Memory map display question
·· I ran the programs StoreLightMeasurementsInEEPROM.bs2 and ReadLightMeasurementsFromEEPROM.bs2 from chapter 7 of the book, "What's a Microcontroller", and the programs worked fine and I could read what was written to EEPROM.· But when I looked at the EEPROM memory map display using the Run|Memory Map command, I could not see the upper 58 bytes highlighted in any color to indicate that data was written there.· In the legend, there is color coding for defined and undefined data.·
·· Is there some way to have the data I write to EEPROM highlighted when I look at the memory map display?
Thanks!
[noparse][[/noparse]Tim]
Thanks!
·· Duh, that's right...I forgot.· It would be cool though to be able to see a visual representation of where your data is stored in the EEPROM!
Thanks!
