PENGUIN ROBOT Virtual Volume Amplifier - the Code
Title: Penguin Virtual Volume Amplifier (VVA)
Code Name: penguin_virtual_volume_amp.bpx
Purpose: Exploits a method to increase volume
This program is really amazing. Without any parts,
boards, or add ons, this code will become a sound
amplifier. There's no size to the VVA, and it takes up
no space.
The VVA gives Penguin robot the ability to regulate
sound volume, such as alerts, warnings, and
Penguinese language.
Run VVA code and make new discoveries in the
realm of a special sound spectrum (see below).
humanoido
no space.
humanoido
humanoido said...
The most unique discovery made with the VVA
program is the VVA Spectrum, a special range of
sound intensities spanning the hearing range.
' DIRECTORY ' --------- ' INTRO TO VVA ' THE VVA SPECTRUM ' OPERATION ' FUNCTION ' SOUND DEVELOPMENT TOOL ' LIMITATIONS ' ADVANTAGES ' INTRO TO VVA ' ------------ ' Penguin's Virtual Volume Amplifier (VVA) will amplify sound without ' adding any electronic components. Penguin robot exploits sound ' characteristics unique to the peizoelectric speaker. ' THE VVA SPECTRUM ' ---------------- ' Make new discoveries by searching the VVA Spectrum. The VVA ' Spectrum is the space occupied by the entire sound range ' which is peizoelectric speaker capable. This program will allow ' the user to search this range, and make new discoveries! ' OPERATION ' --------- ' The code gives a series of sound play back choices. This ' includes nonamplified sound, amplified sound, and the option to ' experiment by specifying a sound frequency. For each, ' the frequency value is displayed. ' FUNCTION ' -------- ' The Virtual Volume Amp is also a unique sound development tool. ' With the frequency input option, the sound number is entered and ' the result is played back. This can range from audible to ' inaudible sounds, covering the VVA spectrum. It lets you hear ' the sound played through the peizoelectric speaker at its ' occuring volume intensity and tone. This is excellent for pick ' and choose notes, compositions, and many other sound functions. ' SOUND DEVELOPMENT TOOL ' ---------------------- ' The VVA is a sound development tool capable of finding very ' unique sounds and effects. The VVA is a good supplement to ' the Virtual Sound Chip VSC and other sound programs in the ' Penguin program suite. ' LIMITATIONS ' ------------------------ ' There are some limitations such as only specific frequencies are ' amplified. ' ADVANTAGES ' ---------- ' There are many uses for the virtual amp. It ' especially excels at warnings, alarms, alerts, loud notes, sounds ' to overcome noisy environments, variable intensity sounds, sound ' machines, rising amplitudes, magnitude oscillators, harmonic ' generators, music, chords, and sound flags.
