Raspberry Pi Zero as GPU over SPI
Rayman
It's working! Lots of work to do but check out what this code does (see code screenshot and monitor pic).
For $5, you can add a RasPi Zero to your system and get HDMI 24-bit color graphics!
Seems lower left corner is the origin for coordinates...
This is over HDMI.
The mini-HDMI connector on the RasPi Zero is a bit of a pain, but just need the right adapter or cable.
So, I'm just sending integers and converting to float in the RasPi...
The screenshot may have been a shameless plug for SpinEdit
Plus the HDMI cable adaptor
What link speeds did you achieve ?
Even UARTS should be able to go over 12MBd, tho the FIFOs on those are modest. If the code is mostly in Pi, the link speed may not be so important ?
You could always use C or BASIC instead of Spin. Those both handle (32 bit) floats natively. If you're using FlexGUI you could write the float handling routines in C or BASIC and do the main code in Spin, if you prefer that.
But, my Spin2 driver for OpenVG is similar to my Spin driver for EVE2 and with that it was all integer based.
So, I'm not convinced that I actually need to work in floating point to do what I want to do.
I'm not fully decided on this yet...
I am able to get to 5 MHz on the SPI bus without trying very hard. I think it's good enough for now.
BTW: You also need to add $5 or so for a uSD card.
I may have made a mistake in getting a giant, 60 GB one.
Problem is that I've found that you want to back up this uSD card, once you get it the way you want it.
But, the backup and restore tools only work on the whole disk.
So, it takes over an hour for me to backup the disk!
I need to start over with a small disk and then back that up.
I think the tool will let me burn a small image onto a big disk...
I really am living under a rock...
That may be a lot better. But, with a painful looking connector...
I'd like to have the P2 to show HDMI boot screen until the RasPi boots up and is ready to go.
The compute module might make it easier to connect RasPi and P2 HDMI pins together...
Do you intend this to be a production item ?
Can't you just enable the boot splash screen on the Pi? It's enabled in raspi-config and you can change the image shown by replacing /usr/share/plymouth/themes/pix/splash.png with another PNG. At least that's what a quick look on the internet returned.
You can also remove stuff you don't need from the OS to reduce the boot time to just a few seconds.
Also, it's less expensive and easier to use.
You can buy as many as you want at Microcenter.com, although the price increases with qty...
No, I don't do production.
I do want to either keep HDMI off or show some special splash screen until it's ready. Have to look into that more.
I've read about some things to increase boot speed
Definitely need to look into that as it is way to slow now...
I like the IDE you're using. Is it available for download? Does it use FastSpin behind the scenes? I like the behavior of FlexGUI (was fun to write a program in C that used a bunch of my Spin objects), but it's not as aesthetically pleasing as Propeller Tool, which is my choice for the P1.
I think the W version is a security issue for use at work though... I just read how NASA got hacked into by somebody connecting a W to their network...
Good thing there is a regular version without wifi…
Jon, thanks! You can get the SpinEdit IDE here: https://forums.parallax.com/discussion/169259/spinedit-editor-for-spin-spin2-and-fastbasic/p1
and yes, uses Fastspin for P2
Interestingly, there is no point function...
I had a go with a similar idea some time ago, but using freebasic on the Pi and communicating using normal ttl 232 serial. Parsing the serial input and converting to shapes colours shades even text was possible (text was a bit clunky- the font had to be rendered in advance).
Worked ok as a cheap hi-res display device. Done just for fun- no ultimate application.
Dave
Oh just noticed this is prop2 category- I was using prop1 :clown:
This one took a bit more coding...
This is great. Had to increase the memory split. I gave GPU 256MB as it crashed with 64MB...
I was wondering where the image file needs to be... Turns out (at least, I think so) it needs to be in same folder as the Raspi executable.
This is showing a 1920x1080x24-bit color image (attached) with the other stuff on top:
Check out this test of 1080p graphics in 24-bit color:
We're just about getting there natively on the P2. Once a suitable HyperRAM driver is done large frame buffers will be doable too, though 1080p 24bpp would probably need 2 HyperRAM modules, overclocking and sysclk/1 operation. Before then 1080p 16bpp would be somewhat easier to achieve and a better use of RAM bandwidth (24bpp wastes 25% of the 32bits transferred) but even that still needs something in the the vicinity of 150MB/s which is a lot unless you overclock to ~300MHz.
