PENGUIN ROBOT Morse Code Foot Tapper - the Code
Title: Penguin Morse Code Tapper
Code Name: penguin_code_tapper.bpx
Purpose: Penguin Robot taps out Morse Code with a foot!
This program is more than fun!
Set Penguin Robot on a wood table and listen
as this little bot taps out Morse code messages with
his left foot!!!!!!!!!!!!
humanoido
humanoido
' INTRO ' ----- ' Penguin robot has the Morse Code itch, in his foot! ' He calls for help using a foot to tap out a message. ' Code: three short, three long, and three short - SOS!!! ' MESSAGE REPEAT ' --------------------------- ' Penguin will tap out the message 5 times and stop. To repeat, ' touch reset. To lengthen or shorten the message repeat, change ' the FOR NEXT value of X in the main program. Note that X is a ' nibble range. ' CHANGING THE FOOT TAP MESSAGE ' ------------------------------ ' To change the message, just vary the subroutine calls in the ' main program. Use any combination of tapdit and tapdah followed ' by the appropriate pause. ' CALIBRATION ' ----------- ' Place calibrated values for tilt and stride into the ' declarations section. For example: ' CenterTilt CON 1900 ' this is the tilt center value ' CenterStride CON 1900 ' this is the stride center value
