breaking up variables to pieces?
I have this " Hello world", I want this
H
E
l
l
o
W....
·· I have tried this
'' Print a zero-terminated string
· repeat strsize(stringptr)
··· term.out(byte[noparse][[/noparse]stringptr++])
··· term.chr(everything I could think of 10,13 lineclf) nothing works
and searched search.pallalax.com but everything is for stamp on sting work.
I am looking for substring("string", start, length) or a way to do it.
A pointer to the place that deals with memory and breaking var's up would be nice.
Mosquito: An animal which buzzes in your ear and never stops. He may byte you, he may nibble you, but you will know you were bit.
Technologically challenged individual, Please have pity.
H
E
l
l
o
W....
-Martin
SelmaWare Solutions - StampPlot GUI for controllers, XBee and Propeller Application Boards
Southern Illinois University Carbondale, Electronic Systems Technologies
American Technical Educator's Assoc. Conference·- April, Biloxi, MS. -- PROPELLER WORKSHOP!
Try changing to "Good bye cruel world"
also there is no for next in spin: also there is no way to see it on the next line.
That is a first day example from a basic book. I could be wrong. If so appologies on end.
PUB dec(value, scaleBy) | i '' Print a decimal number if value < 0 -value out("-") i := 1_000_000_000 repeat 10 if i == scaleBy / 10 out(".") result~~ if value => i out(value / i + "0") value //= i result~~ elseif result or i == 1 out("0") i /= 10If you want 2400 to display as 2.400, you'd call dec(2400,1000).
Obviously, change calls to out() to be whatever you need.
-Martin
His code should read as follows, and it would be very similar to Mosquito's in his OP:
Coming to numbers there are many formatting options with the object NUMBERS and FLOATSTRING.
When you want to do it yourself, you have to do some COPYING, using BYTEMOVE(dest,src,size)
So:
(1) allocate the memory for your string to be, either in VAR space, or - more obvious - in DAT space. The advantage with DAT is that you can better place templates...
Ex:
(2) You can output this string by a .STR routine of a driver.
(3) You change parts of it
- either by loops containing
or something more intelligent.
- or copy from another place
