12v DC to 24v DC
PLJack
Is there a way to convert 12vDC (car battery) voltage to 24vDC voltage.
Jack
Jack
There are lots of DC-DC converters on the market. Try a Google search. How many amps of 24 volts do you need?
Maybe we can help you narrow something down.
Work:· Clemensb@otc.edu
Good Stuff on my Blog: http://theDeadBug.journalspace.com
The chip is the MAXIM ICL7662
I've included the datasheet!
****· Oops, my mistake...this will only convert up to 20V....but look on the 6th page....the doubler circuit!
Vout = 2Vin - 2Vdiode
So, you could put in 12Volts but you would lose across the two diodes (2Vdiode).· Use germanium diodes maybe and you'd lessen the loss to 0.3V each!· Circuit might oscillate at the top of it's range!
Steve
http://ca.geocities.com/steve.brady@rogers.com/index.html
"Inside each and every one of us is our one, true authentic swing. Something we was born with. Something that's ours and ours alone. Something that can't be learned... something that's got to be remembered."
Post Edited (steve_b) : 3/7/2005 6:10:49 PM GMT
Yeah, it would only supply enough power to use for logic IC's requiring low amounts of current.
I have only had experience with one of those charge pumps and that was in a home made smart card reader/writer. i of course was GIVEN the schematic at the time and has been a while since I messed with any of that.
Anything more maybe a simple switch mode through a hand wound toroid transformer. 24Volts would be easy.
And if it didn't need any critical Pulse Width modulation you could simply use a 555 and one mosfet then regulate it somehow.
http://www.paysonarizona.net/
I need 24v DC at just under 3 amps from a 12 car battery..
I was hoping to make a power supply for it but I just might have to buy
a a complete power supply for it.
What do you think.?
Jack
UPDATE:
So I looked around at some DC/DC converting units.
The schematics are not one or two chip solutions.
Two things.
1:
Seems the time and effort to build a "reliable" unit
would surpass the time/cost of just buying a ready made unit.
2:
The unit that needs to be powered cost $8,000.00
I would hate to damage the unit just to save a few bucks
on the power converter.
Unless someone has a simple (safe) idea for building a converter
I will just go buy one.
Thanks for your effort up to now.
Jack
Post Edited (PLJack) : 3/8/2005 3:53:08 PM GMT
Bruce
Tracy Allen
www.emesystems.com
I love simple solutions!
My only concern is that automobile circuits are known to be violent.
They batteries would need to be connected to alternators to charge them.
Also I would need to buy four batteries. Two for the vehicle and two for
bench testing.
I like the idea though, thanks
Jack
