Forum Update - Announcement about May 10th, 2018 update and your password.
FPForth
deSilvadeSilva Posts: 2,967
edited November 2007 in Propeller 1 Vote Up0Vote Down
"frohf" has now finally posted his first Forth for the Propeller.
(a) Use it from a terminal window @19,200 baud. Ariba is just testing a new PropTerminal for it smile.gif
(b) Details see below; some "FORTH for Dummies" will follow
(c) There are obviously some problems with the early versions... I try to keep you up to date so you need not wonder smile.gif
Status FPForth 0.72
- stack underflow issue has been fixed
- auto Hydra recognition, so there is no extra binary for the hydra any longer!
- Frohf has prepared a short but comprehensiv PDF with a list of all implemented WORDs
Issues
- ." does not work correctly
Some WORDs explained - (0.71):
WORD ( Stack before -- Stack after ; <string> ) C/I/COG
C = Compile only
I = Immediate
COG = executed inside the COG without any internal reference to the HUB
"Stack Notation" as standard with FORTH, using the following data descriptors:
   a   Aligned Address
   b   Byte Address
   c   Character
   f   Flag, TRUE or FALSE
   n   Signed integer
   t   Flag, TRUE or FALSE
   u   Unsigned integer
   w   general value
   T   TRUE
   F   FALSE
   na  Name Address
   la  Link Address
   ca  Code Address
   cca COG Address
<string> indicates a specific use of the trailing characters, e.g.  SEE WORDS
! ( w a -- ) COG
Stores 16 bit of a value value w to address a
# ( d -- d )
Converts one character of a number. The number is converted according to actual number base
#> ( d -- b u )
Limits output string. Yields string address u and length b.
#S ( ud -- 0 0 )
Generates number string by calling # until the number is converted.
' ( -- ca ; <string> )
Displays code address ca of the trailing word <string>
( ( -- ; <string> ) I
Starts a comment upto next ')'
* ( n n -- n ) COG
16 bit (!) multiplication
+ ( w w -- w ) COG
addition
+! ( n a -- )
Add n to (16 bit??) cell at address a.
- ( w w -- w )
Subtraction
. ( n -- )
Display 32bit number after convertion according to actual number base
/ ( n n -- q )
32 bit division
/MOD ( n1 n2 -- n3 n4 ) COG
n1/n2 = n3 remainder n4.
0< ( n -- t ) COG
TRUE if n<0
< ( n1 n2 -- t ) COG
TRUE if n1<n2
= ( w1 w2 -- t ) COG
TRUE if W1==w2
@ ( a -- w ) COG
pushes the 16bit value from address a
2/ ( n -- n ) COG
fast divide by 2
2* ( n -- n ) COG
fast multiply with 2
2! ( w a -- ) COG
Store 32bit value w to address a
2@ ( a -- w ) COG
pushes the 32 bit value from address a
0 1 2 -1 COG
the very numbers 0, 1, 2, and -1
1+ ( n -- n ) COG
fast plus 1
1- ( n -- n ) COG
fast minus 1
2+ ( n -- n ) COG
fast plus 2
2- ( n -- n ) COG
fast minus 2
@EXECUTE ( a -- ) COG
executes any token <> 0 at address a.
ABS ( n -- +n ) COG.
AND ( w w -- w ) COG
BL ( -- c )
pushes a space ("blank character")
C! ( c b -- ) COG
stores 8 bit value c at address b
C@ ( b -- c ) COG
pushes 8 bit value from address b
COG! ( w cca -- ) COG
stores a 32bit value w to COG register cca.
COG@ ( cca -- w ) COG
pushes a 32bit value w from COG register cca.
BINARY ( -- )
Set number base to 2
DIRA ( n -- ) COG
EMIT ( w -- )
send w to the standard serial port
DECIMAL ( -- )
Set number base to 10
DROP ( w -- ) COG
DUMP ( a u -- )
Display u characters starting at address a
DUP ( w -- w w ) COG
HEX ( -- )
set number base to 16
I ( -- w ;R -- ) COG
copies value w from the return stack to the data stack.
I+ ( R n -- n+ )
increment return address
I- ( R n -- n- )
decrement return address
OUTA ( -- n ) COG
MAX ( n1 n2 -- n )
MIN ( n1 n2 -- n )
MOD ( n1 n2 -- n )
remainder
NEGATE ( n -- n )
NOP ( -- )
no operation
NOT ( n -- n ) COG
inverts each bit
OUTA ( n -- ) COG
OR ( w w -- w ) COG
OCTAL ( -- )
Set numbert base to 8
OVER ( w1 w2 -- w1 w2 w1 ) COG
R> ( -- w ;R w -- ) COG
removes return address and pushes it to the data stack.
R@ ( -- w ;R -- ) COG
pushes return address to the data stack without removing it
ROT ( w1 w2 w3 -- w2 w3 w1 ) COG
SWAP ( w1 w2 -- w2 w1 ) COG
TRUE ( -- T ) COG
same as -1
WITHIN ( u lo hi -- t )
TRUE if lo<=u<=hi
WAITTICKS ( n -- ) COG
as WAITCNT(CNT+n)
WORDS ( -- )
lists all defined words
XOR ( w w -- w ) COG
Post Edited (deSilva) : 10/16/2007 6:31:54 PM GMT
  • 47 Comments sorted by Date Added Votes
  • rjo_rjo_ Posts: 1,825
    edited September 2007 Vote Up0Vote Down
    deSilva,
    Thanks for all of your contributions to the forum.
    Would it be possible to add a "bignum" function to FPForth... I would like to do completely unscaled integer math on the Prop. For example... adding two integers the size of the Encyclopedia Britanica together.
    Rich
  • lnielsenlnielsen Posts: 72
    Two·quick notes on FPForth:
    1. If you are using HyperTerminal you have to disable flow control. I will be trying PuTTY this weekend because I hate HyperTerminal.
    2. The German thread has more information. You can use this·Babelfish link for something that looks like English.·
    It has been years since I have done anything in Forth so I have some relearning to do. Someone else might have some better recommendations but I am starting by reading two·of Leo Brodie's books·that are available on the Internet
    1. "Starting Forth"
    2. "Thinking Forth"
    Thanks frohf for developing this and thanks deSilva for keeping up informed!
    BioProp: Robotics - Powered by Bioloids and controlled by the Propeller
  • KeithEKeithE Posts: 903
    Here's another book "Programming Forth" by Stephen Pelcwww.mpeforth.com/arena/ProgramForth.pdf
    Any chance that this propeller forth will support CREATE ... DOES> ? Last that I looked on the German forum I didn't see DOES> present. I don't know if it's missing due to technical difficulty, ideology (e.g. Ting's eForth), or maybe I just missed it.
  • deSilvadeSilva Posts: 2,967
    Good references!
    I added the list of implemented words. There is no specific limit to it: Frohf will will most likely implement what he needs and where a request is for...
    Note that there is a small kernel of words totally implemented inside the COG.
    It might be important to know that the complete stack is also allocated inside the COG, limiting its size considerably, but without any bad effects so far....
  • LeonLeon Posts: 7,619
    I've just tried it. It executes the first command OK, but subsequent commands don't get executed properly. I can't get a colon definition to work because of this problem.
    Leon
    Edit:
    I had the terminal program set for CR/LF. Changing it to CR only got it working properly.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
    Post Edited (Leon) : 9/29/2007 5:44:24 PM GMT
    Leon Heller
    G1HSM
  • rpraverrpraver Posts: 19
    Is there a version that runs on the Hydra?
    As it uses pins 30 and 31 only at the moment the difference is just the 10 MHz crystal. I think Frohf will make a version smile.gif
    edited October 2007 Vote Up0Vote Down
    I just uploaded v0.70 - see posting #1. There is now a 5MHz (checked on the Protoboard) and a 10MHz crystal version (checked on the Hydra)
  • LewisDLewisD Posts: 29
    Is the source available?
    I don't wont my time to be wasted like it was on the last Forth I tried...
    LewisD
    Be patient!
    FPForth will undergoe still some basic revisions.
    And you cannot waste too much time as long as there is just a binary smile.gif
    I think what LewisD meant was that without the source code, this could become another abandonded project like Cliff's Forth. It sounds like frohf will be publishing source as soon as the first full release is ready. As I understand it, this will include SD/EEPROM file support and the ability to access spin/asm objects running on other cogs.
    Personally I am waiting for Propeller Terminal support via PC_Interface and the ability to call my own Bioloid communication driver code. In the mean time, I am re-learning Forth and working on my driver and sensor code.
    By the way, What was changed in version 0.70 other than the·crystal speed?
    See the first message in this thread, bug fixes in 0.70 are listed.
    Leon
    Leon Heller
    G1HSM
    Thanks lnielsen
    I am concerned that it may be abandoned.
    I am very interested in using a Forth for my robot projects...
    LewisD
    Don't fear!
    Of course this can always happen with any one-man-project...
    But we think it has first to get some internal stabiliity before it should be allowed to "spawn" into variants...
    The community is small.. In fact I have no idea how large at all!? This forum has 10,000 users, so 20k to 30 k may be a good guess - but may be not...
    <Edit> My mistake!! 10 k is the count for ALL Parallax forums, impossible to separate them. So according to popularity, history, and the "feeling" from the Propeller forum, I should say there are 1k interested in propeller rather than 10k ... So there is no justification for jumping to 20k to 30k as I did the other day... </Edit>
    I should say - and this is again a guess, not even an "educated" one:
    75% SPIN only
    10% SPIN with mixture of assembly language
    10% with high interest in C-Compiler, now messing arround with SPIN and assembly
    4% interested in an alternative high performance development system for dedicated and customized Propeller solutions; FORTH being their favourit, but willing to change to C when it's good, or stay with assembly if FORTH does not perform...
    1% FORTH addicts
    <Edit> But after a reconsideration by far less :-( </Edit>
    Post Edited (deSilva) : 10/5/2007 7:00:34 PM GMT
    I just load forthhydra_070.binary on my hydra and all
    I get is a blank screen? What am I missing?
    Thanx
  • Mike GreenMike Green Posts: 22,646
    This Forth uses the serial connection to the PC for its console. You need to run a program like Hyperterminal on the PC with a connection at 19.2KBaud. There's no support currently for VGA or TV and the PS/2 keyboard.
    I load the Hrydra with forth.
    I have started Hyper terminal @ 19.2K and still no joy....
    Sorry to hear :-( You can be sure I checked it...
    But with Aribas new PropTerminal only, which autoconfigures to FPForth and also shows a larger screen.
    When you use Hyperterminal the Propeller is reset, so if you have loaded Forth to RAM rather than saved it to EEPROM there is nothing to see....
    19.2k, 8 bits, no parity, no handshake!
    You also need upper-case, and CR at the end of a line.
    Leon
    Leon Heller
    G1HSM
    New version 0.71 (see first posting)
    - also displays number of used stack elements
    - DIRA, INA , OUTA now work!
    - new words:
    CHAR
    [noparse][[/noparse]CHAR]
    COG@ -- to be used with Propeller constants, see below
    COG!
    DOES>
    I+
    I-
    I
    WAITTICKS
    On the Hydra there is an LED an I/O 0
    1 DUP DIRA OUTA
    INA .
    CNT COG@
    Constants (in fact register numbers)
    PAR, CNT, CTRA, CTRB, FRQA,
    FRQB, PHSA, PHSB, VCFG, VSCL
    Note: INA, OUTA, and DIRA are not constants but implemented as somewhat faster instructions
    Post Edited (deSilva) : 10/9/2007 8:27:51 PM GMT
    I just added a short explanation of many of the words in posting #1
    It now works fine.
    Did the trick.
    When creating a new connection the handshake defaulted to "HARDWAGE"
    Regarding the documentation in the post:
    "COG = executed inside the COG without any reference to the HUP
    w···general·value·(32·bit)
    ! ( w a -- ) COG
    Stores a 16bit value w to address a
    @ ( a -- w ) COG
    pushes the 16bit value at address a"
    Is the ! and @ documentation correct? At first it says that "w" is 32-bit, then later it says that ! and @ store/load 16-bit values, but uses "w" in the stack comment.
    Also I think that the "COG" implies no HUB access, but aren't these accessing RAM through the hub? Maybe it really means that the word exists solely in the COG, but it can still take actions that require the use of the hub?
    Also DOES> didn't make it into the list at the top. Glad to see that it was added to the forth though.
    Keith
    Yes, Keith, you are right, I shall be more precise... It was translated in a hurry, from Frohf's note which still have some typos in it....
    The rules are:
    Everything that is stored in or loaded from HUB is a 16-bit value (or a character)
    Everything handled in the COG (and on the stack, which is COG based) is a 32 bit value.
    The attribute "COG", means just that the FORTH interpretation needs no access to the HUB (extended dictionary)
    Added the Hydra variant(therehad been an issuewith it yesterday).
    At last:
    1 DUP OUTA DIRA
    Could you add placeholders for:
    CHAR
    DOES>
    In your top post? Also is CREATE in the image?
    Has any work been done on things like VARIABLE or ALLOT ?
    I haven't actually played with this yet.
    Try WORDS
    Most things work as in many FORTHs - exept they could still have issues smile.gif
    More documentation is underway...
  • SapiehaSapieha Posts: 2,964
    Hi deSilva.
    Posible stack BUG!
    ·( 1 ) ok
    ·( 1 ) ok
    TIME Zeit: 3, 2357 mS
    ·( 0 ) ok
    TIME Zeit: 429496, 7295 mS
    · underflow?
    ·( 0 ) ok
    ·( 0 ) ok
    ·( 0 ) ok
    ·( 0 ) ok
    WORDS ( 5 ) ok
    ·( 5 ) ok
    ·( 5 ) ok
    TIME ( 9 ) ok
    Sapieha
    Regards
    Sapieha
    _____________________________________________________
    For every stupid question there is at least one intelligent answer.
    Don't guess - ask instead.
    If you don't ask you won't know.
    If your gonna construct something, make it as simple as possible yet as versatile/usable as possible.
    Thankl you, Sapieha! This is an already known bug, mentioned in the summary 0.71 in the first posting.
    Frohf is just fixing it; a new version will be uploaded on Tuesdy.
    Hi deSilva.
    Thanks for replay.
    TIME Zeit: <-- Posible in english ??
    Sapieha
    Regards
    Sapieha
