers
cheers
I had the same problems with the flexiforce sensor as you. I think it's a good sensor to use to detect pressures, but not necessarily measure them.
I believe part of the problem had to do with consistantly "preloading" the flexi each time. If you didn't do this right, then you're reading wouldn't match your last measurement.
I don't think the PIezo has the same problem...haven't used it though, but you do have more control with the add-on circuit they describe.
Cheers
<FONT>Steve
What's the best thing to do in a lightning storm? "take a one iron out the bag and hold it straight up above your head, even God cant hit a one iron!"
Lee Travino after the second time being hit by lightning!
