MikroE Clicks; are there additional Click boards for which you'd like Spin2 support? — Parallax Forums
Hello,
You're eating these Click boards like holiday crackers, cheese and salami.
These are the ones we stock: https://www.parallax.com/product-category/propeller-2/click-boards/
This is the whole selection from MikroE: https://www.mikroe.com/click
I'm happy to stock more of them. Are there additional Click boards you'd like to consume? You know the drill: if we stock them, we'll produce code for them.
  • RaymanRayman Posts: 13,918
    There is an amazing amount of different Click boards...
    I was looking for a 9DOF IMU, but there's so many options!
    Think I saw a 13DOF sensor, not even sure what that is...
    I went looking for a single chip 9DOF Click, but didn't see one...
    Can you make your own? I'd maybe make a lsm9ds1 based Click board.
    Or, there's also a Bosch 9DOF chip that appears much easier to use as it does the IMU calculations for you...
  • Rayman wrote: »
    You can make your own. We can't though, as the volume is just too low for our NRE and setup.
  • VonSzarvasVonSzarvas Posts: 3,283
    edited 2021-01-04 08:22
    @Rayman
    Parallax has a module in stock with that LSM9DS1 9DOF :
    https://www.parallax.com/product/lsm9ds1-9-axis-imu-module/
    You can find code objects and design files at the downloads tab (under the product on that same link).
    C code libraries and BlocklyProp blocks example included. Hopefully P2+Flexprop will allow those P1 C code libraries to be used for P2.
  • Since I ordered the Propeller 2 Mini Starter Bundle, and I am waiting for delivery, I think what would be a necessary board is the microSD click. I think that should be a good fit, now that the P2 has 512KB, to handle the driver code.
    Ray
    I'd be interested in a TCP/IP one...
    This one looks good:
    https://www.mikroe.com/eth-wiz-click
    This one is interesting...
    https://www.mikroe.com/ribus-click
    Let's you connect to the https://riverdi.com/ series of EVE powered displays...
