HDMI compatible audio with P2 — Parallax Forums
This thread is started to discuss HDMI compatible audio as it might be cluttering up the P2-EVAL rev B thread.
  • roglohrogloh Posts: 5,194
    edited 2019-09-25 13:03
    I believe am getting really close to my implementation working as mentioned in the prior thread. I tried it out on the TV today, didn't sync yet so I have a bug somewhere to fix. Good thing is the code is being fully exercised and doesn't hang and the output timing is what I expect when I pulse LEDs at HYSNC, VSYNC transition times and scope them. I think I probably have a 10b code problem somewhere or I'm sending out bad data packets upsetting the TV.
    I am using a Saleae logic analyzer to capture the TMDS bus at much lower than normal frequencies. It is clocked at 11.9MHz giving a pixel rate of 1.19MHz. The sampling is done at 12MHz (USB rate) and that gives me almost one TMDS sample every clock, every now an again I get a duplicate because of this mismatch but I'm living with it.
    (In this case, channel 2 is red, channel 5 is green, channel 7 is blue, and channel 7 is TMDS clock - I lost the labels I had before I captured the pic for some reason).
    I wrote a rudimentary decoder in C to process the data exported by the Logic software and to display the 10b codes on each channel aligned with the clock edge and also showing a debug bit on the rightmost column. Red is first, green second, blue third, then clock, then a debug pin. If it matches a TERC4 encoded 10b value the nibble mapped to that value is shown too.
    So with these tools I can now see what is being sent out on the bus. Its not pretty but it sort of helps a lot. Every now and again (1 bit in 120), the clock brings in another sample due to the mismatch in timing (I really need a Logic analyzer with a clock input). Ozpropdev's version could get this data spot on. I just mark those with a * so I can ignore the data.
    This dump shows the start of the first packet (null packet in this case) I send in the data island. I temporarily made the guard band 2 pixels of all zeros so I could notice it easily on the logic analyzer. It's not meant to be using those values but I find it easier to debug.
    914 x 1050 - 141K
    1668 x 430 - 72K
    981 x 417 - 25K
  • potatoheadpotatohead Posts: 10,255
    edited 2019-09-25 13:09
    Re: Audio sample rate mismatch
    Seems to me, given that small error, a few samples can be dropped over time with low impact.
    Perhaps that can be done by looking at them. See two very similar in size, maybe some level qualifier apart and just average them into one sample.
    Compute the error, how many frames until an overrun happens, divide, and let the watcher just mooch a few samples out of the stream as needed to keep it sane.
    The other thing to watch might be quiet regions. Apply same idea, but watch for near zero. Maybe that case is the fall back catch up case too. Multiple samples averaged into a few will have low impact.
    This may not even be heard, but for pathological cases.
    All one needs is frame level accuracy. Drop the right number at whole island intervals, and the error becomes hours, not minutes or seconds, or is gone, depending. More than good enough, IMHO.
    When to emit audio samples...
    If you had a source producing samples at 44.1kHz, you could make a tiny FIFO to buffer them and encode/transmit them as HDMI opportunities occur.
    Or, you could just run a 32-bit NCO in software, updated twice on each scan line, to know when to encode/transmit new samples.
  • evanhevanh Posts: 15,258
    Just throw them into the HDMI as they come available. I bet the receiver will average them over time and digitally resample for it's own DACs. I wouldn't be surprised if you can have a something like 40 kHz sample rate and it'll just fine. The fact that they are packeted samples almost guarantees the receiver has to do this.
    It would be interesting to know if the vertical blanking time is usable for audio without any at horizontal blanking time.
  • I've attached the C program source to display the TMDS codes in case anyone wants to use it to debug sampled bytes of the HDMI bus pins. It's pretty hacky but it works I think. You pass it 8 bit raw binary data files, one byte used for each sample at the P2 clock rate. You can nominate which bits of an 8 bit byte are the red, green and blue channels, the clock and another debug bit which is useful to identify external events to find where they occur in the data. Capturing the P2 pins directly may not support this debug feature as easily as a logic analyzer does, because the 8 bit port on the P2 includes the negative signals as well. So only 4 data items are directly available in the byte on the P2 itself, unless you capture wider source pin data and merge it into a bit of the input file somehow or modify this program accordingly to work with 16 bit data for example.
    This tool took about 15mins to whip up and could potentially still be buggy, hope not, but YMMV.
    To build and run:
    RLs-MacBook-Pro:Documents roger$ gcc -o tm tm.c
    RLs-MacBook-Pro:Documents roger$ ./tm
    tm: decoder for TMDS binary data
    	Usage:
    		 tm <red_bit> <green_bit> <blue_bit> <clk_bit> [<dbg_bit>]
    		   where each <xxx_bit> indicates which bit of the byte
    		   contains the data for channel xxx
    		   and optional <dbg_bit> can be used for
    		   helping identifying events like vsync etc
    RLs-MacBook-Pro:Documents roger$ ./tm 2 5 6 7 1 < dump2-all.bin
    Decoding TMDS bits on binary input bytes:
      sample    bits        Red channel 2           Green channel 1         Blue channel 0                  Clock                   Debug
             1 *  2  --->   10              01              00                      00              11
             2   10  --->   0111110000              1011110000              0111110000                      0000011111              1111111111
             3   10  --->   0111110000              1011110000              0111110000                      0000011111              1111111111
             4   10  --->   0111110000              1011110000              0111110000                      0000011111              1111111111
             5   10  --->   0111110000              1011110000              0111110000                      0000011111              1111111111
             6   10  --->   0111110000              1011110000              0111110000                      0000011111              1111111111
             7   10  --->   0111110000              1011110000              0111110000                      0000011111              1111111111
             8   10  --->   0111110000              1011110000              0111110000                      0000011111              1111111111
             9   10  --->   0111110000              1011110000              0111110000                      0000011111              1111111111
            10 * 11  --->   01111100000             10111100000             01111100000                     00000111111             11111111111
            11   10  --->   0111110000              1011110000              0111110000                      0000011111              1111111111
            12   10  --->   0111110000              1011110000              0111110000                      0000011111              1111111111
    Cheers,
    Roger.
    c
    c
    4K
    tm.c 3.9K
  • cgracey wrote: »
    That's kind of what it is doing. On each scanline of 858 pixels @480p resolution (H_TOTAL) I add AUDIO_INC = 28*858 to an accumulator, and if the number is greater than LIMIT, I am allow to pull a sample from the audio fifo and send. I keep doing this until I either have an accumulator value below the LIMIT or I reach the 4 sub packet limit. Basically like an NCO in software. The factor of 28 keeps all values as integers with no fractions, and there are perfect relationships for all sample basic sample rates and the P2 clock.
        PROP_FREQ = (PIXEL_CLK * 10)  ' TODO: compute PLL frequency from this?
        ' Audio parameters
        SAMPLE_RATE = 32_000
        'SAMPLE_RATE = 44_100
        'SAMPLE_RATE = 48_000
        AUDIO_MULT  = 28
        AUDIO_INC   = (AUDIO_MULT * H_TOTAL)
        LIMIT       = (PIXEL_CLK * AUDIO_MULT / SAMPLE_RATE)
  • TonyB_TonyB_ Posts: 2,143
    edited 2019-09-26 00:26
    From the original thread, there are two unrelated issues re audio frequencies:
    1. Ensuring outgoing audio is sent via HDMI at the exact freq (e.g. 32/44.1/48 kHz) for different sysclocks (e.g. 252/270 MHz).
    2. Ensuring incoming audio is sampled at the exact freq (e.g. 32/44.1/48 kHz) for different sysclocks (e.g. 252/270 MHz) then output via HDMI.
    As mentioned in this post
    http://forums.parallax.com/discussion/comment/1478781/#Comment_1478781
    issue 1 is not a problem. Provided N and CTS are integers, the audio clock can be recreated from the video clock by the HDMI sink (aka receiver) with no errors, approximations or resampling. Audio Clock Regeneration packets contain the values of N and CTS so the sink knows what to use.
    Issue 2 has nothing to do with HDMI per se.
    Don't do any ratioing. See what happens.
    TonyB_ wrote: »
    The new smart pin mode for bitstream capturing with external clock should help a great deal with issue 2.
  • Some good news - just now I managed to get the HDMI picture syncing when sending out both NULL islands and what I consider should be valid packets in data islands. I have the same test pattern displayed as I posted in the P2-eval rev B original thread. This is good, it wasn't even working before and the HDTV wouldn't lock to it.
    I found the issue in the code, I had V and H sync pulses inverted in one last place where they shouldn't have been. That's what was breaking it.
    The audio samples that in theory I am encoding are not playing yet on my TV but that might be a problem either in the packet header data, the encoding or getting packets from the fifo. Will have to dig further there...
    I've also been enhancing my decoder program a bit too to decipher each sample further and print more details. The regular invalid (11 bit) sized samples do get annoying, but that's only an artefact of my sampling method. Still tidying this up and trying to align things nicer. It will be useful in general I think going into the future. It would be rather good for it to decode the island packets too and compute/validate the ECC bits, which should be possible once the data is robustly captured.
        sample   bits      Type                             Red(ch2)        Green(ch1)      Blue(ch0)
         82250 *   11 :->  RGB (FF_FE_FF)                   01111100000	10111100000	0111110000
         82251     10 :->  RGB (FE_01_FE)                   0111110000	1011110000	0111110000
         82252     10 :->  Blanking  VH=3  +V  +H           1101010100	1101010100	1010101011
         82253     10 :->  Blanking  VH=3  +V  +H           1101010100	1101010100	1010101011
         82254     10 :->  Blanking  VH=3  +V  +H           1101010100	1101010100	1010101011
         82255     10 :->  Blanking  VH=3  +V  +H           1101010100	1101010100	1010101011
         82256     10 :->  Blanking  VH=3  +V  +H           1101010100	1101010100	1010101011
         82257     10 :->  Blanking  VH=3  +V  +H           1101010100	1101010100	1010101011
         82258     10 :->  Blanking  VH=3  +V  +H           1101010100	1101010100	1010101011
         82259     10 :->  Blanking  VH=3  +V  +H           1101010100	1101010100	1010101011
         82260     10 :->  DataPreamble     +V  +H          0010101011	0010101011	1010101011
         82261 *   11 :->  RGB (FF_FF_FE)                   00110101011	00110101011	1111010101
         82262     10 :->  DataPreamble     +V  +H          0010101011	0010101011	1010101011
         82263     10 :->  DataPreamble     +V  +H          0010101011	0010101011	1010101011
         82264     10 :->  DataPreamble     +V  +H          0010101011	0010101011	1010101011
         82265     10 :->  DataPreamble     +V  +H          0010101011	0010101011	1010101011
         82266     10 :->  DataPreamble     +V  +H          0010101011	0010101011	1010101011
         82267     10 :->  DataPreamble     +V  +H          0010101011	0010101011	1010101011
         82268     10 :->  DataGuard        +V  H-          0100110011	0100110011	0101100011
         82269     10 :->  DataGuard        +V  H-          0100110011	0100110011	0101100011
         82270     10 :->  TERC4 0000_0000_0010 +V  H-      1010011100	1010011100	1011100100
         82271     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82272     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82273 *   11 :->  RGB (FE_FE_FF)                   10100111100	10100111100	0110001110
         82274     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82275     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82276     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82277     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82278     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82279     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82280     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82281     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82282     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82283     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82284     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82285 *   11 :->  RGB (FE_FE_FF)                   10100111100	10100111100	0110011110
         82286     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82287     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82288     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82289     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82290     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82291     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82292     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82293     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82294     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82295     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82296     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82297 *   11 :->  RGB (FE_FE_FF)                   10100111000	10100111000	0110011100
         82298     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82299     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82300     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82301     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82302     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82303     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82304     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82305     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82306     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82307     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82308     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82309 *   11 :->  RGB (FE_FF_FF)                   10100111000	10100111001	0110011100
         82310     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82311     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82312     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82313     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82314     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82315     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82316     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82317     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82318     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82319     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82320 *   11 :->  RGB (FE_FE_FE)                   10100011100	10100011100	0011001110
         82321     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82322     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82323     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82324     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82325     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82326     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82327     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82328     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82329     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82330     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82331     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100	1010011100	0110011100
         82332 *   11 :->  RGB (FE_FE_FE)                   10100111100	10100111100	1011000011
         82333     10 :->  TERC4 0000_0000_1011 +V  +H      1010011100	1010011100	1011000110
         82334     10 :->  DataGuard        +V  +H          0100110011	0100110011	1011000011
         82335     10 :->  DataGuard        +V  +H          0100110011	0100110011	1011000011
         82336     10 :->  Blanking  VH=3  +V  +H           1101010100	1101010100	1010101011
         82337     10 :->  Blanking  VH=3  +V  +H           1101010100	1101010100	1010101011
         82338     10 :->  Blanking  VH=3  +V  +H           1101010100	1101010100	1010101011
         82339     10 :->  Blanking  VH=3  +V  +H           1101010100	1101010100	1010101011
         82340     10 :->  Blanking  VH=3  +V  +H           1101010100	1101010100	1010101011
         82341     10 :->  Blanking  VH=3  +V  +H           1101010100	1101010100	1010101011
         82342     10 :->  Blanking  VH=3  +V  +H           1101010100	1101010100	1010101011
    edited 2019-09-28 01:22
    Got a bit further, but not hearing sound yet. :frown: I have proven that my encoder works, and send a valid info frame packet that tells the HDTV to use YUVYCbCr instead of RGB. I can see this in the displayed test bird picture output changing into weird "solarized" looking colours.
    This fact alone is great because for the HDTV to be able to decipher this packet it proves that the encoding I am doing is working properly across all bit lanes of the TMDS channels and the ECC bits are computing ok too, unless the Pioneer TV ignored them which it shouldn't. I've been looking at this code all week and can't see anything wrong with it since I fixed that sync problem, so unless it is subtle or staring me in the face and I'm missing it, my code might actually be ok.
    I recall when I used the P1V+HDMI audio FPGA stuff I put together some time ago with my HDTV I did have some issue in that some sample rates worked and some didn't, so I am now going to try a few other clocking combinations to see I get some sound output in at least one of them. There are 2 different video pixels frequencies 27MHz and 25.2MHz to try along with 3 sample rates, 32/44.1/48kHz, plus different N and CTS values to use. Going to have a play with that some more...I might just have been using a combination (32kHz+27MHz) that it doesn't like.
  • Well if you need a collection of monitors to test it on...
    Looks good, Rodger.
    edited 2019-09-28 03:45
    Tubular wrote: »
    I know, I might have to take you up on that offer next time I stop by...
    Looks good, Rodger.
    Thanks. Looks good on the TV, but doesn't "sound" good yet. :tongue:
    There is one way I know I could to get this going: if I resurrect my previously working FPGA P1V project on the FleaOhm, underclock it and redirect these HDMI bits to its Raspi compatible header pins for logic analyzer capture then compare with my own data stream, I will find the difference between the working/non-working versions. I've been avoiding doing that until now as it is quite a bit of work to do and a big mental context switch from P2 asm back to Verilog coding but if I get desperate soon enough I might have to go that far. That should find the problem for sure.
    edited 2019-09-28 05:03
    rogloh wrote: »
    This fact alone
    I just thought of something. In YCbCr, just dynamically encoding Y makes a nice, monochrome signal.
    Would not having to encode so many bits improve on the ability to do higher resolutions? Only the 8 Y bits need to change.
    Secondly, one could define static color regions, pre encoded perhaps.
  • potatohead wrote: »
    No, the pixel rate is still the same at ~27MHz so while you could have less hub memory used for a monochrome signal if you just used the Y channel, you still wouldn't increase the output resolution this way. To do that you'd need to overlock the P2 further. Eg, to 400MHz for 800x600 at 60Hz, perhaps somewhat less for devices supporting lower frame rates like some small LCDs or for other monitors if they can handle reduced blanking.
    I imagine high resolution monochrome modes could be very appealing in some applications, for that perhaps component or VGA is the way to go.
  • Ah yes, got it. That makes sense. For some reason, I got the idea of encoding being the primary bottleneck.
    I plan to use component in these ways myself.
  • Got a bit further on this P2 audio over HDMI after leaving it alone for a bit. Something was certainly staring me in the face the whole time, this morning I woke up and realised I had a bug in a particular XOR constant I was using and I fully expected that was the cause of the lack of audio working because it definitely prevented the correct creation of the audio parity check bits and channel status bits.
    I fixed it but was disappointed to find that is not the end of it. However now I am hearing some clicking sounds from the TV from my supposed 2kHz square wave test data. Prior to this I had nothing. So that's something at least but it's still broken though. Painfully slow to debug with just pure PASM right now and my fairly limited debug environment at this stage, but I'm working on it. I'm adding another COG to collect and output serial data items of choice to see if there is something else corrupted.
    :frown:
    Brian, maybe it is interpreting your audio sample data as audio configuration data, once in a while.
  • jmgjmg Posts: 15,149
    rogloh wrote: »
    ... However now I am hearing some clicking sounds from the TV from my supposed 2kHz square wave test data. ...
    That's progress.
    Did you scope the clicks to see if they were maybe part or whole packets ? Does the spacing of them give any useful info ?
  • SaucySolitonSaucySoliton Posts: 489
    edited 2019-09-30 23:33
    A note about the WAV header: Any modern S/PDIF receiver will actually mute the received audio for a fraction of a second, while it detects whether the bitstream is using Dolby Digital compression. Older receivers without this feature would be in danger of damaging the speakers or amplifier if anyone mistakenly sent them a compressed bitstream they couldn’t handle. Assuming your receiver has this feature, there’s nothing to worry about. If you do have a receiver which starts playing the very first sample you get, you’ll need to be much more careful about the initial conditions. For example, you won’t want to start the S/PDIF cog until the buffer has some valid data in it.
    https://scanlime.org/2011/04/spdif-digital-audio-on-a-microcontroller/
    I don't know if this would apply to HDMI. It shouldn't because HDMI should signal the type of data being sent. But I suppose there is a chance that a TV could decide that a perfect squarewave was invalid data. Maybe a sawtooth would help with troubleshooting buffering issues.
  • cgracey wrote: »
    Well the two packet headers are different in each but I guess anything is possible if there is data corruption somewhere and it if it ignores the CRC checks. I still want to test intentionally corrupting a CRC of the currently working video info frame to prove it ignores corrupted packets and stops changing into YCbCr mode for example.
    I currently send audio in the second packet of the two packet data island keeping the first packet free for either info frames or the 900Hz/1kHz clock regen packets. I will also try reversing the send sequence to see if that helps.
    One thing I read in someone's FPGA implementation is they said some TVs are sensitive to having Vsync and Hsync edges synchronized. I will check this too, as I don't think my own PASM2 code is actually doing that. That is one possible difference between Verilog and PASM2 that could be part of it. (By the way, this is Roger, ozpropdev is Brian.)
    jmg wrote: »
    I haven't yet, but they appear to be a slowly repeating sequence, maybe over about 10-15s or so and take a few seconds to get started. Seems to sound the same for different sampling rates too. Click pattern is at a lowish volume, and didn't seem to change when I change my audio fifo sequence to nulls. Almost as if it was getting data from another area of hub memory. And as if it plays one single sample at a time, then waits a bit. Clock regeneration issue perhaps? When I am sending audio samples and regen packets I added a pin toggle output on the P2 and it seems to be sending samples at the right rate ~32kHz or 48kHz etc, though I need to setup a smartpin to count pulses over a full second to prove my rates are precise, because it does fluctuate per scan line between one and two samples. It looks reasonable on the logic analyser right now.
    I am still playing around...
  • Maybe a sawtooth would help with troubleshooting buffering issues.
    Yeah I should also try another pattern. It's LPCM data so hopefully it isn't muted the same way in the TV as Dolby Digital, but I guess you never really know what the receiver side is doing, though I expect there are some different packet types for compressed audio to distinguish what is being sent.
  • One question I have for @cgracey .
    I have this in my code
    xcont   m_blank, syncs      'do the blank portion of the line
    ' 10b TMDS data patterns:
    syncs       long    %1101010100_1101010100_1010101011_10    'inactive H&V syncs
    ' The blank line streamer mode sends immediate data for the duration of the
    ' entire active line, and the HUB RAM is fully available in this interval.
    m_blank     long    $7F810000+H_ACTIVE  + (HDMI_GROUP << 20) 'blank line portion
    What happens if the streamer is the middle of sending out a bunch of pixels and you change the value of the syncs register above while it is streaming? Is it ok to do? Is this S register parameter value latched once at the start when the xcont instruction is issued and reused for the entire duration when sending immediate data, or does this S register's data need to remain stable for the entire duration of the streaming (in this case above, for H_ACTIVE transfers)?
    rogloh wrote: »
    The D and S values in XINIT/XZERO/XCONT are latched by the streamer when the instruction executes. So, D and S can change within your code before and after with no ill effect. It only matters what the values are at the time the instruction executes, which may be a while before the actual streamer command executes, as it is buffered.
  • Thanks Chip, I thought as much, as being buffered it would make sense to do things like that, but just needed some confirmation in case that might be causing me some grief.
