Prop2 Costs
cgracey
in Propeller 2
It looks like it's going to cost $250k to get all the NRE, test development, and mask set done. Then, we can order as many Prop2's as we want.
The process will return prototypes in 23 weeks. That's 5.5 months. Then 12 more weeks to production parts.
Out unit cost will be $5.00/unit, dropping to $4.00/unit when we reach 1M pieces.
Those numbers do not sound too bad ?
Is that cost with them testing the packaged devices, or is that the ready-to-package but not fully tested silicon ?
Seems like an okay amount of time to get the software ready. We ought to be able to have OpenSpin2 (or whatever we call it) reasonably stable by March for the prototypes. The C/C++ efforts ought to be reasonably good by then too.
That's for finished parts, packaged and tested.
I think this looks okay.
Our die is 8.5mm x 8.5mm, so only 350 untested die fit per 8" wafer. With 75% yield, that's 262 dies. $5 x 262 is $1310. I estimate package and test to be $1 per part, so that means they're charging us $1048 per wafer, which is quite decent, out the gate. Then, those costs drop by 20% by the time we reach 1M units.
If it is OTP, that allows late revisions on Boot, and also allows calibration values & Serial numbers to be put into each device.
Some of the early synthesis might run in parallel, but final merge go-ahead would need a confirm the PAD Ring is actually 100% ok.
Frankly, my plate is overflowing with what I've already got on it. I don't want to add more by trying to incorporate that EE block that will need new hookups and firmware to go with it. I'm just DONE making changes. If anything, I may pull the existing fuses out. I want something that I can be very sure about and simulate without caveats. This makes the chip more reliable, but it will have no code protection.
The exact blow curves can be confirmed with the PAD ring chips, correct ?
Understood, but you really should talk with OnSemi about just what exactly is needed to include EE Blocks, it may not be as scary as you imagine.
- they are sure to do these all the time, and even an EE Block that is programmed on the tester, makes the device a LOT more sale-able.
The big marketable gains I see from a programmable memory (be it OTP or EE) are
* Late BOOT changes are possible, and you can sell special ROM versions to larger customers
* Calibrate values for measured MHz/KHz of Oscs
* Serial Number
I don't know. I'm waiting to hear from Ken on that.
I am thinking of maybe a 4.5x4.5mm or smaller die (maybe 128KB Hub, 8 Cogs, ~32I/O with 16 smart pins) in a QFP/QFN-44/48 or even a DIP40. Or even the die as half and half ?
I presume the answer is another big synthesis cost and ring frame cost, but since you had previously suggested there could be a family of P2's, maybe this is a possability.
Might be worth considering/asking ???
What unusable space are you talking about?
We could make whatever size part we want. They'd all cost about the same for NRE. First time out, though, we'll make the biggest part possible, with 16 cogs and 512KB hub RAM.
At what stage do you know how much RAM actually fits ? - that 512k is still a somewhat vague and aspirational 'educated guess'.. ?
Is the Verilog > 512k ready ? If OnSemi finds more (or less ) RAM actually fits physically, does that connect-up just fine ?
I sent the Verilog files to them tonight, so maybe tomorrow they'll see if it compiles okay.
In another thread around here we were speculating about small outfits getting chips made for cheap, like 100,000 dollars. I argued that if the (logic only) design works in simulation and on FPGA it should ready to go. Others argued there was a ton expensive of work after the FPGA stage I was missing.
Just idly curious about the possibilities now a days. Might get more serious about it if my lotto numbers were to hit pay dirt.
Well, there's synthesis and place-and-route NRE expenses that are maybe $100k. Then that 28nm mask set for maybe $1.5M.
So I was pondering if you could have two sized dies on the one wafer. Provided there was not a big cost and time impact, a small P2 and a large P2 might give you more sales. Obviously the smaller die would be cheaper.
Perhaps the smaller die might also fit in the spaces that the larger 8.5x8.5mm die will not.
Probably the mask costs would not increase, or only by a small amount. Not sure if there would be any more synthesis costs.
It's just like making two different pcbs on a panel. The disadvantage is that whatever mix you decide upon, you can almost guarantee the sales volume will be different. However, you can adjust pricing to try and influence the mix.
Ah yes. 28nm might be pushing the point. But there are companies popping up claiming to be able to get one chips in the 100K ball park. Presumably bigger geometry and ASIC. I wonder how realistic that actually is.
There'd be an additional $185k for NRE and test development for each different die, even if you could share the reticle set, which I'm quite sure they won't let you do.
I reckon it was about 2011/12. Can only vaguely recall the announcement. This post of Batang from June 2011 alludes to the announcement
forums.parallax.com/discussion/comment/1010185/#Comment_1010185
Thanks for the update.
You cannot do anything to reduce NRE cost. And also considering that you have a fixed die size (8.5mm square) and fixed geometry (180nm) you cannot do anything to reduce the unit cost.
If I were you I would have crippled the design (ram, cogs, instructions, smart pins, ... everything) to make >1000 dies per wafer and get each unit at <$2.50 unit. Less is more, someone said.
Did you asked about power consumption?
VAR1: wait / running
VAR2: 1 cog / 4 cogs / 8 cogs 16 cogs
VAR3: 32 KHz / 1 MHz/ 16 MHz / 25 MHz / 80 MHz / 100 MHz / 155.52 MHz
... (scared) ...
We recently hit a million units on the P1, so it takes a while. Does that recover NRE? Yes.
P2 will be a different situation, entirely. It would take a poor set of assumptions to somehow calculate that our total investment is somewhat equal to the numbers Chip provided above. They're much larger.
