Lantronix WiPort
I've got a Lantronix WiPort development kit. I'm supposed to mount the evaluation board onto a robot and use it to communicate with the PC wirelessly. I've got the board configured, anyone knows what am·I supposed to do next?
http://www.lantronix.com/support/documentation.html#embds
There is an eval kit quick start guide guide, integration guide and user guide,
plus datasheet.
regards peter
the moment she steps into my life, things changed
What you need to do is to setup two Javelin Uart objects, one for receive (connects to wifi TX pin)
and one for transmit (connects to wifi RX pin). That way you can communicate with the javelin
via wifi and virtual comport, but you can also use network connections. What exactly is possible
is described in the manuals. If you don't understand the manuals, you need to go through them
again, reading them carefully.
regards peter
