Shop Learn
PropBasic and RTC — Parallax Forums
PropBasic and RTC
I have a system running the Propeller coded in "C" that includes an RTC in one COG.
Is there a PropBasic program that does the same thing...setting and reading year, month, date, day, hour, minute, and seconds?
I really like PropBasic and would like to rebuild these systems using PropBasic.
Sincerely,
Discovery
  • I was sure that I used the DS1307 with PropBasic, not for the RTC, per se but the battery-backed RAM for a parts counter.
    Can't even find the DS1307 module right now. Will dig deeper over the weekend.
  • ersmithersmith Posts: 4,745
    edited 2018-10-05 22:12
    Discovery wrote: »
    By "an RTC in one COG" do you mean "one COG acting as an RTC" (counting seconds since the clock was last set) or do you mean "one COG driving an external RTC chip"?
    Making a COG count seconds is pretty simple, although you do need a bit of code to initialize the correct time at the start.
  • Yes...the code that was supplied by a Forum member was written in "C" and all the RTC functions ran in one COG. That propeller has been functioning for several years. As I mentioned, I found that PropBasic is the program code that I like best so for future systems I want to download an RTC into one propeller COG coded in PropBasic then sent to the propeller as compiled code.
    Has this been accomplished?
    Sincerely,
    Discovery
  • It really should be easy to write an RTC for PropBasic. I'm rusty on PropBasic syntax, but here is a version using fastspin Basic. It runs the "updateClock" routine in another COG to update the time, while the main program loops printing the time. In PropBasic I think you'd make updateClock a TASK.
    '' simple real time clock running in another cog
    const FREQUENCY = 80_000_000
    ' hours, minutes, seconds: 00-23, 00-59, 00-59
    dim as ubyte hours, mins, secs
    ' month, day in month: 1-12, 1-31
    dim as ubyte month, day
    ' year: 4 digits
    dim as integer year
    ' stack space for the RTC COG
    dim stack(10)
    '' helper subroutine; return number of days in month
    function daysInMonth() as uinteger
      ' february is a special case
      if month = 2 then
        if (year mod 4 = 0) then
          ' possible leap year
          if (year mod 100 <> 0) or (year mod 1000 = 0) then
            return 29  ' definite leap year
          endif
        endif
        return 28
      endif
      if (month = 4) or (month=6) or (month=9) or (month=11) return 30
      return 31
    end function
    '' routine to keep the clock up to date
    '' this is launched in another COG and just runs forever,
    '' waking once per second to update the time
    sub updateClock
      dim nextSecond
      nextSecond = getcnt() + FREQUENCY
      do
        waitcnt(nextSecond)
        nextSecond = nextSecond + FREQUENCY
        secs = secs + 1
        if (secs >= 60) then
          secs = 0
          mins = mins + 1
          if (mins >= 60) then
            mins = 0
    	hours = hours + 1
    	if (hours >= 24) then
    	  hours = 0
    	  day = day + 1
    	endif
          endif
        endif
        if (day > daysInMonth()) then
          day = 1
          month = month + 1
          if (month > 12) then
            month = 1
    	year = year + 1
          endif
        endif
      loop
    end sub
    '' main program
    '' initialize the time
    print "Enter year month day as YYYY-MM-DD ";
    '' read 10 characters into s$
    var s$ = input$(10)
    print
    '' split out the month, year, day
    year = val(left$(s$, 4))
    month = val(mid$(s$, 6, 2))
    day = val(right$(s$, 2))
    print "Enter time as hh:mm:ss ";
    s$ = input$(8)
    print
    hours = val(left$(s$, 2))
    mins = val(mid$(s$, 4, 2))
    secs = val(right$(s$, 2))
    ' start the RTC update thread on another COG
    var x = cpu(updateClock, @stack(1))
    ' now loop printing the time
    do
      print using "####_-%%_-%%  "; year, month, day;
      print using "##:%%:%%"; hours, mins, secs
      pausems(1000)
    loop
  • BeanBean Posts: 8,121
    Since I'm working on the Badge WX libraries here is an RTC for the Badge WX.
    ' Badge WX PropBasic Demo
    DEVICE P8X32A, XTAL1, PLL16X
    FREQ 80_000_000
    ' Libraries
    LOAD "Lib_BWX_OLED.pbas"
    hub_time    HUB BYTE(4) = 0 ' seconds, minutes, hours, seconds
    RTC TASK AUTO
    'VARs
    seconds  VAR LONG
    minutes  VAR LONG
    hours    VAR LONG
    temp     VAR LONG
    PROGRAM Start LMM
    '{$DEFINE LMM}
    Start:
      WRBYTE hub_Time, 50,58,23
      OLED_Start
      DO
        ' Read until seconds is stable
        DO
          RDBYTE hub_Time, seconds, minutes, hours, temp
        LOOP UNTIL seconds = temp
        OLED_Locate 0,2
        IF hours < 10 THEN
          OLED_PrintLGChar "0"
        ENDIF
        OLED_PrintLGValue hours
        OLED_PrintLGChar ":"
        IF minutes < 10 THEN
        ENDIF
        OLED_PrintLGValue minutes
        IF seconds < 10 THEN
        ENDIF
        OLED_PrintLGValue seconds
      LOOP
    END
    TASK RTC
      clocks  VAR LONG
      seconds VAR LONG
      minutes VAR LONG
      hours   VAR LONG
      clocks = CNT + 80_000_000
      DO
        WAITCNT clocks, 80_000_000
        INC seconds
        IF seconds = 60 THEN
          seconds = 0
          INC minutes
          IF minutes = 60 THEN
            minutes = 0
            INC hours
            IF hours = 24 THEN
              hours = 0
              ' adjust date here
            ENDIF ' hours = 24
          ENDIF ' minutes = 60
        ENDIF ' seconds = 60
        WRBYTE hub_Time, seconds, minutes, hours, seconds
      LOOP
    ENDTASK
    Bean
  • Excellent Bean...thank you.
    Sincerely,
    Discovery
  • Hi Bean,
    My first step in using the program information you provided is to: (1) set the clock time in the COG and (2) read the hours, minutes, and seconds from the main program to activate and deactivate propeller outputs at specific times during the course of a 24 hour day. I have no use for the display at this time.
    What additions or changes do I make to accomplish this task.
    Sincerely,
    Discovery
  • Bean,
    I figured it out...thanks.
    Discovery
  • Hi Bean,
    I inserted into your program a HIGH LED1 instruction just after the DO LOOP UNTIL instruction so that I can tell the Propeller Activity Board propeller clock is working. In the main LMM section I compare the Hours, Minutes, and Seconds to turn ON and OFF I/O. Once in a while it works. Most of the time the program does not get out of the DO LOOP UNTIL block. After about twelve or thirteen attempts...the clock synchronizes the seconds and the program runs perfectly well.
    Have you encountered this problem?
    Sincerely,
    Discovery
  • Has anyone noticed this effect?
    Discovery
  • Okay...I got it...I think.
    With the Propeller Activity Board powered by a 12 volt external power source, the prop was loaded with the program. However, the second synchronization code was modified somewhat. The DO and LOOP UNTIL instructions were removed. The clock ran right off and kept excellent time except it took 2 seconds for the clock to start. So, there is a 2 second constant error. It is important to disconnect the USB cable from the computer because when the computer shuts OFF and you power the computer back ON...the prop coded is removed. This modification appears to work fine.
    Discovery
  • No...that's not it.
    Every so often the code that is sent to the propeller will not execute. The code compiles and down loads but does not run. When the code starts, I turn on LED1 to make sure that the code is actually running. When I made the change to remove the DO LOOP UNTIL instructions, the Propeller would not execute. I removed the USB cable from the computer, reinserted it, ran the program, but it would not execute. I turned cycled the power on the Activity board but the same result occurred. Other programs that ran fine a few minutes before would not execute either.
    I did notice that when I shut cycled power on the computer and bring PropellerIDE back on line all the programs run even the clock program that has the seconds synchronizer in it. The Propeller develops this state every so often but when I restart PropellerIDE it clears the Propeller and programs then run on the Propeller.
    I can now get the clock program to run and control the I/O for clock start and stop times.
    Discovery
  • If I understand, correctly, I have a similar problem. I use ViewPort for my development environment and the platform is the old development board.
    I suspected that this was a ViewPort quirk so I simply hit the board's hardware reset, prior to downloading. No biggie for me.
  • Mickster,
    Testing shows that pressing the reset, removing the USB cable, and moving the power switch to OFF will not clear the problem. Code is downloaded with no error but the propeller will not execute the code. The only method I found to get the propeller to execute the code after it encounters this condition is to reload the PropellerIDE and download the code again...then the propeller executes the code correctly. Strange!
    Sincerely,
    Discovery
  • Hi Bean,
    Your PropBasic clock program is working perfectly. It keeps time really well.
    The code is simple...and elegant, thank you.
    My next step is to write and read data to/from the removable memory on the Propeller Activity Board using PropBasic...half a gigabyte or more. What coding would you recommend. I would like the code to run as fast as possible with PropBasic.
    Sincerely,
    Discovery
    I don't have an activity board. What is the removable memory ? SD card ?
    If it is SD card, I'm afraid I haven't done any coding to read/write an SD card.
    It would be quite a project, and I just don't have the time right now.
    Bean
  • Discovery...for what it is worth...I have had the same problem with the code downloading, but not executing. I too must turn off the power to the FLIP, back out of the IDE, turn the power on to the FLIP, making sure that the USB is plugged in to the computer, listen for my laptop to "ding", meaning it sees the USB/FLIP, and then open the propbasicIDE. Then all works well. If I see at the bottom of the downloading page, the RED letters, "SUCCESS", then I also know the program has downloaded.
    DenO
  • Thanks Denno...we are on the same page.
    Bean...rats, I was hoping.
    One of the guys on the FORUM spent a great deal of time and some of my money to write the "C" code to write and read the SD memory on the Propeller Activity Board. The code is not pretty but it does the job. I cannot stand "C" but like PropBasic.
    I understand that you are very busy. Maybe some time in the future perhaps?
    Sincerely,
    Discovery
  • Bean,
    What do you think the chances are that I can convert line-by-line the "C" code I have for Writing/Reading the SD memory into PropBasic code?
    Sincerely,
    Discovery
  • pmrobertpmrobert Posts: 632
    edited 2018-10-27 22:35
    This PropBasic code from maxwin worked fine for me a few years ago. YMMV! You'll need 7Zip to extract it.
    7z
    4K
    sd.7z 3.6K
  • pmrobert...my computer cannot unzip this file...what do you suggest?
    Discovery
  • Discovery wrote: »
    Discovery
    I downloaded and unpacked the above 7z file and put it into the zip file below.
  • Bauer,
    Thank you.
    Discovery
  • Bauer,
    By any chance, would you happen to have a short PropBasic program that uses the library functions you sent to write and read some data onto and off of the SD?
    Sincerely,
    Discovery
    Bauer,
    Sincerely,
    Discovery
    Take a look at the https://forums.parallax.com/discussion/122615/propbasic-sd-card forum entries. These entries appear to be posted by the creator of the sd.lib library
    edited 2018-10-28 18:36
    I may have neglected to attach the sample application for that library. Also, any further attached files will be zipped not 7zipped - I was lazy that day! Sorry... :-)
    Mike R.
    '   File...... SDplay10
    '   Purpose... Attempt to develop SD read/write routines with PropBASIC
    '   Author.... Maxwin
    '   E-mail.... max@winsoft.hu
    '   Started... 17 05 2010
    '   Updated... 09 09 2010
    ' A BIG thank you to JonnyMac for serial.lib & delays.lib
    ' A BIG thank you to Bean for PropBasic ! Why I Propeller.
    ' Program Description / Notes
    ' Low level SD card interfacing for PropBasic.
    ' The idea is to use an SD card as a mass storage device.
    ' Ideal for datalogging applications.
    ' Read/Write data in 512 byte blocks into sectors 1 to X (depending on card size)
    ' Tip: To read the card contents with a PC, use software such as "HxD", http://mh-nexus.de/en/hxd/
    '  run the program, choose the "Extras" menu, then select "Open disc..."
    '  or write your own application in .NET and open a filestream on PhysicalDriveX
    '  some advice available here: http://www.fort-awesome.net/blog/2010/03/25/MBR_VBR_and_Raw_Disk
    ' The various serial TX statements output diagnostic messages
    '  to the standard PST on pin 30 at the baud rate set by CONstant.
    ' Instructions:
    ' Connect an SD card using the standard Parallax SD card adapter (or equivalent)
    ' and use (or change) the PIN declarations shown below as required.
    ' Then run the program - the PST (Parallax Serial Terminal) connected
    ' to pins 30/31 of the propeller will display some details about the sd card
    ' Terminal will display some card info!
    ' Conditional Compilation Symbols
    ' Device Settings
    XIN             5_000_000
    ' Constants
            Baud            CON     "T57600"        ' serial.lib
            HOME            CON     1
            LF              CON     10
            CR              CON     13
            CLS             CON     16
            SPACE           CON     32
            COMMA           CON     44
    ' I/O Pins
            TX              PIN     30      HIGH    ' serial.lib
            SD_CSPIN        PIN     23      HIGH    ' sd.lib
            SD_DIPIN        PIN     24      HIGH    ' sd.lib
            SD_SCLKPIN      PIN     25      OUTPUT  ' sd.lib
            SD_DOPIN        PIN     26      INPUT   ' sd.lib
            SD_CARDINPIN    PIN     27      INPUT   ' sd.lib
    ' Shared (hub) Variables (Byte, Word, Long)
    ' Shared (hub) Data (DATA, WDATA, LDATA, FILE)
    ' TASK Definitions
    ' Cog Variables (Long only)
            tmp             VAR     LONG
            idx             VAR     LONG
    ' SUB/FUNC Definitions
            LOAD "Library/sd.lib"
            LOAD "Library/serial.lib"
            LOAD "Library/delays.lib"
      PROGRAM Start LMM
    Start:
            ' user start-up code
            DELAY_MS 2500
            TX_BYTE CLS
            TX_STR " - SDplay - "
            TX_BYTE CR
    Main:
            ' Wait for SD Card to be inserted.
            TX_STR " Insert card : "
            DO
                    IF SD_CARDINPIN = 0 THEN EXIT
                    DELAY_MS 250
            LOOP
            TX_STR  "Card inserted."
            TX_BYTE CR
            ' Open SD card
            tmp = SD_OPEN
            IF tmp = 1 GOTO Main
            ' Read card name & serial number, then display
            tmp = SD_READID
            TX_STR "Card name="
            FOR idx = 0 TO 4
                    TX_BYTE SD_name(idx)
            NEXT
            TX_STR " ,Serial number="
            TX_DEC SD_serialnumber
            TX_BYTE CR
            ' Read size of card, then display
            tmp = SD_READSIZE
            TX_STR "Blocksize="
            TX_DEC SD_blocksize
            'TX_STR " ,Sectorsize="
            'TX_DEC SD_sectorsize
            TX_STR " ,Totalsectors="
            TX_DEC SD_totalsectors
            TX_STR " ,Totalcapacity="
            TX_DEC SD_totalcapacity
            TX_BYTE CR
            ' Write block to card
            ' First populate SD_bytebuffer with the data bytes
            ' SD_bytebuffer is 128 LONGS. Use BB_PUT to populate the buffer
            ' Store test data in buffer: ABCDEF...WXYZ (repeated!)
            tmp = 65
            FOR idx = 0 TO 511
                    BB_PUT idx, tmp
                    INC tmp
                    IF tmp = 90 THEN
                            tmp = 65        ' Reset back to 'A' char
                    ENDIF
            NEXT
            ' Write test data to card
            tmp = SD_WRITE 1                ' Write SD_bytebuffer to sector 1
            IF tmp = 0 THEN
                    TX_STR " -- Data Written OK! -- "
            ELSE
                    TX_STR " Writing failed! "
            ENDIF
            ' For demo, empty the SD_bytebuffer!
            FOR idx = 0 TO 511
                    BB_PUT idx, 0
            NEXT
            TX_BYTE CR
            ' Read block from card into SD_bytebuffer using BB_GET sub
            tmp = SD_READ 1                 ' Read sector 1 into SD_bytebuffer
            IF tmp = 0 THEN
                    TX_STR " -- Data Read OK! -- "
            ELSE
                    TX_STR " Reading failed! "
            ENDIF
            ' Display SD_bytebuffer on serial terminal (.. well, only first 20 bytes!)
            TX_BYTE CR
            TX_STR "20 bytes of data back from card:"
            TX_BYTE CR
            FOR idx = 0 TO 19
                    tmp = BB_GET idx
                    TX_BYTE tmp
            NEXT
            ' Close card when finished
            SD_CLOSE
            TX_BYTE CR
            TX_STR "End."
            'DELAY_MS 2500
            'GOTO Main
    END
    ' SUB/FUNC Code
    ' TASK Code
  • pmrobert...Thank you very much. The zip works.
    Now I can get started.
    Sincerely,
    Discovery
  • The Propeller on the Activity Board running Bean's time program is gaining time...ever so slight...but it is running fast.
    I don't suppose there is an easy way to adjust the clock to be precise?
    Sincerely,
    Discovery
    Sincerely,
    Discovery
    How fast? Since crystals are involved, they have a certain PPM tolerance.
    edited 2018-11-06 19:26
    As Publison stated, the issue is very likely crystal inaccuracy. You'll likely need to periodically update (reset) the time by some means. I use a GPS receiver when very accurate time is needed. Of course, this is not inexpensive and needs a decent signal from the GPS satellites so definitely has drawbacks. There are other options of course...
