What should a Propeller OS have? (Sphinx/SphinxOS, PropDos, PropCmd, FATEngine, - Page 4 — Parallax Forums
124»
    edited 2010-06-19 15:47
    Kye said...
    You missed my point. How do you tell a FAT FS system cog what to do using a mailbox rountine? Its not that simple. I'm not talking about low level get block and put block rountines. I'm talking about opening files and such.
    Here are the files I use to communicate to the file system.· cfileio0.spin is used by the calling cog, and cfileio1.spin is the top object that runs the polling loop on the file system cog.
    Dave
    edited 2010-06-19 16:03
    Bill, most of the cog will be FS agnostic, just providing sector read & write functions just as fsrw (well it is the sdspifemto equivalent... mb_rawb_spi). If there is space, we can add some Fat16/32 stuff - maybe directory. I doubt we can fit much more. mpark used 3 cogs for the full FAT16 code.
  • jazzedjazzed Posts: 11,803
    edited 2010-06-19 16:13
    Kye said...
    This is why the mailbox can't be simply one long (unless current Propeller is the only target).
    With a pointer however, you have a reference to a data-structure which can be anything.
    Dave's code defines a fair and flexible idea and should be usable with PASM too.
    I was going to suggest something similar with the addition of flags in service type.
    • a service type command field and flags
    • pointer to struct used with service type
    Cheers.
    --Steve
    Propeller Pages: Propeller JVM
    edited 2010-06-19 16:44
    I don't mind additional functionality - but here is the minimum functionality Largos expects:
    - sd_open (basically initialize card)
    - sd_read (read one sector)
    - sd_write (write one sector)
    - sd_ioctl (read/write SD specific info - card size, error count, error code etc)
    - sd_close (basically unmount)
    All SD access should release the SPI bus fully (it is OK if there is an IOCTL to keep SPI bus open for faster applications) so the bus is available between sd_* calls
    The source code of the SD cog should have two subroutines called SELECT and RELEASE.
    SELECT asserts /CS
    RELEASE de-asserts /CS, and provides the necessary number of clocks to finish de-asserting /CS
    The reason for this is that with these explicit routines being the only routines for selecting/de-selecting the SD it will be VERY easy to port the SD cog to different types of SPI multiplexers. Why is this important to me?
    - PropCade uses a simpler multiplexing scheme that is reasonably compatible with existing drivers
    - Morpheus+ uses a multiplexing scheme to add uSD, SPI memory and support the I/O on Mem* ... and it is not as simple as the PropCade scheme
    - other boards use multiple /CS signals from the prop to support SPI peripherals
    The generic mailbox format I use for my drivers is four consecutive longs:
    mbox[noparse][[/noparse]0] = command
    mbox = source pointer
    mbox = destination pointer
    mbox = count
    command needs to be non-zero for the driver cog to do something, and when the driver cog is done, it clears command
    Mind you, I myself depart from the generic usage (VMCOG for example) when necessary, but the key concept that NEVER varies is how mbox[noparse][[/noparse]0] != 0 means there is a command to process, and mbox[noparse][[/noparse]0] == 0 means the driver is ready to receive a command.
    Later, after much more experimentation, I may standardize my mailbox more.
    Generally, my drivers support the following minimum command set:
    _open
    _read
    _write
    _ioctl
    _close
    The above may seem familiar to some [noparse]:)[/noparse]
    Cluso99 said...
    www.mikronauts.com E-mail: mikronauts _at_ gmail _dot_ com
    My products: Morpheus / Mem+ / PropCade / FlexMem / VMCOG / Propteus / Proteus / SerPlug
    and 6.250MHz Crystals to run Propellers at 100MHz & 5.0" OEM TFT VGA LCD modules
    Las - Large model assembler Largos - upcoming nano operating system
    edited 2010-06-19 18:55
    jazzed said...
    Another thing that may be useful is a lock to make it cog-safe.
    edited 2010-06-19 19:27
    Dave Hein said...
    Yes, that is similar to the linux model for multiprocessing where spinlocks (yes
    that's what they are really called) are used to ensure exclusive access.
    Of course that would mean having a lockid semaphore in a data structure
    passed by reference in the mailbox which means mailbox must a pointer
    for such shared access.
    I proposed a compromise on stdin/stdout and other device mailbox definitions.
    Basically, there are 2 types of interfaces: character and stream (reference).
    It would be nice if any of the mailboxes used by the system could be of either type.
    I propose the MSB (bit 2**31) of the mailbox be used to disambiguate the type.
    If the MSB is clear, then the mailbox is character based meaning, the long is the
    mailbox and not a pointer; this allows one to spin on the mailbox bits if required.
    If MSB is set, then the other 31 bits provide a reference pointer to the interface
    data structure; this allows for a complex interface which can include locks.
    So, that provides a solution for flexibility that is better than previously considered
    regarding all mailboxes rather than certain mailboxes being some fixed type.
    I hope this is acceptable.
    Cheers,
    --Steve
    edited 2010-06-19 20:01
    Hi Steve,
    Can't be bit 31 of the command long, makes the spinner longer.
    I had a different way...
    mbox(1) is normally the source pointer
    If it was a value between 0 and 255, it was a character
    ie
    mbox(1) := "H"
    mbox[noparse][[/noparse]0] := _putch
    and
    mbox(1) := @a_string
    mbox[noparse][[/noparse]0] := _puts
    and
    mbox(1) := @a_ptr
    mbox(3) := len
    mbox[noparse][[/noparse]0] := _write
    and
    mbox[noparse][[/noparse]0] := _getch
    (if mbox(3) == 0, no timeout, otherwise mbox(3) = timeout_ms)
    returns mbox(1), if 0..255 = valid character, if -1 = timeout or error
    The above is the Largos way [noparse]:)[/noparse]
