Shop Learn
Cluso's RetroBlade2 - Your board(s) have arrived, so what to do next — Parallax Forums
Cluso99Cluso99 Posts: 17,669
edited 2021-03-22 22:46 in Propeller 2
This thread is for discussion about how to use your RetroBlade2.
For specs, features, or ordering, please see/use this thread
forums.parallax.com/discussion/172262/clusos-retroblade2-single-chip-computer-first-orders-paid-and-shipped-taking-new-orders-payment/p1
Currently there are two build variants of my board - one has a Flash chip fitted/soldered and the other doesn't. They both use the same pcb. You choose whether or not to fit the VGA connector.
Power Supply
You will need to provide 5V regulated (and GND) to the board. The board has regulators fitted to reduce this to the 3V3 and 1V8 supplies required. This is limited to somewhere over 500mA. Do not expect to be able to highly overclock or push the P2 to its' absolute limits with this board design. Expected normal use should be fine. The regulators and the P2 chip can get quite hot so ensure adequate ventilation around the board.
The board can be powered from one of the following connections, but be careful to only provide one source as they are all wired in parallel - USB header J4, header J1 (with P00-15), header J3 (with P32-47), microUSB J5, and microUSB J6. I power my board from my PC over USB header J4 without problems. You can use a phone power supply as long as it can provide 500mA or more, depending on you use.
microSD
You can boot directly from the microSD card. It (preferably) requires a later SDHC or SDXC microSD card formatted with FAT32. Just copy a P2 binary file to the microSD and name it "_BOOT_P2.BIX" (upper case matters). Then when powering up your board it will load and run this file. Older SD or SDHC cards 4GB and smaller typically use the old byte addressing mode and generally will not be compatible with software drivers for the P2. Newer SDXC cards are often formatted with XFAT and again generally are not compatible with software drivers for the P2, so you will need to reformat these to FAT32.
Flash
You can boot directly from Flash (if fitted). To do so will require a pullup on the CS line. A pullup is provided on the board, together with a link. You will need to solder the provided 1x2 0.050" header pins to the board, and use the provided 0.050" jumper to enable the pullup resistor to boot from Flash.
USB-Serial
The 1x6 pin header (J4) is arranged to be compatible with the cheap fleabay USB-TTL 6pin CP2102 board. See the post below for how I connect my board. (see post #47 for max 921_600 baud)
VGA
The VGA connection is optional. If the optional VGA is supplied mounted to your board, it is not soldered. You can remove it easily by slightly squeezing the mounting lugs with slight pressure removing the VGA connector and it will pop off without damage. Dry fitting the VGA connector makes it for safer posting.
Under the VGA connector is provision for mounting a 1x16 0.1" header for access to P16-31.
  • Cluso99Cluso99 Posts: 17,669
    edited 2020-12-22 16:55
    This is the schematic. Note the mod (in red) required for the Flash as not all Flash chips have internal pullups on the WP and HOLD lines.
    These are the jumpers that may be required to make your board work.
    Red = jumper to enable booting from Flash (if fitted)
    Green = jumper to enable the onboard transistor reset circuit
    Blue = jumper to bypass the the onboard transistor reset circuit (eg when using a PropPlug)
    USB-Serial
    This is my suggestion for connecting to your PC using the USB-Serial 6pin CP2102 (USB-A full size) converter...
    USB-serial board
    https://ebay.com/itm/6Pin-USB-2-0-to-TTL-UART-Module-Serial-Converter-CP2102-STC-Replace-Ft232-Module/401092508083?hash=item5d62f9f9b3:g:2aQAAOSw0kNXhzR7
    * Remove the 6pin male header by removing one pin at a time. ie heat a pin and remove with pliers. The heated pin will slide out of the plastic surrounds.
    * Using my provided 1x6 pin female header with extended male pins
    o Remove the plastic spacer under the female plastic - easy as it slides off (keep this for later)
    * now solder the female header onto the USB-serial board with female on the top. Careful when soldering to only solder right at the pcb as you do not want solder wicking up the pins.
    * now slip the spacer over the pins (saved above) half way up the pins. This provides support for the pins, although not absolutely necessary.
    RetroBlade2
    * fit the transistor reset enable link (wire) on your RetroBlade2 (shown in green)
    * solder the provided 1x6 female header (normal short pins) to your RetroBlade2
    1267 x 865 - 318K
    573 x 442 - 70K
    756 x 1008 - 203K
    942 x 744 - 270K
    reserved
    reserved
    edited 2020-12-15 01:29
    Cluso's P2 OS
    Here is my P2 OS in its' current state of development. Its' definately not ready for prime time but you can give it a go. Don't bother reporting bugs as it's nowhere near this stage yet.
    Compile and download with
    f2 os228c
    DIR, VER, HELP and a few others.
    Cluso's Z80/CPM emulation
    Again. not ready for prime time. Unzip and copy the files from the cpm-2020-12-15.zip to the microSD card (formatted as FAT32).
    Then download the compiled binary with
    L2 Z055D
    MBASIC is on E: so do this after downloading (use caps lock on your keyboard)
    C:\P2\_RetroBlade2\ClusoZ80>L2 Z055D
    C:\P2\_RetroBlade2\ClusoZ80>l500 Z055D.binary -b115200 -t -SINGLE
    ( Entering terminal mode. Press Ctrl-] to exit. )
    Auto Detected P2EVAL
    Cluso's P2 Z80 Emulation: Experimental v055?
    Z80 & CPM cog= 0
    SD Driver cog= 1
    Initialise
    Find Directory
    Find file(s)
    A: ZICOG_A2.DSK sector 00010180 size 00800000
    B: ZICOG_B .DSK sector 00014180 size 00800000
    C: ZICOG_C .DSK sector 00018180 size 02000000
    D: ZICOG_D .DSK sector 00028180 size 00800000
    E: DRAC_A .DSK sector 00008180 size 00800000
    F: DRAC_B .DSK sector 0000C180 size 00800000
    G: ZICOG_G .DSK sector 00034180 size 00100000
    H: ZICOG_H .DSK sector 00034980 size 00100000
    Z: BOOTHDSK.ROM sector 00039200 size 00000400
    Loading file BOOTDSK.ROM
    Starting Z80 & CPM
    PC B C D E H L A F R R2 IF SP alu ea OpCode(s)
    64K CP/M Version 2.2 (ZiCog, BIOS V1.27_Zi04, 8 HD, 10-Sep-2009)
    A>E:
    E>MBASIC
    BASIC-80 Rev. 5.21
    [CP/M Version]
    Copyright 1977-1981 (C) by Microsoft
    Created: 28-Jul-81
    32824 Bytes free
    Ok
    10 A=3
    20 B=4
    30 C=A*B
    40 PRINT C
    LIST
    10 A=3
    20 B=4
    30 C=A*B
    40 PRINT C
    Ok
    RUN
    12
    Ok
    SAVE "ZOOM.BAS"
    Ok
    10 A=11
    LIST
    10 A=11
    20 B=4
    30 C=A*B
    40 PRINT C
    Ok
    LOAD "ZOOM.BAS"
    Ok
    LIST
    10 A=3
    20 B=4
    30 C=A*B
    40 PRINT C
    Ok
    SYSTEM
    E>
    Has anyone had a chance to try anything out yet?
    FYI
    Discovered this morning that pnut35b is not finding and/or properly downloading/running to the RetroBlade with USB-Serial CP2102 and transistor reset enabled. It's under investigation. Flexprop/loadp2 v5.0.2 is working just fine.
  • I had a similar problem using pnut35b with a P2 Edge and a Prop Plug. FlexProp worked fine, and Prop Tool 2.4 work also. I downloaded using pnut35b the first few times, but it quit working after that. It wasn't able to find a P2.
  • hinvhinv Posts: 1,033
    Cluso99 wrote: »
    And we're away :sunglasses:
    Into the ROM Monitor and TAQOZ. Wow this is so useful to just test for life!
    I finally got my serial2USB boards in on the slow boat from China, but I can't seem to get either to work.
    I used to be able to talk to it with just SO SI 5V and GND from anther usb2serial adapter, and didn't provide any connection to RST. I used minicom -D /dev/ttyUSB0 and just did ">"<space><esc> sequence to get it to autobaud and go into TAQOZ. Is there something I have to do different now that I have the correct adapter?
    edited 2021-01-12 17:51
    BTW, the new usb2serial adapters do show up in lsusb and minicom seems happy connecting to ttyUSB0 when they are connected, but no talkie.
    Without DTR being connected to RST (and the transistor reset link soldered) the USB driver in the PC seems to eventually lockup requiring a reboot of the PC. I don’t know what the pc software does but it just seems to happen every so often if there isn’t a reliable reset to the P2. I’ve also seen this happen with P1 on occasion too.
    Doesn’t seem to happen using flexprop and loadp2 using the cheapie CP2102 USB with the transistor reset enabled.
    I actually haven't soldered anything on the RetroBlade yet. I'm just holding my pins in tension against the side of the holes with a broccoli rubber band.
    Cluso99 wrote: »
    I haven't had a problem with having to reboot my laptop (I run a variant of debian), but I have had to pull the usb and plug it in again. It works pretty good all the way up to 4m baud on the current board I use, which shows up as:
    Bus 003 Device 041: ID 1a86:7523 QinHeng Electronics HL-340 USB-Serial adapter
    Note, I provide power through this adapter as well, which works well as it is. Though I haven't played with SPI flash or microSD yet. I'm learning TAQOZ and the monitor, so powering the board through the serial module works pretty good. This might be my problem with the cp2102 boards you suggested. Maybe they don't provide enough power.
    I power my boards using the 5V from the CP2102 without problems, but of course this is dependant on the pc being able to supply this.
  • RamonRamon Posts: 466
    Hello!
    STEP 1) Solder 1x6 (0.1") female header for CP2102 USB<>TTL converter
    COMMENT: This header seems lower height than common ones. The CP2102 seems to move once plugged in.
    STEP 2) Press fit 1x2 (0.05") male pin header with jumper on 'Q' position
    COMMENT: I was wondering why was not a 1x3 male pin header included instead. And later found that PCB footprint is different. It doesn't fit. So instead of soldering jumper I did mechanical press fit.
    STEP 3) Connect USB<>TTL converter and open terminal (minicom -D /dev/ttyUSB0)
    STEP 4) Press the following keys: '>', then (space), and then (ESC)
    Cold start
      Parallax P2  .:.:--TAQOZ--:.:.  V1.1--v33h         190219-1900
    !!! GREAT, THANK YOU ALL !!!
    STEP 5) WORDS, reset, help (ok, no help)
    TAQOZ# WORDS ---
    DUP OVER SWAP ROT -ROT DROP 3RD 4TH 2DROP 3DROP NIP 2SWAP 2DUP ?DUP AND
    ANDN OR XOR ROL ROR >> << SAR 2/ 2* 4/ 4* 8<< 16>> 8>> 9<< 9>> REV |< >|
    >N >B >9 BITS NOT = <> 0= 0<> 0< < U< > U> <= => WITHIN DUPC@ C@ W@ @ C+!
    C! C@++ W+! W! +! ! BIT! SET CLR SET? 1+ 1- 2+ 2- 4+ + - UM* * W* / U/
    U// // */ UM// C++ C-- W++ W-- ++ -- RND GETRND SQRT SETDACS ~ ~~ W~ W~~
    C~ C~~ L>S >W L>W W>B W>L B>W B>L MINS MAXS MIN MAX ABS -NEGATE ?NEGATE
    NEGATE ON TRUE -1 FALSE OFF GOTO IF ELSE THEN BEGIN UNTIL AGAIN WHILE REPEAT
    SWITCH CASE@ CASE= CASE> BREAK CASE ADO DO LOOP +LOOP FOR NEXT ?NEXT I
    J LEAVE IC@ I+ BOUNDS H L T F R HIGH LOW FLOAT PIN@ WRPIN WXPIN WYPIN RDPIN
    RQPIN AKPIN WAITPIN WRACK PIN @PIN ns PW PULSE PULSES HILO DUTY NCO HZ
    KHZ MHZ MUTE BLINK PWM SAW BIT BAUD TXD RXD TXDAT WAITX WAITCNT REBOOT
    RESET 0EXIT EXIT NOP CALL JUMP >R R> >L L> !SP DEPTH COG@ COG! LUT@ LUT!
    COGID COGINIT COGSTOP NEWCOG COGATN POLLATN SETEDG POLLEDG KEY WKEY KEY!
    CON NONE COM CONKEY CONEMIT SEROUT EMIT EMITS CRLF CR CLS SPACE SPACES
    RAM DUMP: DUMP DUMPW DUMPL DUMPA DUMPAW QD QW DEBUG lsio COG LUT KB MB
    M . PRINT .AS .AS" .DECL .DEC4 HOLD #> <# # #S <D> U. .DEC .BIN .H .B .BYTE
    .W .WORD .L .LONG .ADDR PRINT$ LEN$ " ." CTYPE ?EXIT DATA? ERASE FILL CMOVE
    <CMOVE s ms us CNT@ LAP LAP@ .LAP .ms HEX DEC BIN .S WORDS @WORDS GET$
    SEARCH $># @DATA HERE @HERE @CODES uemit ukey char delim names TASK REG
    @WORD SPIN | || , [W] ["] NULL$ $! $= ASM FORGET CREATE$ CREATE VAR pub
    pri pre : ; [ ] ' := ==! ALIGN DATCON ALLOT org bytes words longs byte
    word long res [C] GRAB NFA' CPA CFA \ --- ( { } IFNDEF IFDEF TAQOZ TERM
    AUTO SPIRD SPIRDL SPIWB SPICE SPIWC SPIWW SPIWM SPIWL SPIPINS SPIRX SPITXE
    SPITX WAIT CLKDIV RCSLOW HUBSET WP WE CLKHZ ERROR SFPINS SF? SFWE SFINS
    SFWD SFSID SFJID SFER4 SFER32 SFER64 SFERASE SFWRPG BACKUP RESTORE SFRDS
    SFWRS SFC@ SFW@ SF@ SF .SF SDBUF sdpins MOUNT DIR !SD !SX SD? CMD ACMD
    cid SDWR SDRDS SDWRS FLUSH FOPEN FLOAD FGET FREAD FWRITE SECTOR SDRD SDRDS
    SDADR SD@ SD! SDC@ SDC! SDW@ SD @FAT @BOOT @ROOT fat END  432 ok
    TAQOZ# reset ---
    TAQOZ# help ???  ---  ok
    TAQOZ#
    STEP 6) Take a MicroSD card and extract 'OS228c-2020-12-15A.zip' into it. Then plug SD card and see what happens:
    Uh! Nothing happened.
    STEP 7) OK. lets see what TAQOZ says about SD:
    FAT32 (FROM FACTORY)
    TAQOZ# dir --- 'PHSD16G 011B_2426 NO NAME    32k 14,764M
    B2      .    $FFC0_3F80   2107.15.31.31.63   4,294,967,295
     _ C H A. R  $0B80_3F80   1980.03.16.00.03   7,209,065
    _CHARD~1.SPI $0000_4040   2020.05.16.12.13   802
    A_ F A T. 3  $1C00_3F80   1980.03.14.00.03   50
    _FAT32~1.SPI $0000_4080   2020.11.28.10.57   94,366
    _HELP2  .TXT $0000_4140   2020.11.10.08.57   2,064
     _ H U B. D  $0B80_3F80   1980.03.16.00.03   7,209,065
    _HUBDE~1.SPI $0000_4180   2020.05.18.12.52   4,134
     _ S D _. C  $0B80_3F80   1980.03.16.00.03   7,209,065
    _SD_CO~1.SPI $0000_41C0   2020.05.23.11.32   52,296
    A_ S D _. E  $1CC0_3F80   1980.03.09.00.03   3,276,910
    _SD_EQ~1.SPI $0000_4240   2020.05.24.01.41   4,633
     _ S T D. _  $0B80_3F80   1980.03.16.00.03   7,209,065
    _STD_I~1.SPI $0000_4280   2020.11.28.08.37   6,148
     _ S t r. i  $0B80_3F80   1980.03.16.00.03   7,209,065
    _STRIN~1.SPI $0000_42C0   2020.05.18.12.51   29,050
    Af 2 . b. a  $FFC0_3F80   2107.15.31.31.63   4,294,967,295
    F2      .BAT $0000_4300   2020.11.10.07.16   70
    Af 5 0 0. .  $0000_3F80   2107.15.31.31.63   4,294,967,295
    F500    .EXE $0000_4340   2020.11.05.00.50   2,994,136
    Bs e r i. a  $1C00_3F80   1980.03.14.00.03   50
     j m _ f. u  $1D40_3F80   1980.03.12.00.03   7,864,421
    JM_FUL~1.SPI $0000_5A40   2020.11.17.05.18   21,324
    Aj m _ n. s  $1CC0_3F80   1980.03.09.00.03   3,276,910
    JM_NST~1.SPI $0000_5A80   2020.08.28.02.22   9,190
    AL 5 0 0. .  $0000_3F80   2107.15.31.31.63   4,294,967,295
    L500
    Doesn't seems good.
    STEP 8) OK. lets format with FAT32, and try again.
    NO BOOT, again.
    What TAQOZ says:
    FAT32 (from LINUX)
    TAQOZ# DIR --- 'PHSD16G 4302_0A50 P2_16G     8k 14,767M
    P2_16G       $0000_7B42   2021.01.16.13.05   0
    B2      .    $FFF0_7B42   2107.15.31.31.63   4,294,967,295
     _ C H A. R  $02E0_7B42   1980.03.16.00.03   7,209,065
    _CHARD~1.SPI $0000_7B72   2020.05.16.12.13   802
    A_ F A T. 3  $0700_7B42   1980.03.14.00.03   50
    _FAT32~1.SPI $0000_7B82   2020.11.28.10.57   94,366
    _HELP2  .TXT $0000_7C42   2020.11.10.08.57   2,064
     _ H U B. D  $02E0_7B42   1980.03.16.00.03   7,209,065
    _HUBDE~1.SPI $0000_7C52   2020.05.18.12.52   4,134
     _ S D _. C  $02E0_7B42   1980.03.16.00.03   7,209,065
    _SD_CO~1.SPI $0000_7C62   2020.05.23.11.32   52,296
    A_ S D _. E  $0730_7B42   1980.03.09.00.03   3,276,910
    _SD_EQ~1.SPI $0000_7CD2   2020.05.24.01.41   4,633
     _ S T D. _  $02E0_7B42   1980.03.16.00.03   7,209,065
    _STD_I~1.SPI $0000_7CE2   2020.11.28.08.37   6,148
     _ S t r. i  $02E0_7B42   1980.03.16.00.03   7,209,065
    _STRIN~1.SPI $0000_7CF2   2020.05.18.12.51   29,050
    Af 2 . b. a  $FFF0_7B42   2107.15.31.31.63   4,294,967,295
    F2      .BAT $0000_7D32   2020.11.10.07.16   70
    Af 5 0 0. .  $0000_7B42   2107.15.31.31.63   4,294,967,295
    F500    .EXE $0000_7D42   2020.11.05.00.50   2,994,136
    Bs e r i. a  $0700_7B42   1980.03.14.00.03   50
     j m _ f. u  $0750_7B42   1980.03.12.00.03   7,864,421
    JM_FUL~1.SPI $0000_9422   2020.11.17.05.18   21,324
    Aj m _ n. s  $0730_7B42   1980.03.09.00.03   3,276,910
    JM_NST~1.SPI $0000_9452   2020.08.28.02.22   9,190
    AL 5 0 0. .  $0000_7B42   2107.15.31.31.63   4,294,967,295
    L500    .EXE $0000_9472   2020.11.05.00.50   801,128
    Ao s 2 2. 8  $0690_7B42   1980.03.01.00.03   7,929,970
    OS228C~1.BIN $0000_9A92   2020.12.15.03.45   64,980
    Ao s 2 2. 8  $0730_7B42   1980.00.00.00.03   4,294,967,295
    OS228C  .LST $0000_9B12   2020.12.15.03.45   926,533
    Ao s 2 2. 8  $0320_7B42   1980.03.19.00.03   109
    OS228C~1.P2A $0000_A232   2020.12.15.03.45   487,757
    AO S 2 2. 8  $0700_7B42   1980.03.14.00.03   50
    OS228C~1.SPI $0000_A5F2   2020.11.28.11.00   86,627
     ok
    TAQOZ#
    STEP 9) OK. Lets try again a format with Windows10 in FAT32, and check again: NO BOOT.
    What TAQOZ says?
    FAT32 (from Win 10)
    TAQOZ# DIR --- 'PHSD16G A617_D738 NO NAME    8k 14,767M
    P2_16G       $0000_87E0   2021.01.16.13.11   0
    B  I n f. o  $0740_87E0   1980.03.15.00.03   110
     S y s t. e  $06F0_87E0   1980.03.21.00.03   6,619,245
    SYSTEM~1     $0000_8810   2021.01.16.13.11   0
    B2      .    $FFF0_87E0   2107.15.31.31.63   4,294,967,295
     _ C H A. R  $02E0_87E0   1980.03.16.00.03   7,209,065
    _CHARD~1.SPI $0000_8840   2020.05.16.12.13   802
    A_ F A T. 3  $0700_87E0   1980.03.14.00.03   50
    _FAT32~1.SPI $0000_8850   2020.11.28.10.57   94,366
    _HELP2  .TXT $0000_8910   2020.11.10.08.57   2,064
     _ H U B. D  $02E0_87E0   1980.03.16.00.03   7,209,065
    _HUBDE~1.SPI $0000_8920   2020.05.18.12.52   4,134
     _ S D _. C  $02E0_87E0   1980.03.16.00.03   7,209,065
    _SD_CO~1.SPI $0000_8930   2020.05.23.11.32   52,296
    A_ S D _. E  $0730_87E0   1980.03.09.00.03   3,276,910
    _SD_EQ~1.SPI $0000_89A0   2020.05.24.01.41   4,633
     _ S T D. _  $02E0_87E0   1980.03.16.00.03   7,209,065
    _STD_I~1.SPI $0000_89B0   2020.11.28.08.37   6,148
     _ S t r. i  $02E0_87E0   1980.03.16.00.03   7,209,065
    _STRIN~1.SPI $0000_89C0   2020.05.18.12.51   29,050
    F2      .BAT $0000_8A00   2020.11.10.07.16   70
    F500    .EXE $0000_8A10   2020.11.05.00.50   2,994,136
    Bs e r i. a  $0700_87E0   1980.03.14.00.03   50
     j m _ f. u  $0750_87E0   1980.03.12.00.03   7,864,421
    JM_FUL~1.SPI $0000_A0F0   2020.11.17.05.18   21,324
    Aj m _ n. s  $0730_87E0   1980.03.09.00.03   3,276,910
    JM_NST~1.SPI $0000_A120   2020.08.28.02.22   9,190
    L500    .EXE $0000_A140   2020.11.05.00.50   801,128
    Ao s 2 2. 8  $0690_87E0   1980.03.01.00.03   7,929,970
    OS228C~1.BIN $0000_A760   2020.12.15.03.45   64,980
    OS228C  .LST $0000_A7E0   2020.12.15.03.45   926,533
    Ao s 2 2. 8  $0320_87E0   1980.03.19.00.03   109
    OS228C~1.P2A $0000_AF00   2020.12.15.03.45   487,757
    AO S 2 2. 8  $0700_87E0   1980.03.14.00.03   50
    OS228C~1.SPI $0000_B2C0   2020.11.28.11.00   86,627
     ok
    TAQOZ#
    What TAQOZ says about SD Card:
    TAQOZ# .DISK ??? DISK ???  ---  ok
    TAQOZ#  ---  ok
    TAQOZ# DISK ???  ---  ok
    TAQOZ# SD? ---  ok
    TAQOZ#  ---  ok
    What does my PC says?
    ramon@pc /media/ramon $ md5sum /media/ramon/P2_16G/*
    783b6e23802d8ac38318c930860900fd  /media/ramon/P2_16G/_CHARDEF.spin2
    f58b6cc8af9648f7e98a75c2120f3530  /media/ramon/P2_16G/f2.bat
    c808803ce9bb8532af524676148260fa  /media/ramon/P2_16G/f500.exe
    c2230ea4d0e2898b6c537c263f06be7a  /media/ramon/P2_16G/_FAT32.spin2
    3098302fd1cfcdefe8196cb896e54f67  /media/ramon/P2_16G/_HELP2.TXT
    b12dd552dccaedfd45b349f274991cd8  /media/ramon/P2_16G/_HUBDEF2.spin2
    9a099fd250db49d3034840af7b7d4514  /media/ramon/P2_16G/jm_fullduplexserial.spin2
    cf7fd71f9af6007c4725b029c138bf4a  /media/ramon/P2_16G/jm_nstr.spin2
    63862ddc2602d3d346206be1f1af2c8c  /media/ramon/P2_16G/L500.exe
    7492ee076a3684a41fbbf3891bfa3b99  /media/ramon/P2_16G/os228c.binary
    fa3fc76690559d348b767821c8da18c4  /media/ramon/P2_16G/os228c.lst
    35ac9afd5464955dbf6ba251169ee9cd  /media/ramon/P2_16G/os228c.p2asm
    0e37357e59e767090f3adea069778fee  /media/ramon/P2_16G/OS228c.spin2
    f4133dd101f86cb7d78381ca2707649b  /media/ramon/P2_16G/_SD_Code.spin2
    efc222bbcc409ccabcf5921a9b9f9f06  /media/ramon/P2_16G/_SD_Equ.spin2
    64fbddabed265600def19a4385184210  /media/ramon/P2_16G/_STD_IOj.spin2
    b3d2d4cce8b5442a9af7e5bdec94d9ee  /media/ramon/P2_16G/_StringE.spin2
    Ramon wrote: »
    Hello!
    Yes it does move. When you plug in a USB female lead into it it gets supported on the VGA. You can always solder the USB board into the RetroBlade if you want a permanent solution.
    No. The 2x1 0.050" header plus shunt is for the Flash enable. When I originally designed the pcb I did not have space for the transistor reset jumpers to be 1x3 at 0.050" pitch. It was meant to be a permanent link because users are not likely to switch between a PropPlug and a CP2102 USB dongle. Later I widened the board but I didn't think to make the header suit 0.050".
    Cold start
    TAQOZ# WORDS ---
    TAQOZ# reset ---
    TAQOZ#
    There is a TAQOZ thread for using TAQOZ.
    You need to format (if not already formatted) the SD Card as FAT32 with 32KB clusters before copying any files. Peter says there is a problem with windoze formatting the cards correctly but I have not seen a problem. However, your card must use sector addressing which means that it should be at least 4GB (not a guarantee tho), BUT, if your card is more than 16GB it is likely formatted as exFAT and this does not work so you will have to reformat it as FAT32 and 32KB clusters.
    However, from the TAQOZ dumps below, you haven't either...
    1. Compiled and downloaded the code to your RetroBlade2 to run it.
    2. Copied the binary to the SD as "_BOOT_P2.BIX". If you don't have this file (or "_BOOT_P2.BIY") in the root directory, nothing is going to run! These are the only two files that the P2 ROM will boot from. See the P2 ROM thread for more details.
    forums.parallax.com/discussion/170637/p2-sd-boot-code-rev-2-silicon
    L500
    Doesn't seems good.
    NO BOOT, again.
    What TAQOZ says:
    FAT32 (from LINUX)
     ok
    TAQOZ#
    What TAQOZ says?
    FAT32 (from Win 10)
     ok
    TAQOZ#
    TAQOZ#  ---  ok
    TAQOZ# SD? ---  ok
    TAQOZ#  ---  ok
    I think this board is really nice. I have both Propeller Plug and CP2102. Obviously I don't want to use them at the same time, but it would be great if I can test them both. My suggestion is to change the transistor reset jumpers footprint to 1x3 0.05" (or 0.1" if space allow it); AND ship the Retroblade2 with both 1x3 0.050" male pins and 1x6 female header (J4) already soldered. Both items are required to start using the board and the VGA connector is already taller than both of them.
    About your P2 OS:
    Why everybody needs to compile the code?
    I guess that 'f2 os228c' will not work as expected if my system is running a system that is not Windows, right?
    Isn't it easier that you just provide the '_BOOT_P2.BIX' binary file inside the .ZIP file?
    When I look inside F2.bat I have this feeling that it just removes the os228c.binary file (that is already included!) and compiles it again. Can I just rename 'os228c.binary' to '_BOOT_P2.BIX' ?
    (Card is a MicroSDHC Kingston Canvas Select Plus 16GB [Google: "SDCS2/16GB"] that was already factory formatted as FAT32, but with 8Kb cluster size)
    edited 2021-01-16 09:59
    Ramon wrote: »
    If I do an update to the pcb (not expected any time soon tho) then I will change the header to 0.050" pitch and include 1x3 header and shunt.
    I do not intend to hand solder any pins or connectors - that is up to the user. I could do it as a special for a price.
    Some users may choose not to solder the 1x6 header, or even solder a male instead.
    BTW I check the board by holding the CP2102 in the holes in the RetroBlade2 with one hand while typing etc with the other hand. It works for fully testing all I/O header pins around the pcb amongst other checks.
    About your P2 OS:
    No. You take whatever binary you want and copy it, rename the copy "_BOOT_P2.BIX" and copy to the SD. You can use the OS, or the Z80 or anything else. it is totally up to you. That is why I provided the binaries.
    Yes. That is the intention. My F2.bat deliberately deletes the binay before compilation. This way, if there is an error in compilation there will not be a binary present.
    [/quote]
    Many of us prefer to use SanDisk SD cards as they have proven reliable compared to a lot of other cards. Having said that, I haven't actually found a card that didn't work. It is preferable to have the card formatted with a cluster size of (at least) 32KB. Unless the card becomes fragmented then it doesn't really matter what the cluster size is. But some programs (including the boot ROM) take the view that the binary it is going to load is contiguous (ie not fragmented) and no checks are performed.
    I made many test and finally downloaded the sd card formatter (v5.0.1) to format the card to FAT32.
    The software formatted the card to 32Kb cluster size (GUI did not allowed me to change the cluster size, maybe there is some option on the CLI. Didn't read the manual).
    Finally found that the error was that I used "BOOT_P2.BIX" instead of "_BOOT_P2.BIX" (as written on forums.parallax.com/discussion/170637/p2-sd-boot-code-rev-2-silicon)
    SD:>P2-SDDriver x221
    *** Cluso's Propeller 2 Operating System OS228x ***
    SD:>help
    *** Cluso's Propeller 2 Operating System v.228? ***               (10 Nov 2020)
    ===Not everything implemented/debugged at this time===
    clear                                         ' Clear screen
    copy    <source_file> <destination_file>      ' Copy a file
    del     <file>                                ' Delete a file
    diff    <file1> <file2>                       ' Display file differences
    dir     [mask]                                ' Display directory of files
    free                                          ' Display FAT32 used/free space
    help                                          ' Display this help info
    lf                                            ' Toggles LF on/off
    ls      [mask] [A]                            ' Display directory of files
    reboot                                        ' Reboot the Propeller Chip
    ren     <source_file> <destination_file>      ' Rename a file
    rsector <sectornum>                           ' Read and display sector#
    run     <file>                                ' Runs binary .BIX file (repl.OS)
    testsd                                        ' Tests SD card (writes to SD)
    type    <file> [-Hn]                          ' Display the contents of a file
    used                                          ' Display FAT32 used/free space
    ver                                           ' Display info about PropOS
    dircpm  <cpm_disk>                            ' Display directory of CPM files
    cpm2fat <cpm_disk> <cpm_file> <fat_file> -T/B ' Copy CPM file to FAT32
    fat2cpm <fat_file> <cpm_disk> <cpm_file>      ' Copy FAT32 file to CPM
    fat2pc  <fat_file>                            ' Copy FAT32 file to PC
    pc2fat  <fat_file>                            ' Copy PC file to FAT32
    SD:>ver
     Originally derived from KyeDOS...
         by Kwabena W. Agyeman & J. Moxham & Cluso99
         & acknowledgements to M. Park (Sphinx) etc
     ClockFreq 000000000Hz, ClockMode $00000000, Cog 0
     SD card on pins 60,61,59,58
     Serial  on pins 63,62, Mode 00, Baud 00115200, Cog 0
     Screen size: 080 x 025
     <LF> is ON
     Resident Cogs :     This Cog: 0
     Cogs available: --234567(=6)
    SD:>DIR
    F2      .BAT     F500    .EXE     JM_FUL~1.SPI     JM_NST~1.SPI     L500    .EXE
    OS228C  .LST     OS228C~1.BIN     OS228C~1.P2A     OS228C~1.SPI     SYSTEM~1.
    _BOOT_P2.BIX     _CHARD~1.SPI     _FAT32~1.SPI     _HELP2  .TXT     _HUBDE~1.SPI
    _SD_CO~1.SPI     _SD_EQ~1.SPI     _STD_I~1.SPI     _STRIN~1.SPI
    SD:>reboot
    Command not found, try help
    :smile:
    @Ramon,
    Pleased you have it sorted :smiley:
    Thank you! Is there any interactive assembler/dissasembler/debugger available for P2?
    I am thinking about something similar to MS-DOS debug.
    I need a quick tutorial (reference, or cheatsheet). Something like this -> https://montcs.bloomu.edu/Information/LowLevel/DOS-Debug.html
    Currently a big issue is having to extract the SD card to copy some files from my computer and insert the card again on Retroblade to execute them.
    I have found a way to be able to boot multiple files without the need to rename them to '_BOOT_P2.BIX'.
    STEP 1) I load first into TAQOZ and show current directory:
    Press '>', then (space), then (esc)
    TAQOZ# DIR --- 'PHSD16G 539E_634B P2_16G     32k 14,764M
    P2_16G       $0000_3F80   1980.00.00.00.00   0
    F2      .BAT $0000_4380   2020.11.10.07.16   70
    F500    .EXE $0000_43C0   2020.11.05.00.50   2,994,136
    L500    .EXE $0000_5B40   2020.11.05.00.50   801,128
    OS228C~1.BIN $0000_6180   2020.12.15.03.45   64,980
     BOOT_P2.BIX $0000_6DC0   2020.12.15.03.45   64,980
     o s 2 2. 8  $0800_3F80   1980.03.15.00.02   7,929,968
     S228C~2.BIN $0000_6DC0   2020.12.15.03.45   64,980
     OOT_P2 .BIX $0000_6DC0   2020.12.15.03.45   64,980
     ok
    TAQOZ#
    STEP 2) Jump to P2-Monitor (Load file and Run)
    (on TAQOZ#) Press Ctrl-D.
    NOTE: for some unknown reason I am not able to LOAD file 'BOOT_P2.BIX' but I can load 'OS228C~1.BIN'
    TAQOZ#  ---  ok
    P2-MONITOR V1.3
    *help
    *L BOOT_P2.BIX
    *L_BOOT_P2.BIX
    *LOS228C~1.BIN
    *ROS228C~1.BIN
    P2-SDDriver x221
    SD:>
    Summary of used commands:
    Lfilename.xxx<cr>              LOAD:      Load file from SD   (8.3 filename)
                                                 returns "=" on success, "!" on failure
    Rfilename.xxx<cr>              RUN:       Run  file from SD   (8.3 filename)
                                                 returns "!" on failure
    <esc><cr>                      TAQOZ:     goto TAQOZ
    More info about P2-MONITOR commands here : http://forums.parallax.com/discussion/170638/p2-rom-monitor-debugger-rev-1-rev-2-silicon#latest
    NOTE 1: I wonder if there is any way to easily transfer files from HOST computer to TAQOZ or P2-MONITOR (I am thinking about something similar to Kermit, ZMODEM, XMODEM, YMODEM, ...)
    NOTE 2: Cluso OS228 'reboot' command is not working, and retroblade2 doesn't have reset button so It forces me to unplug USB cable and reconnect again.
    Is there any other way to reset/reboot?
    edited 2021-01-16 12:58
    I am on my iPad so answers a little harder.
    You can go straight to the monitor rather than via TAQOZ with “>” <space> Ctl-D.
    You’re missing the first underscore in “R_BOOT_P2.BIX”
    Once I get the OS working properly there will be a method to send a file from the pc to (and from) the sd in the P2. I still have many problems with the OS because the compilers cannot place code in hub at specific addresses when using spin2.
    I believe that FlexProp has SD drivers that might be able to transfer files but I haven’t had time to look into it.
    You can connect a reset switch across the reset line. I’ll look at it in the next day or so.
    No. REBOOT is not implemented yet. Until I can get the compilers to work with letting parts stay resident in cog and hub a lot of commands are not working.
    It is better to use file names with 8+3 characters rather than use the shortened 8+3 file name for long file names (the ones with “~” in the file name.
    Don't worry I am already busy with my new toy :smile:
    I didn't missed the underscore. If you look again, you will see that before Run command, the Load command (with underscore) failed (!). No big issue as the long name file can load and run.
    Yes, I know some functions are already not implemented. I can wait. I will follow progress. It seems a nice OS.
    Also, I have found a new TAQOZ file on the other thread (http://forums.parallax.com/discussion/comment/1509204/#Comment_1509204) and this one allowed me to see the SD Card .DISK information. It has many WORDS added into it, so maybe it could even have some way to transfer files already. (but It's a pity that the embedded P2 TAQOZ ROM doesn't work.)
    There were restrictions on what could go into TAQOZ, the Monitor/Debugger, and the SD booster because the 16KB ROM was full.
    edited 2021-01-16 17:13
    FWIW P2 binary files should be stored on SD as .BIX so as not to be confused with .BIN files which are/were used for P1.
    You can reset the RetroBlade2 from the terminal program on the pc by toggling DTR. I use PST (Parallax Serial Terminal) and toggle DTR to reset the board.
    You can also connect a reset switch (momentary) between GND and JP2-1 (pin 1 square pad of the 3pin reset connection = the bypass transistor side = transistor collector = P2 RST pin).
  • dgatelydgately Posts: 1,443
    edited 2021-03-03 21:12
    Running either PropellerTool 2.5.1 or PNut v35g, on RetroBlade2 versus a P2EV Rev C, DEBUG does not work on the RetroBlade2. Shouldn't the result be the same?
    Here are examples of executing DEBUG_PLOT_HubRAM.spin2 (from the PNut samples):
    P2EV:
    RetroBlade2:
    dgately
    @dgately
    Your results should be the same.
    Looks like the serial speed (baud) is incorrect. Wonder if it is related to reset timing in pnut/PropTool ???
    I've noted for some time that pnut (and probably PropTool) has incorrect timing often resulting in pnut not finding my board. I've asked Chip to change it but he hasn't. Not sure this part is related tho.
    The one thing that is different on my RetroBlade2 is that I don't use a real propplug and I use the transistor reset on my board. The P2EVAL does not invert the DTR reset using the transistor circuit. Are you using a real propplug or the cheapie CP2102? If CP2102 I wonder if the baud Chip uses is too high and needs to be lowered?
    @Cluso99 said:
    @dgately
    I'm using a CP2102:
    Same as I use. I haven't tried Chips debugger. I'll get to it shortly and see if I can find out why this doesn't work.
  • I'm having the same issue with my CP2102.
    I can only run up to 921600 baud and then things get flaky.
    IIRC debug runs at 2M baud so we fall short of that target speed.
    It's not a cable issue either because the same cable runs fine at 3M
    on my FTDI boards.
    I had to modify the timing of one of my loaders to get CP2102 to work as their
    seems to be a delay in the receive buffer handling, but reset timing remains unchanged.
    A few years back I had issues using CP2102 with P1 which limited reliable loading
    to 16K. :(
