knockoff ping sensor? — Parallax Forums
    edited 2009-05-10 19:39
    It's not a PING. It's a motion sensor, not a distance sensor (read the description!). If you want to detect motion between 3mm and 3m, I suppose you could use it, but the description doesn't tell you how much motion is needed or in what direction in order to trigger it.
    Post Edited (Mike Green) : 5/10/2009 7:44:32 PM GMT
  • thebucketmousethebucketmouse Posts: 20
    edited 2009-05-10 19:52
    ah, right. thanks for clearing that up for me
  • PrettybirdPrettybird Posts: 269
    edited 2009-05-11 18:20
    I have a similar device. It is a simple TTL hi low signal. As Mr. Green said it can be used as a swithch but not a measurement device. I tried it with a a LED and a scope. No analog to mess with. I may have a use for it in the future. It will detect obsticles.
