Flip and propellerC language; RESOLVED
245678
  • Ingenious, you guys should get together and write a book about Prop C.
    thank you
  • The "book" is available by just clicking on "Help" in SimpleIDE. Most of the information is in the various links.
  • bbrienbbrien Posts: 288
    edited 2020-02-04 - 03:49:56
    #include "simpletools.h"
              #include "propeller.h"
              #define clkset  (XTAL1*PLL1x,5000000)
              int main()
                 int mask = 0xff0000;
                 int  freq = CLKFREQ>>1;
                 DIRA = mask;
               while(1)
                  int button1 = input(3);
                  if(button1 == 1)
                      high(17);
                      pause(200);
                      low(17);
                      pause(200);
                    else
                       low(17);
                  int button2 = input(4);
                  if(button2 == 1)
                      high(18);
                      pause(200);
                      low(18);
                      pause(200);
                   else
                      low(18);
                  int button3 = input(5);
                  if(button3 ==1)
                      high(19);
                      pause(200);
                      low(19);
                      pause(200);
                   else
                      low(19);
                  int  button4 = input(6);
                  if(button4 == 1)
                      high(20);
                      pause(200);
                      low(20);
                      pause(200);
                   else
                      low(20);
  • Dave HeinDave Hein Posts: 6,064
    edited 2020-02-02 - 03:32:55
    You are not using clkset() correctly. You are using a #define to redefine it. Notice that the compiler is giving a warning about this. You should call clkset() at the beginning of your program by adding the line clkset(0x6b,5000000);" at the beginning of the main routine.
    You have a typo where you declare freq, and initialize it to "CLKFREQ>>!". You probably meant "CLKFREQ>>1".
    After fixing these problems the program compiles OK. I don't get an error about an "else" without a previous "if".
  • correction made , but still having the same problem.
    edited 2020-02-02 - 04:12:43
    Can you attach your *.c file instead of including it in a code block? Maybe you have some weird character in your file that isn't visible in the code block.
    edited 2020-02-02 - 04:24:11
    Make sure you don't have a statement or a semicolon immediately after the if statement. That would cause the error you're seeing. So instead of
                  if(button3 ==1)
                      high(19);
                      pause(200);
                      low(19);
                      pause(200);
                   else
                      low(19);
    if you had
                  if(button3 ==1);
                      high(19);
                      pause(200);
                      low(19);
                      pause(200);
                   else
                      low(19);
    you would see the error.
    I have accidentally created errors like that in the past when I added a debug print after the if statement, but before the "{".
  • Corrected the mistakes and it builds now and loads, however the outputs are not right. If I hold the button down the output pins should remain active flashing continuously until I release the button, but it doesn't. If I depress the button the corresponding led stays lit for approximately 2 seconds and then shuts off and doesn't reactivate for a second or two.
    edited 2020-02-04 - 13:43:47
    Please attach your code. I suspect it has something to do with the way you set the clock frequency.
    Try holding the button down for 20 seconds. I'm guessing that you'll see it toggle at a very low rate.
  • complete program is about 5 or 6 posts back.
  • That is clearly not the program you were running. That code doesn't even compile. If you'd like some help, please attach your current code. Otherwise, we're just guessing at what changes you made that may be causing the current problem.
    edited 2020-02-06 - 02:43:31
    Sorry about that,wrong sheet. New sheet
     int main()
       clkset(0x6b,50000000);
       DIRA = mask;
     while(1)
       if(button1 == 1)
         high(17);
         pause(200);
         low(17);
         pause(200);
       else
         low(17);
      if(button2 == 1)
        high(18);
        pause(200);
        low(18);
        pause(200);
      else
        low(18);
      int button3 = input(19);
      if(button3 == 1)
        high(19);
        pause(200);
        low(19);
        pause(200);
      else
        low(19);
      int button4 = input(20);
      if(button4 == 1)
        high(20);
        pause(200);
        low(20);
        pause(200);
      else
        low(20);
  • I ran the program on my propeller development board, and it works OK for me. Of course, I had to fix the call to clkset first. It was missing the right parenthesis.
    What board are you using for the propeller? Did you build it yourself, or are you using a pre-built one? Have you run any other programs on this board?
    edited 2020-02-06 - 19:48:40
    Flip from parallax running at 5MHz. I changed the pause amounts to a range of 20 to 70 and they flash much faster now. Now I want to generate a slow PWM to run my motors. I will include my next program. It doesn't produce the desired results, please check it out. It turns on but no PWM pulse.
     int main()
       int microsecond = CLKFREQ/1000000;
       int highClocks = microsec * 10;
       int lowClocks = microsec * 90;
       DIRA = mask;
       while(1)
         if(button1 == 1)
            OUTA |= (1<<17);
            waitcnt( CNT + highClocks) ;
            OUTA &= ~(1<<17);
            waitcnt( CNT + lowClocks );
        if(button2 ==1)
           OUTA |=(1<<18);
           waitcnt( CNT + highClocks);
          OUTA &= ~(1<<18);
          waitcnt( CNT + lowClocks);
       if(button3 == 1)
         OUTA |= (1<<19);
         OUTA &= ~(1<<19);
       if(button4 == 1)
         OUTA |= (1<<20);
         OUTA &= ~(1<<20);
  • I looked at int pwm_start(unsigned int cycleMicroseconds ) and void pwm_set( int pin, int channel, int tHigh ), but I guess I don't understand
    how to setup and use them. can someone please show me an example
    with multiple outputs . all I got was a multitude of errors.
  • Here's an example taken from the Propeller C tutorials. This tutorial also shows how to use a remote joystick to control a robot using X-Bee radios to send the joystick data to the motor control. The tutorial starts here:
    learn.parallax.com/tutorials/language/propeller-c/dc-motor-control-project
    /*This application uses PWM to drive two DC motors. Maximum PMW is set at 1000 with command "pwm_start(1000)". This application program is entended
    for use with a two H-bridges in this case the Pololu Motor Driver Carrier Board(28820). Also used in this application two DC gear motors(28819)
    P3 and P4 are used to drive the motors in a forward motion(includes turning). P2 and P5 are used to move in reverse. If you want to use only one
    motor comment out or remove pins 3 and 4 OR pins 2 and 5 from the code.
    #include "fdserial.h"
    #include "abdrive.h"
    int main()                                 // Main function
      pause(250);
      // Keep pins low if unused.
      set_outputs(5, 2, 0b0000);
      set_directions(5, 2, 0b1111);
      fdserial *xbee;
      xbee = fdserial_open( 9, 8, 0, 9600 );   // Begin the serial connection ( this is why we
                                               // needed the jumper cables connected to pins 8 and 9 )
      char data;
                                               // Create the variable that will be used to hold incoming data
      pwm_start(1000);
      while ( 1 )                              // Repeat this forever or until loss of power
        data = fdserial_rxChar( xbee );        // Set data to the data received from the XBee board
        if ( data == 'f' )                     // If the data incoming is telling the robot to move forward
        //(pin, pwm channel, 800/1000)         // Move forward 80 percent speed (800 of 1000)
         pwm_set(3, 1,800);                    // left wheel command set
         pwm_set(4, 0,800);                    // right wheel command set
        else if ( data == 'b' )                // If the data incoming is telling the robot to move backward, move backwards
                                               // Move backwards 80 percent speed (800 of 1000)
          pwm_set(2, 0,800);                   // left wheel command
          pwm_set(5, 1,800);                   // right wheel command
        else if ( data == 'l' )                // If the data incoming is telling the robot to turn left, turn left
        {                                      // Turn right motor faster than left motor to make a right turn
          pwm_set(4, 0,850);                   // right wheel command
          pwm_set(3, 1,550);                   // left wheel command
        else if ( data == 'r' )                // If the data incoming is telling the robot to turn right, turn right
        {                                      // Turn left motor faster than right to make a right turn
          pwm_set(3, 0, 850);
          pwm_set(4, 1, 550);
        else if ( data == 's' )                // If the data incoming is telling the robot to stop, then stop
          pwm_set(2, 0, 0);
          pwm_set(5, 1, 0);
          pwm_set(3, 0, 0);
          pwm_set(4, 1, 0);
  • I use the statement "if (button1 == 1)
    pwm_set(17, 0, 500);
    else if( button2 == 1)
    { I get an error: :'else' without a previous 'if'. Why is the IDE unable to recognize the previous'if'.?
  • Do you get any other warnings or errors? It would really help if you attached your source file so that we could duplicate the problem.
    edited 2020-02-08 - 20:00:18
    I will send the entire page,
     int main()
       clkset = 0x6b, 5000000;
       DIRA = mask;
       pause(250);
       pwm_start(3000);
     while(1)
       if (button1 ==1)
          pwm_set(17, 0, 1000);
        else
       if(button2 == 1)
          pwm_set(18, 0, 500);
        else
          pwm_set(18, 0, 0);
  • There were a number of errors in the program. Here is a corrected version showing the errors in comments.
     int main()
       clkset(0x6b, 5000000);    // **** error was "clkset = 0x6b, 5000000"
       DIRA = mask;               // ****  error was no ";" atend of statement
       pause(250);
       pwm_start(2000);
     while(1)
       if (button1 ==1)
        else
          pwm_set(17, 0, 0);
       if(button2 == 1)
        else
          pwm_set(18, 0, 0);
      if((button1 == 0) && (button2 == 0))   // ****  error was wrong syntax of if statement
          pwm_set(17, 0, 100);              // ****  error was no ";" at end of statement
    Note, I don't know if the program does what you want since I don't have your hardware. But it compiles.
    When debugging a SimpleIDE program, look at the errors and start with the one on top. Look at the numbers in the error statement. The first number is the line number. Correct that error, rebuild, and if there are errors handle the next in order from the top down.
  • 'else' without a previous 'if' statement
    expected statement before ')' token
  • bbrien, something doesn't make sense here. Every time you paste code into your responses it is missing characters that would cause obvious compiler errors. However, you never mention those errors. You always mention other errors, such as an else without if. The errors that we get from your posted code are completely different from the errors that you get. I can only conclude that the code you are posting is not the same as the code you are compiling.
    PLEASE ATTACH YOUR SOURCE FILES INSTEAD OF PASTING THEM INTO YOUR POST!!!
    Use the "Attach a file" link to attach a file.
  • bbrien wrote: »
    Did you copy the code I put into my post and then just paste it into a blank Simple IDE screen? Or are you typing it in?
    In your previous code where you got 'else' without a previous 'if' statement error, the if statement had incorrect syntax so the following 'else' statement resulted in the 'else' without a previous 'if' statement.
    That is why it is important to scroll to the top of the error listing and correct errors from the top down.
    Be sure that you have ";" at the end of each statement
    Also check the line number for the error and look for the error on the same numbered line in the SimpleIDE listing.
  • dgatelydgately Posts: 1,270
    edited 2020-02-08 - 19:50:52
    bbrien,
    SimpleIDE lets you copy the error text so you can paste it in to the forum. Please use the Code 'C' (Ctrl-O) command within the forum post to include your text in a nice code-style format. I've added an error to the following code just to get the error text to display as an example:
    Error code example as copied from SimpleIDE's "Build Error Code" menu item:
    Project Directory: ./Documents/PropCCode/
    SimpleIDE Version 1.1.0
    ./Documents/SimpleIDE/Learn/Simple Libraries/
    ./Documents/SimpleIDE/ Updated on: 2019-10-22
    propeller-elf-gcc -v GCC 4.6.1 (propellergcc_v1_0_0-36-g4c46ecb)
    propeller-elf-gcc -I . -L . -I ./Documents/PropCCode/AB-IR-Remote-Wav/library/libsimpletools -L ./Documents/PropCCode/AB-IR-Remote-Wav/library/libsimpletools/cmm/ -I ./Documents/PropCCode/DS1302Demo/library/libsimpletext -L ./Documents/PropCCode/DS1302Demo/library/libsimpletext/cmm/ -I ./Documents/PropCCode/EdgeHeader/library/libsimplei2c -L ./Documents/PropCCode/EdgeHeader/library/libsimplei2c/cmm/ -o cmm/bbrien.elf -Os -mcmm -m32bit-doubles -fno-exceptions -std=c99 bbrien.c -lm -lsimpletools -lsimpletext -lsimplei2c -lm -lsimpletools -lsimpletext -lm -lsimpletools -lm
    bbrien.c: In function 'main':
    bbrien.c:27:7: error: expected '(' before '{' token
    Done. Build Failed!
    Click error or warning messages above to debug.
    This allows other forum posters to help you in solving your error.
    You can also create a .zip file of your whole project too attach to your posting (As I've done in this post). Look in the Project menu for the "Zip" command. See an attached .zip of a shortened (& repaired) version of your code, below...
    dgately
    edited 2020-02-08 - 20:24:30
    Had a semicolon where it shouldn't have been and it took a long time before I saw it and it compiles now, now I have another problem. I get 13 rapid pulses and then no pulses for about 1 second + and then another group of pulses. What causes this and how do I correct. please refer to earlier post for revised program . thanks
  • New question regarding IIC communication, How hard is it. I have started reading the IIC library in simpleIDE.
  • IIC (aka I2C) is relatively simple at the hardware signalling level. It basically consists of 2 signals, a data signal (low or high) and a clock signal that indicates when a valid data bit is available. The communication protocols range from dead simple to fairly complex. See this page for a desription.
  • "This page" lost me. What I want to do is have the Flip read a signal from the Arduino which uses a single digit(4) as the address for I2C. What is the I2C address for the flip. My old sketch for the I2C read is as follows
       void receiveEvent (int  howMany)  //  received 4 bytes from hand controller
        if(howMany>=4)
         RmotorPinI2C = Wire.read();
         RdirPinI2C      = Wire.read();
         DmotorPinI2C = Wire.read();
         DdirPinI2C      = Wire.read();
         while(Wire.available()>0)
            Wire.read ;
         i2cFlag = true;
       void checkI2C()
         if (i2cFlag ==true)
           noInterrupts();
           analogWrite(rmotorPin,RmotorPinI2C);
           digitalWrite(rdirPin,RdirPinI2C);
           analogWrite(dmotorPin,DmotorPinI2C);
           digitalWrite(ddirPin,DdirPinI2C);
            interrupts();
            i2cFlag = false;
    How do I rewrite and what code lines do I use.
  • I am using an arduino as the master which uses an address of 4 and I want to use a propeller flip as a slave but I don't know what to use for the address to pass to the arduino, and what parts of simplei2c.h do I use to read the bytes from the above arduino code into the outputs of the 'flip'.
  • I'm going to have to give up on the idea of using I2C to communicate with the propeller Flip board. The Spin language has an assignment operator(:=) which copies the input directly to the output. Is the propeller C (==) the same or equivalent. I would prefer to use I2C so I wouldn't have to design a new board , but I cannot find any understandable examples. Is it possible to add spin code to the propeller C code.
