What's wrong with my waitpeq? [ASM]
I have been fighting with the waitpeq command, and need some help.
I have an ASM routine.· It *should* wait for a pin (Adams_CS) which is P0 to drop low.· Once the pin drops low, it should send "AA" out of Pin31.
Without the WAITPEQ command, the Prop Sends out the "AA" as desired.· When I put in the WAITPEQ statement, it won't function at all.
The WAITPEQ Statement is this:
······· WAITPEQ 0,ADAMS_CS
······· -ADAMS_CS is defined as $1 (P0 on prop)
······· -"0" because·the·ADAMS_CS line is·active low.··I want the code to execute when P0 is low.
If anybody can help me, I'd really appreciate it.
Thanks.
Shaun
DAT
START_COG
ORG 0
MOV DIRA, PIN_DIRECTIONS
WAIT_FOR_INCOMING_SIGNAL
WAITPEQ 0,ADAMS_CS
'***THE FOLLOWING SECTION SENDS 1 BYTE FROM "UP_DATA" UP TO THE PC @ 1.5MB/SEC***'
LOAD_UPSTREAM_DATA
RDLONG OUTPUT_DATA, PAR
ROR OUTPUT_DATA, #1
START_BIT
MOV OUTA, #$00 'Drop Level to 0
CALL #BIT_PAUSE_1000000
'DATA_BYTE
CALL #BIT_LOAD 'BIT 0
CALL #BIT_LOAD 'BIT 1
CALL #BIT_LOAD 'BIT 2
CALL #BIT_LOAD 'BIT 3
CALL #BIT_LOAD 'BIT 4
CALL #BIT_LOAD 'BIT 5
CALL #BIT_LOAD 'BIT 6
CALL #BIT_LOAD 'BIT 7
'PARITY_BIT
MOV OUTA, PIN_MASK
'STOP_BIT
'Don't need to Change state because it is correct from Parity_Bit.
'IDLE_LINE 'This returns the line back to Idle.
MOV TIME, CNT
ADD TIME, PAUSE
WAITCNT TIME, PAUSE
JMP WAIT_FOR_INCOMING_SIGNAL
''**********SUB ROUTINES****************************'
BIT_PAUSE_1000000
MOV TIME, CNT
ADD TIME, BIT_TIME_1000000
WAITCNT TIME, BIT_TIME_1000000
BIT_PAUSE_1000000_RET
RET
BIT_LOAD
ROR OUTPUT_DATA, #1
MOV MASKED_OUTPUT, OUTPUT_DATA
AND MASKED_OUTPUT, PIN_MASK
MOV OUTA, MASKED_OUTPUT
BIT_LOAD_RET
RET
PAUSE long 5_000
BIT_TIME_1000000 long 17
PTR long 1
Pin_Directions long %01000000_00000000_00000000_00000000
Pin_Mask long %01000000_00000000_00000000_00000000
OUTPUT_DATA Long $AA_AA_AA_AA
ADAMS_CS LONG $1
Time RES 1
MASKED_OUTPUT RES 1
Rather use a register with content 0
It is working!
Thank you for your quick responses.
