No 3.3V regulators on hand, can I
frank freedman
Problem with a prop mini I think, but need to test with another prop to be sure. so went to build up a prop on the 4 row breadboard and can't find a 3.3v regulator. Here somewhere....
So, I linked 3 diodes series for an output of 3.34V. If the drop across the diodes will always stay at 1.7v, does this seem like a reasonable solutionto run the prop? As a side question, if the former is reasonable, if my board is full of 5V ADCs, DACs, sensors and logic, would this be a lower cost way to power just the prop and its EEProm instead of having another three terminal regulator?
Thx
Thx
EDIT: LCSC have LDO regs at 50 for 89 cents.
I am a little closer but I agree though they certainly not in the components business.
Jim
