24LC32A EEPROM Issue
Hi all,
I have come across an anomaly that I can not pin down.· It seems that when I am writing to the 24LC32A chip using "P" or "PX" stamps everything·seems to be·recording fine for a while then I get a hiccup, records fine again for a while, then another, and so on.· Meanwhile, on my terminal screen every looks fine throughout the entire recording process.· I have changed out 24LC32A's and the same thing occurs at the same location (See·data dump·below).· I have also tried to look at bit and byte positions for a pattern but I have not been able to find one.
My questions:
Are there any known bugs with this chip? (Probably not, but gotta ask)
Are there any locations in the chip that have special meaning that I should not be writing too?
And, most likely, could it be the way I am writing to memory?
Any help·would be appreciated.· Anomalies are the hardest issues to troubleshoot.· But it is a consistent anomaly at least.
...code sniplet
' This procedure is used for WORD size variables
' wrdAddr and x are passed to subroutine
' wrdAddr is passed back to main procedure with new starting value
Write_Word_Data:
·· I2COUT SDA, $A0, wrdAddr.BYTE1\wrdAddr.BYTE0, [noparse][[/noparse]x.BYTE0, x.BYTE1]
·· wrdAddr = wrdAddr + 2
RETURN
' This procedure is used for BTYE size variables
Write_Byte_Data:
·· I2COUT SDA, $A0, wrdAddr.BYTE1\wrdAddr.BYTE0, [noparse][[/noparse]x]
·· wrdAddr = wrdAddr + 1
RETURN
...end code sniplet
Partial data dump from the chip.· Red line is the anomaly that occurs at 7 locations.·
Full code is attached just in case someone wants to look through it.
WWW.HABP.NET
"Don't ask yourself what the world needs - ask yourself what makes you come alive, and then go do it." - H.T.Whitman
My questions:
...code sniplet
Write_Word_Data:
RETURN
Write_Byte_Data:
RETURN
...end code sniplet
WWW.HABP.NET
bsp
14K
WWW.HABP.NET
Some sequence of writes puts the first byte of a word to be written at the end of a block of 32 addresses and
your program attempts to write two bytes. Because both bytes are in one I2COUT, the first byte will go in the
expected location. The second byte will be written at the beginning of the 32 byte "page" rather than the location
following the first byte. In the first case at 255, the LSB will be at 255 and the MSB will be written to 224 rather
than at 256. It may be that the pattern of single and double byte writes just crosses a 32 byte boundary in the
middle of a word at those locations.
Solution is either to always write a word starting at an even address or split a word write into two separate
byte writes (and their 5ms pauses).
I made the write word statement into 2 seperate statements per you suggestion and it fixed the problem.
I really appreciate your help with this one.
WWW.HABP.NET
