Nixie Tube Clock
DigitalBob
My son bought me this cool nixie clock as a gift for Arduino. I have to figure out how to pin this in and get it to work with the Prop and BS2.
I always though adding blue LEDs to a Nixie display was a bit of a naff hipster gimmick. Not in the spirit of things.
Recently I found out there might be a very good reason for it.
It is suggested that Nixies might not start their gas discharge when voltage is applied without a bit of help from stray photons in the environment. Nixes were even made with some radio active stuff inside that gave them a kick in the dark and got them to light up.
This was never a problem for my Nixie clock back in the day, where every tube had it's own driver, but perhaps when multiplexing the Nixie drive at speed it is.
See here:
I have some Nixie tubes here. This calls for an experiment...
Edit: I take it back; they might be just blue on Bob's. I see now that mine is from a different vendor.
If you are going to use a Nixie display then use a Nixie display. These things are beautiful enough already. They don't need a cheapskate LED light show.
@DigitalBob
Really? What is up with that? It's just a link to a regular Youtube video.
As per one of Peter Jakacki's tips, on another thread (I don't found/remember where, ATM), try removing the "s" part of the "https" link address.
I believe it has to do with changing from one country to another, when linking, but I'm not sure. It worked for me, several times, so it should work for other ones too.
Henrique
