new to this...need help or advice
Hi..I have just purchased..."what's a microcontroller with home workboard" kit.· I am trying to learn this stuff and figured this would be a good start. I have a project that I am needing to control a pnuematic cylinder (120V mac valve)·and 25w 120v party light, a red and a green. I am in the process of building a bmx starting gate, that the gate will drop automatically after a short recording of the bmx cadence is played and after the green light comes on.
My question is..
··· I have been told that I need a relay to be able to use the micro controller with a high voltage, so I dont blow the whole thing up. How does this work and what type of relay DO I need to use with the Parallax Basic Stamp Kit? Especially since I am mixing high and low voltage together...
Any help is greatly appreciated.
thanks
My question is..
thanks
I'm sure more knowledgable people will reply to you also, but the BasicStamp will output a voltage of 5V. So you will need a relay with a 5v input coil, and can handle the output voltage you are using. You should also have a diode across the contact pins of the input coil to prevent inductor kick that might damage the BasicStamp. There are many solid state type relays that would work. You can search some places like www.digikey.com for the relays. Hope this helps you get started.
David
There are 10 types of people in this world,...
Those that understand binary numbers, and those that don't!!!
http://www.crydom.com/products/productFamilyList.aspx?idProductLine=2
Pay special attention to the signal/control voltage and current and the output voltage and current.
Jeff T
Post Edited (kelvin james) : 12/31/2007 7:46:51 PM GMT
