Need a help with coupling Parallex 360 servo feedback motor to D shaft
in Accessories
Hello all,
i need to connect my parallex 360 servo (having 25 tooth 5.96mm OD in datasheet) to a d-shaft of encoder.
Is there any coupler anybody has tried ? or please suggest some coupler
it was helpful to get the name
Also, I would recommend using a flexible shaft coupler that allows for slight misalignment between the servo and the encoder; otherwise, something could break. I've seen it happen.
But more to the point, the Servo 360 has a built-in encoder, and it's a very good one. Why do you need an external encoder to begin with?
I once broke the shaft (0.25" dia.) on a $160 NEMA 23 stepper motor due to misalignment. All I could say at the time was "OUCH"
