Token decode
My shop was broken into and a computer stolen. This computer had a sx program that was not backed up.
I have the eeprom with the program in it. I can read the eprom code, but I was wondering if there is any source for reversing the token codes back to some sort of human readable text.
Chris
Chris
It probably won't be something you could modify any further anyway.
If you can read the code back you can make new chips if that is your goal.
Bean.
www.iElectronicDesigns.com
That is my goal, to get it back to assembler without the variable names and comments.
It is just to get the aid in re-writing it.
My question is now is how or who?
http://online.dip.jp/angelica/index_e.html
Good Luck
-Kris
I will give it a go.
Chris
The eprom has the token codes.
Is there a disassembler for those codes?
-Kris
I think he means he is using the BS2sx chip.
Chris9999 if that is the case, you should re-post your request in the Basic Stamp forum. Make sure to say you are using the BS2sx chip.
Bean.
Yes it is the BX2sx chip. Sorry for the confusion
I will check out the Basic Stamp forum
