Batteries for Penguin Robot — Parallax Forums
xavixavi Posts: 5
edited 2007-12-30 23:26 in Robotics
Hi all,
I'm interested in using CR123A 3.0V Rechargeable Batteries in my penguin.
Is it possible? Has anyone tried them?
Thank you,
xavi
  • SuperwormsSuperworms Posts: 118
    edited 2007-12-30 20:54
    probelly, but i don't have a penguin, so i'm just giving you my two cents
    Equipped with his 5 senses, man explores the world around and calls his adventure science
    -Edwin Hubble
    edited 2007-12-30 22:09
    I've not heard of rechargables in a CR123A size. You could certainly use something like this as long as the output voltage and current were adequate. I think the Penguin draws about 170mA average when moving and the batteries provide about 2.7-2.8V each for several hours.
    You would need to use some kind of external charger designed for the batteries.
    I glanced at some of the ads I found with a quick websearch. They have about 1/2 of the current capacity of the disposable CR123As (700mAh vs. 1400 mAh). I see no reason why they wouldn't work.
    Post Edited (Mike Green) : 12/30/2007 10:17:19 PM GMT
  • xavixavi Posts: 5
    edited 2007-12-30 22:46
    ok, i'll buy and test them.
    If anyone is interested, I found these batteries at http://stores.ebay.com/GREATSUCCESS123-SUPERMARKET
    A similar deal can be found here. These are lithium ion batteries (the kind that have been known to catch fire if they overheat while recharging or short internally during use). So use and charge at your own risk.
