Radio Shack once again saved the day
Radio Shack once again saved the day .... The sign out front says "3 Days and we're gone ... everything must go ... office shelves, cabinets, furniture must go" .... So what do I go in there to buy? .... A Reed Relay for $1 that I was going to take apart anyway.... I just needed the Reed switch to make an electronic float sensor for a bilge sump pump. ... What's a Reed Switch in case you asked? Literally two thin pieces of metal (Reeds) that are separated by a millimeter or so in an insulated glass capsule. When a magnet is in their presence they become attracted to one another making an electrical connection. Placing a magnet on a water float creates an electrical means for detecting the water level.
Back in the 70's I built a homemade car alarm system and wanted a hidden switch to turn it on/off.
I glued a small magnet to a reed switch (see one on left).
Another magnet would allow it to act like a toggle switch depending on which end I touched it to.
Tucked it in a corner of the dash by the windshield .
Held the "triggering" magnet on the outside of the windshield to arm or disarm - worked great!
Pretty sure I bought these at Radio Shack
Nice to hear from Sir Beau!
Are these the same ones your talking about?
I nabbed a bunch a long time ago. As you can see, I have been into them.
BTW: What is under the blob?
It's an IC. I think it's called something like chip-on-board, where they just glue the wafer to the PCB and wire bond it directly.
Yep, chip-on-board, aka COB. A lot of early digital clocks and calculators used COBs.
Yes, I have seen them before in low cost products. This just seemed like an over complicated circuit for what it does, unless it holds it's state after being triggered. I don't think I even tried them, before I dismantled them. Probably a 555 type design of sorts. But that nice looking Inductor has me baffled.
Maybe this?
http://www.homemade-circuits.com/2012/04/simplest-piezo-driver-circuit-explained.html?m=1
(tl;dr : volume boost for piezo speaker)
Totally forgot that it is a piezo speaker, and has to be driven by frequency. It was right in front of my face the whole time.
Wonder if these same inductor's can be used in a charge pump circuit. I have some Maxim chips I can play with.
Yes, it's best not to try to bend the leads strait.
The leads are usually a heavy stiff wire, and will bust the end of the glass capsule. If you keep a firm grip on a pair of needle nose close to the glass helps, if you really must bend. Lost a couple scavenged reed switches trying to manhandle them in the past. Some of them are pretty small, thin glass package.
Seems like kids could have a lot of fun with these. I guess you could even tie strings to the magnets and setup tripwires.
http://www.goldmine-elec-products.com/prodinfo.asp?number=G21009A
Also http://losangeles.cbslocal.com/2017/05/30/woman-attacked-torrance/
I ended up not having to remove the reed from the relay (not to break the glass on the reed switch ... been there before as well), the magnet was able to trigger the reed with everything else just left intact... but notice the orientation (Aside from the image needing to be rotated 90 CW)... notice the orientation between the magnet and the reed switch. This approach was ideal for the type of sensor I needed and to streamline the overall sensor layout.
BTW, the reed switch is driving a relay which in turn energizes the motor.... the reed switch is NOT directly driving the motor.
One thing to note: with a pump like this there is very little hysteresis, so if there is any back flow when the motor turns off, then it will oscillate as the water rises and falls. Ideally you would have TWO float sensors at different levels to increase the hysteresis. In my case however I got away with one sensor because the bilge pump serves to prime a gravity siphon .... once primed, the pump doesn't even run, the siphon takes over... if the siphon fails, then the pump will prime it again.
Hopefully things will quiet down again, and this is not a sign of our times.
