Surplus brand new OEM 20x4 Serial LCDs for sale (also Prop versions too)
2»
  • I have some with your name on them. :)
  • I still have ~80 of theses modules still available for $18.00 each. Quantity 10 at $15.00 each.
  • PublisonPublison Posts: 11,182
    edited 2019-10-02 - 17:56:46
    60 modules available for $15. Quantity 10 at $12 each. These are quality displays with enhanced features.
  • Peter JakackiPeter Jakacki Posts: 8,861
    edited 2019-10-03 - 03:46:45
    Here is an updated datasheet for the display. These are high quality displays used by an OEM as high contrast outdoor displays due to the FSTN LCD and the backpack is integrated as a thin surface-mount module so it is suitable for tight spaces.
    A single button on the rear of the unit can be used to change contrast or reset configuration to defaults. Baud baud, contrast, backlight brightness and other parameters are programmable via the serial port.
    2390 x 1669 - 1M
