How can I measure temperatures around 170 C? — Parallax Forums
jmspaggijmspaggi Posts: 629
edited 2009-05-01 08:44 in Accessories
Hi,
I'm will have soon a solar-hot-water-heating-system. And I want to do some "tests" with it. So I'm looking for a way to monitor the temperature at the exit of the 3 panels.
In sumer, the glycol inside the pipes can go up to 160 degrees. So I can't use a regular DS1620 of DS18B20, which measure only up to 127C.
Also, the pannels are on my roof, and the controller is 3 floors below. At about 30 feets from the panels.
I was thinking about using a 1-wire component because of the distance, but maybe also a 3-wire can works if I slow the shift-in shift-out.
So do you have any suggestion regarding the sensor I should us? The cheaper the better since this is not going to last forever.
Also, Mark (ElectricAye) pointed me that I can have so solder issues with a so high temperature. Can I "simply" use another soledring product?
Thanks for your recommandations,
JM
  • LeonLeon Posts: 7,620
    edited 2009-04-28 21:32
    You will probably have to use a thermocouple.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
  • dandreaedandreae Posts: 1,375
    edited 2009-04-29 13:50
    The DS2760 Thermocouple is a one-wire device that will work for this project.· Here is a link for more information:
    http://www.parallax.com/Store/Sensors/TemperatureHumidity/tabid/174/CategoryID/49/List/0/Level/a/ProductID/96/Default.aspx?SortField=ProductName%2cProductName
    Features:
    • 1-Wire interface allows multiple devices with just one BASIC Stamp I/O pin
    • Cold Junction measurement: 0°C to +127°C (0.125°C resolution)
    • Low power consumption: Active current = 90 µA max, Sleep current: 2 µA max
    Key Specifications:
    • Power Requirements: 2.5 V to 5.5 V @ 90 µA (max)
    • Communication: Dallas 1-Wire® Interface with unique 64-bit device address
    • Dimensions: 1.08 x 0.43 x 0.3 in (27.5 x 11 x 7 mm)
    • Operating Temperature: -4 to 158 °F (-20°C to 70°C)
    • Thermocouple Module
    • K-Type (Chromel/Alumel) Element Temperature Range: 32 to 1873 °F (0 to 1023 °C)
    • J-Type (Iron/Constantan) Element Temperature Range: 32 to 1873 °F (0 to 1023 °C)
    • T-Type (Copper/Constantan) Element Temperature Range: 32 to 752 °F (0 to 400 °C)
    Dave
    Dave Andreae
    Parallax Tech Support·
  • jmspaggijmspaggi Posts: 629
    edited 2009-04-29 15:19
    Hi Dave, hi Leon,
    Thanks for your replies.
    The space I have between 2 solar pannels is abour 1 inch, and the wires are 18" long. I can round the wire around the pipe, but will it still be correct like that? Also, since I will have to build 2 other boards for the 2 other wires, can I buy a DS2760 board from parallax without the wires?
    JM
  • QuattroRS4QuattroRS4 Posts: 916
    I have previously done the following -
    Thermocouple to AD595 to LTC1298 to MCU.. The AD595 is a monolithic thermocouple amplifier - giving an output in the 0-5v range. The LT1298 is a dual channel 12bit ADC .
    John
    'Necessity is the mother of invention'
    Those who can, do.Those who can’t, teach.
