P2 Tricks and Traps
We had a similar document for P1, so thought it might be about time to start a P2 version.
Website: www.clusos.com
  • 4 Comments sorted by Date Added Votes
  • Cluso99Cluso99 Posts: 13,132
    edited December 2017 Vote Up0Vote Down
    WAITCTn
    In P1 we did this...
                    mov     count,            #(96*2)
                    mov     delay,            cnt
                    add     delay,            delay5us
    :loop           waitcnt delay,            delay5us
                    'do something
                    djnz    count,            #:loop
    In P2 we do this...
                    mov     count,            #(96*2)
                    getct   delay
    .loop           addct1  delay,            delay5us
                    waitct1
                    'do something
                    djnz    count,            #.loop
    And here is the trap: Our P1 code incorrectly converted to P2
                    mov     count,            #(96*2)
                    getct   delay
    .loop           waitct1
                    'do something
                    djnz    count,            #.loop
    Note we need to include the addct1 instruction into the loop because waitctn no longer adds to the count
  • Prop2 has WAITX instruction that is easier to use and does what's needed for the common use of just inserting a delay.
    If precise period or phase aligning is needed then ADDCT1 becomes effective.
    The Prisoner's Dilemma, in english - "Selfishness beats altruism within groups. Altruistic groups beat selfish groups." - Quoted part from 2007, D.S Wilson/E.O Wilson.
  • Cluso99 wrote: »
    I think the clue there for P1 users would be that WAITCTx is standalone and doesn't support D and S fields.
    Melbourne, Australia
  • RDWORD, RDLONG, WRWORD, WRLONG Hub non-aligned
    The P1 ignores lowest hub address bit(s) for non-aligned hub reads and writes.
    The P2 correctly accesses non-aligned word and long reads and writes.
    In the P1, there were tricks associated with the lower hub address bit(s) being ignored. This code will fail on P2.
