Please help: PIN definition on THIS STAMP 1
in BASIC Stamp
please help me,
I cannot find the pin defintion on this stamp 1 chip,
I have just got 5 such stamps which can do good work for me,
but nowhere the pins are defined - to be sure:
many thanks from Germany
Schwipp
Schwipp
but they don't answer my email questions.
I used lots of their stamp products 25 years ago, now I have a simple application for it again.
So much for their support then, clearly nothing like Parallax!
Pinouts on such a simple PCB are easy to work out. Just continuity check the PIC chip's pins to the module's pins while checking the datasheet of the PIC chip itself. There you have it.
thanksa lot.
I did not know this.
But:
Do you think Wilke used the original Parallax chip loaded already with the interpreter software?
best wishes Schwipp
later:
I phoned Wilke and asked for basic- "KNOPF" - Knopf is the keyword which I did not remember.
They send my this, so many thanks for your advice!!
Problem of the PIN definition of Wilke Basic Stamp1 KNOPF Briefmarke solved,
I used a multimeter and checked the wiring,
together with the Pin defition of PIC16C56 given in a schematic attached by Peter Jakacki above:
PIN 11 of Wilke Basic Stamp1 "Knopf" = RA3 = PC Busy = PIN 1 of 3-PIN-SIP-Socket of Parallax "Basic Stamp 1 Serial Adapter", bidirectional
PIN 12 of Wilke Basic Stamp1 "Knopf" = ToCkI (To Clock Input?) = PC Data = PIN 2 of 3-PIN-SIP-Socket , only sends data to stamp
PIN 7 of Wilke Basic Stamp1 "Knopf" = Ground = PIN 3 of 3-PIN-SIP-Socket
