Stepper Motor BS2/sx control — Parallax Forums
ArchiverArchiver Posts: 46,084
edited 2000-08-23 03:12 in General Discussion
Hi Everyone!
I am building an xy table using stepper motors. I currently
have 2 83 oz/in 1.25 amps/phase motors and a driver card
for them that can handle 2.0A per/phase.
I have built my own Unipolar stepper driver cards using
the UCN5804 Driver IC. And the ULN2803. These are great
and easily programmed thru Qbasic.
The reason I bought the Basic stamp BS2/sx was to be able to
store and run the program without having to have a pc and paralell
cable every I go.
My question is; I want to be able to run a big stepper from the
the BS2/sx chip. 1500-2400 oz/in with Amperage ratings from
5-10Amps. What kind of chip or circuit could I build that would
protect my stamp from over current? I really enjoy the programming
side of it and I know enough to get me in trouble on the hardware
side of it.
I appreciate all the help I can get. And Thank you in advance!
  • ArchiverArchiver Posts: 46,084
    edited 2000-08-22 10:11
    Simply use a fet with the correct resistor for each output
    You must make sure the base current does not exceed the Stamps rating .
    Original Message
    To: <basicstamps@egroups.com>
    Sent: Tuesday, August 22, 2000 3:56 PM
    Subject: [noparse][[/noparse]basicstamps] Stepper Motor BS2/sx control
    > Hi Everyone!
    > cable every I go.
    > side of it.
    edited 2000-08-22 21:17
    Russel:
    If your motor is unipolar, it is easy to drive steppers with IRL530N
    mosfets. They are logic level input gate drive, which means they can be
    driven directly from a Stamp.
    on resistance=0.1 ohms.
    n-channel, 15 amp, 100 volts.
    I use a 1k to 10k resistor between the gate and Stamp, 1/16 to 1/8 watt.
    This inhibits mosfet oscillation and provides some protection to the Stamp
    if the mosfet fails. You can get further protection by using 2 clamp diodes
    on the Stamp pin, one to +5v, the other to gnd.
    Good luck,
    Ray McArthur
    Original Message
    Sent: Tuesday, August 22, 2000 1:56 AM
    > side of it.
    edited 2000-08-23 02:30
    Hi Ray:
    I take it the diodes would be between the resistor(i.e. the resistor between
    the stamp and MOSFET) and the MOSFET.
    So, would the banded end of the diode going to 5v would be oriented toward
    the MOSFET, and the banded end of the diode going to ground would be
    oriented toward ground?
    Is there a book or other reference where you found out about the 1 to 10K
    resistor between the MOSFET and the Stamp?
    Mark
    Original Message
    To: basicstamps@egroups.com <basicstamps@egroups.com>
    Date: Tuesday, August 22, 2000 1:13 PM
    Subject: Re: [noparse][[/noparse]basicstamps] Stepper Motor BS2/sx control
    >Russel:
    diodes
    >Good luck,
    >Ray McArthur
    Original Message
    >From: <russell1@p...>
    >> side of it.
    Hi Mark,
    Connect one diode from the Stamp pin to +5V, band to +5. Connect the 2nd
    diode from Stamp pin to gnd, band to Stamp pin. Both diodes would "point"
    up. The idea is that if the mosfet melts down and applies drain voltage
    back to the gate, the diodes would keep the Stamp pin voltage between ~0 and
    ~5 volts until the series resistor burns open circuit.
    > resistor between the Mosfet and the Stamp?
    There is probably discussion of this in app notes by International Rectifier
    or other mosfet vendors. I found out about it in my working days when
    mosfets were new, and we had devices oscillating at 300 MHz!! before
    melting. In high power circuits switching at tens or hundreds of kHz, only
    10 to 100 ohms is used to damp oscillations. For low speed circuits the
    1k-10kohm provides more drive circuit protection. Mosfets have high input
    capacitance, which, in conjunction with operating frequency, determines how
    large the resistor can be.
    Ray McArthur
    Original Message
    Sent: Tuesday, August 22, 2000 9:30 PM
    > Hi Ray:
    between
    > Mark
    Original Message
    > From: rjmca <rjmca@w...>
    > >Russel:
    Stamp
    > diodes
