Welcome to the Parallax Discussion Forums, sign-up to participate.
peter:BOOT$ ./p2asm ROM_137PBJ.spin2 ERROR: Expected ",", but found "[" _HUBBUF = $0_2000'[128] ' hub buffer[128] used as default buffer by _HubRxString (in writable hub ram!!)By putting a space between the 2000 and the comment it was happy but of course I am now tracking down other funnies.
peter:BOOT$ ./p2asm ROM_137PBJ.spin2 ERROR: Expected "41", but found " ACMD41= 41 +$40 ' $4000_0000 R1 - APP_SEND_OP_COND *Reqs CMD55 first" Segmentation fault peter:BOOT$ ./p2asm ROM_137PBJ.spin2 ERROR: Expected "23", but found " ACMD23= 23 +$40 ' NoBlks[22:0] R1 - SET_WR_BLOCK_ERASE_COUNT *Reqs CMD55 first" Segmentation faultSo the asm source doesn't have whitespace between ACMD41 and the = operator. Also noticed that it doesn't like ackpin without an # operator as it throws an error.
ERROR: Unexpected EOL ff1c4 156 fc0c0200 akpin pinreg '..acknowledge pin
ERROR: MODZ is undefined _RET_ MODZ _set wz ' "Z" = success ERROR: MODZ is undefined _RET_ MODZ _set wz ' "Z" = success ERROR: MODZ is undefined _RET_ MODZ _clr wz '/ return "NZ" = not found ERROR: MODZ is undefined _RET_ MODZ _set wz ' "Z" = success ERROR: MODZ is undefined _RET_ MODZ _clr wz ' "NZ" = fail ERROR: modc is undefined pRCMOVE modc $0F wc ' set carry for decrementing (always cleared by PUSH) ERROR: modc is undefined _ret_ modc 0 ERROR: MODZ is undefined _RET_ MODZ _set wz ' "Z" = success ERROR: MODZ is undefined _RET_ MODZ _set wz ' "Z" = success ERROR: MODZ is undefined _RET_ MODZ _clr wz '/ return "NZ" = not found ERROR: MODZ is undefined _RET_ MODZ _set wz ' "Z" = success ERROR: MODZ is undefined _RET_ MODZ _clr wz ' "NZ" = fail ERROR: Unexpected EOL akpin pinreg '..acknowledge pin ERROR: PTR not allowed if_z wrlut PTRA,retptr ' save IP onto return stack ERROR: modc is undefined pRCMOVE modc $0F wc ' set carry for decrementing (always cleared by PUSH) ERROR: modc is undefined _ret_ modc 0 ERROR: Unexpected EOL akpin pinreg '..acknowledge pin
MODC and MODZ are aliases in Pnut for MODCZ.
There's also an issue with labels not appearing in the listing if they are on the same line as other code. Looks like it's time to clean up all these issues. Is the file ROM_137PBJ.spin2 available somewhere so I can test with it? If not, I'll just create a file that contains all the issues you pointed out so I can test with it.
Thanks, you can find that file in my Dropbox P2 folder BOOT folder
Where is it please?
<link to ROM listing>
That listing is soooo helpful, I found why my code wasn't running after I combined all the other code it had a byte string at the end which ended up knocking out the word alignment and TAQOZ uses the lsb of a hub code address to indicate jumping rather than calling
Add an alignw
I have downloaded now. Thanks for the exe
Anyone with W10 will need to open a command line and supply the filename as a parameter. It helps to have P2ASM and the source file in the same folder.
Dave,
Thanks for this. Already proved useful with a bug to call the ROM routines. Was using a string in cog but it needs to be in hub and I forgot. The listing showed it up straight away
But it looks like p2asm is having a problem in the CON section digesting the bitwise decode "|<" (and maybe encode?) ">|" operators: and the enumeration[offset] syntax option:
I've attached the full source in case you'd like to use it as a test case.
I also found that I wasn't handling forward references to constants correctly. I had to restructure how I parse the source file to fix it. Previously, I used 2 passes, where the first pass gathered symbols and their values, and the second pass generated code. However, Spin/PASM requires processing all the CON symbols first, and then the next 2 passes are performed. If constants reference other constants that are defined later in the file it actually requires an additional pass through the source file.
Thanks for posting the USBHost code. I added it to the list of programs that I use to test the assembler.
If a constant larger than 9 bits is used with "#" instead of "##", the compiler does not issue an "out of range" error, e.g. mov reg, #54321 with p2asm will compile without error, but pnut throws a "Constant must be from 0 to 511" error.
It appears p2asm does not yet support PTRx expressions with AUGS to get 20 bit unscaled indexing, e.g. wrbyte reg, ptra[##54321] throws: Neither is a show stopper, though the # vs. ## did catch me out a couple of times. I very much appreciate what you've done with p2asm!
There is a case to have the assembler manage this automatically, where it can do so in an unambiguous manner. Just like most Assemblers now manage CALLs.
ie If it knows CONST is > 511, simply promote to the larger form, possibly with a comment in the listing.
##<511 still allows force of larger form, should users want that for some reason.
I picked up the GitHub code and the way you have the # vs. ## immediate error reporting works for me. If p2asm promotes an immediate > 511 to use augs/augd in the future, that would be OK too, as long as a warning gets raised so I can keep pnut happy, too
Also, I've run across a minor issue regarding ".local" symbols being accessible when they should be out of scope: p2asm will assemble with no error, but PNut catches it and throws an "Undefined symbol" error.
p2asm handles local labels a bit differently than PNut. Local labels are valid until the global label following the local label. Any code written for PNut will work with p2asm, but not vice-versa. I found it easier to implement it that way. If it becomes a problem I will change the handling of local labels to match PNut, but for now I'll probably leave it as is.
BTW, local labels are disabled when the assembler generates an object file. This is because local labels conflict with the code generated by GCC that generates labels like .Lxxxx. I'm not sure why we changed from :label to .label, but I did mention the conflict with GCC at the time.
I saw Peter Jakacki's mention of Tachyon Forth on comp.lang.forth --- sounded like a good Forth system --- also, the P2 seems to be an intriguing processor.
It is intriguing because it is possible to ban the use of interrupts. You have multiple cogs, so you don't really need interrupts.
This means that RTC (Return-stack Threaded Code) can be used. This is generally the 2nd fastest threading scheme --- STC (Subroutine Threaded Code) is generally the 1st fastest.
In RTC you use the return-stack pointer as your Forth IP register --- it points to the threaded code --- so, NEXT is a RET instruction.
You would use another register for your return-stack pointer.
The advantage of RTC over STC is that you can write your primitives using a traditional assembler, typically provided by the chip manufacturer --- with STC you have to meta-compile machine-code at run-time, typically with your own assembler --- also, another advantage of RTC over STC is that the code is usually less bloaty.
I might be interested in writing a Forth system for the P2 using RTC. This wouldn't compete directly against Tachyon Forth, because they have different goals. He is using byte-code for the purpose of reducing code size. I would be using RTC for the purpose of increasing execution speed, at the cost of more bloaty code.
I would need some info on the P2. The only thing I've found so far is: https://www.dropbox.com/s/l5w3voyknyae2k2/P2 instruction set.xlsx?dl=0
This is pretty good info, but not everything I need. In the opcodes, you have 9 bits specifying a register, so I assume there are 512 registers. Is this true?
This is a 32-bit processor, so I assume the registers are 32-bit. The address space is 1 megabyte though, right?
When CALL is done, is a 32-bit address pushed onto the return-stack? So RET expects a 32-bit number, although it only uses the lower 20 bits for the address. Is this true?
How many clock cycles does RET take? Peter Jakacki says he can do NEXT for byte-code in 6 clock cycles --- if RET takes 6 then RTC is not worthwhile --- it would have to take 3 to double the speed over byte-code, which would make it worthwhile.
I would need a lot more info on the P2 to get started --- any pointers would be appreciated --- thanks in advance.
yes and no.
P2 silicon is limited to 512k HUB, but the FPGA versions have 1MB when the FPGA can do that.
IIRC the stack is only as wide as it needs to be, and I think the non-address bits are ignored
On page 1, 1st post here are Document links - these show the Cycles/opcode timing, which can depend on where code runs from.
COG execution is always fastest.
https://forums.parallax.com/discussion/162298/prop2-fpga-files-updated-2-june-2018-final-version-32i/p1
