Oscillator versus resonator?
Hi,· i'm trying to interface a 5V motorola coprocessor with my propeller.· However, this coprocessor requires a 20 mhz TTL clock which must be driven high to at least 2.4 V and driven low to at most 0.5 V.· After running into some issues with the coprocessor not working, I checked the 5V 20 mhz oscillator I have for the clock signal by putting it on my scope (including taking it off the load to prevent parasitic capacitance).· The scope reads it high at 3.3V and low at around 0.9 to 1 V.· It appears the problem I could be having is that the oscillator is not driving the clock signal low enough to meet specifications.· I've even tried a different 20 MHz oscillator from a different company and get around the same readings.· Both oscillators say in their specs that they have a low output voltage of 0.5 V.· I've tried soldering all the connections on the oscillators to prevent any stray capacitance.· Should I try a resonator instead of an oscillator?
Note: I understand that the propeller is a 3.3V device.· I am using voltage translators between the propeller and the coprocessor for bus communication.
Please describe, in detail, the precise voltage translator you are using.
JMH
Paul Baker
